ITEM: Pioneer twin 12" Pioneer champion series subs 400RWMS into 2 ohm (1200peak each) and a Kicker zx750.1 2011 model Amp (929RMS into 2 ohm certified)
CONDITION: Used
PRICE: $250ono for Subs, $300ono for amp. $500 for both
DELIVERY/PICK UP INFORMATION:
PAYMENT OPTIONS: COD
CONTACT DETAILS: PM, here.
OTHER INFO:
Specs For The Woofers Are -
12" Dual 2 ohm Champion Series Subwoofer
Power Handling:
Peak: 1200 watts
RMS: 400 watts
Impedance: Dual 2 ohm
IMPP with Aramid Fiber Cone
Dual Mass Magnet with Magnet Cover
Aramid fiber IMPP composite cone
Spring-Compression Binding Posts
3-layer fiber woven radial surround
Aluminum voice coil bobbin
Integrated single-sided terminals
Frequency REsponse: 18 Hz - 500 Hz
Sensitivity: 89 dB
Box Dimensions In mm Are -
285w
345h
455d at top
520d at bottom
^as from twitch as i got from him.
They're great subs, selling the car so no longer need them. The amp RRP is $700, and the subs coming out now are at $350 in a box each.. last time I saw the subs anyway.
I'll have them in the car until the day sold so you can listen to them - I'm over listening to them loud only did it for a couple of months and was over it. Anyone after loud clear bass will be after these, when the amp is on about 70% I can't even hear the speakers almost on some songs. And they still have more potential.
The subs are in good condition as is the amp, amp is screwed into the back of the sub box but i can easily take them off. Wouldn't even need a power drill.
The subs have a few marks on the face, could do with a little clean but they run absolutely fine.
PICTURES:
Can take some if you want, but they're known brands not shitty things, as I said you can look and hear them in my car if you want too. I have a few brackets holding it in my boot so it doesn't move around when I drive, which I'll supply with the subs if you want them.
Just a few pics.
Item: Vendetta 20" Rims
CONDITION: Used
PRICE: $1300ono - make me an offer
OTHER INFO:
Tiny tiny tiny gutter rash on one, I'd have to go around the wheel 3 times to find it
One wheel has a mark about 3mm wide and about 5mm long.. It's small but you can see it when you get up close.
One or two little stone marks in the dish.. well from every day driving it's a given - Not marked just little dings
They're kept in pretty good condition though. Are due for a clean though, as they are every week if you want to be looking good haha!
2 tyres are about 80%
1 tyre is about 98% - One popped an egg out - I hit a pot hole about 8am, then at like 5PM it popped out in 40 degree heat - The pot hole must of damaged the steel belts.
1 tyre is about 60%
the 1 tyre is warn on the inside (60% one) but it was flipped over about 2000k's ago, so it should even wear.
They're all far from being illegal besides the 60% one - you can replace it and have two new ones but it didn't need changing yet so I didn't bother.
Running Austyre 225/35R20 tyres, they stick real good for a cheap-ish tyre.
I'll let pictures do justice:
Depending how impatient I get more will be going up for sale.
KGO
Price drop on wheels to 1100ono - Found one little gutter rash mark on the other rear one.
Wheels 1000ono, last price on it. Looking for a quick sale.
Send some pix of amp to 0433431782 please mate - got receipt or anything still??
$1000ono bump. Last one before it goes on ebay for wheels!
$200 for subs
$250 for amp
KGO!
Also selling:
69mm Throttle body
12mm and 25mm mace spacers
3.7's LSD Diff (only done 4000k's, only just ran in!)
Make an offer!!
Need this shit sold in the next 2 weeks!! Quick bump make an offer!!! Subs and amps together for $400!!! That's less than what the amp is worth by itself!
GOGOGO!
Amp and sub sold!
Wheels on ebay: eBay Australia: Buy new & used fashion, electronics & home d
LSD Diff done about 4000k's just ran in - cost me $950 will sell for $700ono.
Mace spacers $250 for both
Throttle body 69mm cost $220 now selling $170ono
What the throttle body for?
Sent from my iPhone using Tapatalk
Get pics up for the spacers and diff and I'll see.....
Throttle body is for VS-VY ecotech, as is the spacers.
As for the diff, the diff is still in the car. But it looks like a normal diff? You can't tell if it's LSD or anything without putting it in.
LSD Should have a different tag stating it needs LSD oil.
