ITEM: SC14 parts / unfinished kit
CONDITION: Some parts are new, some are old, read below.
PRICE: $350 for the lot
DELIVERY/PICK UP INFORMATION: I can post, you can pickupo or for a six pack I might deliver
PAYMENT OPTIONS: COD if pickup / drop off bank deposit if I have to post it.
CONTACT DETAILS: PM me here it is easier
OTHER INFO: All other info is below.
PICTURES: are Below.
With the template out of the way.
Hey everyone,
I was putting together an SC14 build for my VS berlina however I now have a V8 ute and no longer need these items, Basically my girlfriends birthday is comming up and i'd like to get her a Mimco Handbag so I need the cash, that being said no stupid offers, most of this stuff has been sourced from all over, it took time and money and isn't far from being complete.
If you buy everything you will still need.
To extend your DFI module wiring and relocate the DFI Module.
Have an extra groove machined into the existing pulley or buy a new pulley from ebay for $150
Swap the spline over from the spare rotors
Any extra bracket work
Some beer and a weekend, maybe a mate or two as well to install/build it.
Kit includes.
SC14 supercharger with spare rotors / spline (rotors in the SC14 are in great condition however previous muppet cut spline, spare rotors and spline are supplied)
A specially tuned Memcal to suit a VS V6 auto
Injectors from a US l67 and rebuild kits Part Number for Injectors 0 280 156 201
Pulley and clutch attachments with bearing and sleeve
Alloy pipes
Bypass valve (Plumb the output of the SC14 back to the input, when not under load the air will go around in a cycle and reduce load on the supercharger, it will make less noise and heat this way)
A Bracket that came with the SC14
I am after $350 for the lot
Pics are below
Captain bump :P have recieved a few messages so i'll answer some of the relevant questions here.
Q. Will I need to remove my air con to fit this?
A. No, but you will need to relocate your coil packs.
Q. Is this a complete bolt on install?
A. No you will need to make up some brackets and have a groove machined into the pulley and whatever else I said above.
Q. Will it blow my engine up?
A. At 3psi with bigger injectors and a tune to suit, I doubt it.
Oh and another item you will need that I forgot to mention, a longer serpentine belt from repco.
People who have ditched the aircon for more power/weight the stock belt will fit. thought i might just add that for you.
~ VN POWER ~ Click the scales
rough idea how much it would cost for everything required to install this?
If you do your own additional brackets I couldn't see you spending too much
Get the groove machined or buy a new pulley from ebay $50 - $150 depending on fabricator / seller
Belt $25
Relocate DFI module (Free)
Longer ignition leads $50
Some silicone joiner pipes (Not sure on cost)
i'm pretty sure thats everything.
Keep in mind that an SC14 alone on ebay normally goes for $300 dollers add onto that the injectorsand rebuild kits at $150 a bypass valve for $80 a custom tune for $100 alloy pipes and and spare spline and rotors which cost me $100.
This incomplete kit owes me over $600
Looks like Mr Beez Kneez is selling brackets. they are only $40 for JC members.
Supercharger Bracket SC14 CRS VN VP VR V6 Commdore
I really want this gone people.
Thanx mate, This should be sold, the injectors alone are worth $200 so whoever buy this are getting a good deal. good luck with the sale.
