ITEM: PLX Kiwi Wifi + iMFD wireless OBD2 dongle
CONDITION: Used, as new condition
PRICE: $150 ono (this is the iMFD version which allows you to add additional modules such as oil pressure, temp and all wideband O2 sensors to the unit. cheapest on ebay is $220 plus post)
DELIVERY/PICK UP INFORMATION: pick up from narre warren or melbourne cbd, or post
PAYMENT OPTIONS: Cash on pickup, or Direct Deposit if posting
CONTACT DETAILS: grantlyy@gmail.com, 0403 563 068 or post/pm
OTHER INFO: For Sale is my wireless OBDII Dongle i have been using with my iphone and ipad.
it can be used with various iphone and ipad applications such as dash command and a few others available.
1 month old, Comes with box. selling as i now have a efi live autocal which can log the data i need.
"Kiwi Wifi + iMFD combines the best of both worlds into one product. Since the OBDII port does not offer all the sensors you may want to monitor, the added iMFD sensor support allows you to add up to 32 additional dedicated sensor modules from the PLX product line. This includes wideband Air/Fuel Ratio, Exhaust Gas Temperature, Fluid Temperatures and much more. If you're already an owner of the standard Kiwi Wifi, we offer a $100 upgrade option if you later decide you need iMFD sensor support. The Kiwi Wifi + iMFD is 100% backwards compatible with Kiwi Wifi.
The added benefit of Kiwi Wifi + iMFD is that with every additional iMFD sensor module you add, your performance does not degrade. For example, if you're monitoring only 1 sensor from the OBDII port and your refresh rate is 5Hz, by monitoring 2 sensors, your refresh drops to 2.5Hz and so on. By adding 1 or 32 iMFD sensors, your refresh rate is always kept constant at 10Hz. This results in higher performance monitoring for even the most demanding applications. "
PICTURES:
Click for full size.
Thanks,
Grant
