ITEM: Holden 355 stroker kit. Genuine SCAT crank, SCAT 5.7" Chev full floating I beam rods, Keith Black hypereutectic stroker pistons.
CONDITION: Brand new
PRICE: $1400
DELIVERY/PICK UP INFORMATION: Pick up.
PAYMENT OPTIONS: COD, Direct Deposit, Funds Transfer
CONTACT DETAILS: PM or this thread.
OTHER INFO: This stuff is all brand new still in the boxes. I bought it all to build a 355 for my ute, but now i've decided to go a different direction which involves raising some more funds to finish my Torana off. The crank and rods are genuine SCAT straight out of the SCAT factory. The pistons are KB, which are a very good piston and they have a 5cc valve relief and they're 0.040" oversize. With stock VN heads, they will give around 10-10.2:1 comp.
To finish the kit off, you will need rings and bearings and get the rotating assembly balanced.
PICTURES:
ITEM: VN V8 engine block.
CONDITION: Used
PRICE: $550
OTHER INFO: VN Engine block. The block has been hot tanked, bored and honed to 0.040" oversize and had new cam bearings fitted. These blocks go for $400-$450 second hand untouched, this one is ready to use.
PICTURES:
ITEM: VN-VS injected heads.
CONDITION: Used
PRICE: $250
CONTACT DETAILS: Email, PM, Phone or Other
OTHER INFO: Used injected heads. They are complete and they're in pretty good condition, they came off a good running engine. They have been dis-assembled and new valve stem seals fitted as they were stuffed.
PICTURES: They're used VN heads, what's to see?
ITEM: 70mm throttle body
CONDITION: Used
PRICE: $100
DELIVERY/PICK UP INFORMATION: Pick up or postage at buyers expense.
OTHER INFO: 70mm throttle body with stainless steel throttle blade. In good used condition.
PICTURES: It's just a throttle body.
That's all for now, i have some other bits and pieces but i'll add those later when i dig out what else i have.
Will sell the stroker kit, block & heads for $2000.
I've also got various bits and pieces to put the engine back together (oil pump, manifold, flexplate, bolts, timing case, sump & pick up etc. etc.)
BUMP. No one wants a 355 stroker kit?
Bump, last chance before i Ebay it all.
