ITEM: Rb30 forged engine
CONDITION: Rebuilt
PRICE: $3,500ono
DELIVERY/PICK UP INFORMATION: Pick-up preferred however willing to freight at your expense
PAYMENT OPTIONS: Cash on pickup, Bank deposit for freight
CONTACT DETAILS: PM, TXT 0448 644 653
OTHER INFO:
I have for sale my forged rb30 engine. Only selling due to going a different setup.
Please note. The twin turbos in the picture are NOT included in this listing. If you would like this setup, it will be extra on the listings ended price.
Alot of time has gone into this. The engine has only been run in. Approx done 5000k's. The engine had a t3 bolted to it that was running 8psi. Have dyno sheet there and receipt for engine work. It was its run in tune and made 183 odd rwkw and 550.8 nm of torque. This was with straight gas
Its a series 2 a6 block with the water and oil line holes. Has adjustable cam gear. Engine will have all the front back on it. No alternator, flywheel, intake or exhaust manifolds.
Engine work was done at a shop in Melbourne. Here is what is on the receipt:
Head is 55.5cc
Valve spring set
Cam Turbo ST2, Crow Cams
Degrease Block
Linish a Crankshaft, STD Size
Bore & Hone Block, 1mm Oversize
Drill out oil plugs on crank & retap for Screw in plugs
Dis, Ass & Align rods
Balance Engine
Surface block
Reco Head, Fit turbo Ex Valves
Supply & fit K-Line guides, Ex only
Assemble to long engine
Match porting on In, Ex
Valve seat inserts, Turbo heavy duty
Water pump
Con-rod bearing set, ACL Performance
Main bearing set, ACL Performance
Ex valve RB30 Nissan
Oil pump Nissan Hi Volume
Full gasket set
Head gasket, Race series turbo, Connetec
Timing belt RB30 Nissan
Belt tensioner RB30 Nissan
Valve Lifter, RB30 Nissan
ARP Head stud Kit RB30
Welch Plugs, Brass
Piston Forged Nissan RB30, Flat tops 1mm
Here are some more pictures, please note that the engine in the car is not the engine for sale. The engine for sale is the one on the stand.
http://www.ebay.com.au/itm/110792646...ht_2754wt_1139
too many time wasters so Im keeping this and putting it in our vl
$2000 needs to sell before this weekend!
he put a deposit in my bank, will let you know if it does
