ITEM: Complete VL disc conversion, 3.08 diff gears, open wheeler diff, axles, extractors and throttle body.
CONDITION: Used as listed below
PRICE: Prices are listed below and are mainly firm but depending on offer
DELIVERY/PICK UP INFORMATION: Pickup preffered, but will help with postage on smaller items
PAYMENT OPTIONS: COD, Direct Deposit, Funds Transfer
CONTACT DETAILS: Call or SMS 0433 771 641, PLEASE DO NOT PM!
OTHER INFO:
Hey guys got some stuff i really wanna get rid of!
First of all i have a complete drum to disc brake conversion for VL, The brakes are from a VN diff and come complete with calipers, rotors, pads, handbrake assy, backing plates and bolts.. Everything needed to bolt them to your drum brake diff excluding handbrake cable. After $60 for the lot!
I also have a set of 3.08 diff gears from a VL V8 BT1, The gears are in good condition.. Were removed to put 4.11's for my own car, only removed 1 week ago! Asking $50..
Next i have a 25 spline BW minispooled centre with no gears.. The minispool is only about 4 months old, and the centre was removed from my VL, the bearings were in fine working order, no noises or anything.. Is has a snapped axle stub in the centre but i will try and remove it if i get time if not all you have to do is knock the pins out and it will fall out..
Centre is ready for you to bolt your gears to and go. Asking $60
Next is a XF throttle body that i wouldnt have a god damn clue where it came from! I found it in the shed and i have absolutely no use for it.. It seems to have already had the bolt holes drilled out the suit VL plenum but im unsure of what else it needed! Seems in good nic, throttle opens good and does not stick.
Asking $50
Also have another diff centre which is just a standard open wheel 28 spline centre from a VN, it has good bearings and 3.08 diff gears.. asking $50 for that one..
I have a set of VL pacemaker extractors that are in excelent condition, had the completely checked and re welded.. they have been coated in black exhaust paint and are ready to go! Asking $150
I also just found a whole pile of various axles from what i can see i have,
Two short 28 spline VN axles, A Long 28 spline VN axle, A short 25 spline VL axle and a long VK salisbury axles 6 cyl..
Message to confirm! $35 each!
Searched through the shed and i found 1x N/A VL/R31 Camshaft in good nic, slight surface rust where to camgear goes on.. $30
Also found a VL head, Unsure if cracked or not, has cam, lifters and springs in it.. Can't remember if i saw rocker gear or not was at the back. would suit rebuilt or port n polish work? $40 for whole thing!
I really want all this stuff gone!
You can contact me via SMS or Call 0433 771 641
All items are located in SA, but can help with postage! Please no time wasters i wont hold anything im sick of being screwed around!
Thanks!
NOTLOENUF "No one likes clean VS's?"Weezy "No, lol"NOTLOENUF "Lol, why not"Weezy "Boring, slow, V6's sound gay, did i mention slow? drop kicks own them and do single peggersand think they're heaps awesome. People put mad subs in them, paint the dash inserts different colours (generally same as body colour) some with the engine cover and then think they own a show car? Need I go on?"
Sorry, just saw the diff centre is 25 spline.
