the calais door shells, are they the lower silver calais door moulds?
if so how much would postage to adelaide be?
OK people Im having a big shed cleanout & I need to move some parts, I need to make some room. Im happy to do deals on multiple purchases.
$250 - VT Electric front seats with adapter rails to suit VB-VK, Dark grey velour, wiring all there ready to wire up, info given on sale to wire up.
$250 - Cerulean Blue VK Berlina Seats & Door trims. All seats excellent condition no marks or tears. VR/VS door pods included witht he front door trims.
$250 - Blueprinted, port matched & externally Polished VK 202 EFI Inlet manifold,throttle body & fuel rail. This looks absolutely amazing and really sets off the engine bay. It needs a light polish as its dulled off a little from sitting in a box for a couple of years. Comes complete with injectors pictured as seen ready to bolt on.
$80 - Kelpro High flow VK EFI fuel injectors. These were purchased new and only did approx 200km in my car. A must when you start porting your head & installing a bigger cam.
$20 - VK EFI Airflow meter - removed from my car it was working when removed, its been sitting in a box for about 2 1/2years, I have no means of testing it (hence the cheap price) as far as I know it works.
$40 - 6cyl VH/EFI VK - HEI Electronic dizzy, excellent condition requires rotor button & dizzy cap. for $10 I will replace the standard nylon gear with a steel one. The dizzy is in excellent condition and has been fully checked out including the vacumn advance.
SOLD - Damaged but repairable Genuine HDT VK Group A Grill
$60 - Adapter seat rails to fit VT-VZ seats into a VB-VK commodore.
$35 - 1 set of 4 rear headrest locking pins with clips in excellent condition suit VH SLE, VK & VL Calais maybe others
$50 - VL Calais Cerulean Blue Door trims, perfect door trims, fronts have map pockets, one rear door trim has a damages backing board I have a perfect replacement backingboard which will be supplied these are easy to swap over. The door trim is still serviceable witht he damaged backing its just that im picky.
$30 - Genuine Holden Cold air intake for EFI VK
$70 - K&N filter element suit VL Walkinshaw or EFI VK in as new condition, cleaned and oiled. Only used for about 500km, I will swap for a VR/VS K&N panel filter
If you want the CAI & Panel filter have the CAI for $10.
SOLD - VK Calais Boot trim & LH eyebrow mould these are getting very rare and are pulling huge money on ebay
$40 - Pair of Genuine holden VL calais tail lights
$35 - VK Calais Rear centre garnish (between tail lights)
$50 - VB-VK - As new Kelpro strut top bearing plates, they were removed from the packaging, I fitted them to the struts, then removed them to fit adjustable
camber ones instead.
$20 - 4x VB-VK salisbury diff U-bolts with nuts to connect the tailshaft to the diff.
$15 - RH VH/VK DEPO after market headlight in as new condition Never fitted to a car just lived in the shed.
$50 - 6cyl Bosch starter motor part number BXH137 suit 202 VB-VK EH-HZ its the 1.4kw small body one.Its in perfect condition
$30 - 15/16 master cyl, purchased new used for 6 months.
$200 - Borgwarner LSD diff centre with a 2.92:1 ring gear, bolt of the gear ratio you want and it will slip straight into a 85 VK or VL diff
$70each - Assorted commodore tailshafts Aussie 4 speed to Salisbury diff, M76 borgwarner to Salisbury diff, Trimatic to Salisbury diff. All with excellent centre bearings & universals
SOLD - 1 set of VK commodore Calais door moulds
$50each - Axels suit Salisbury diff VB-84 VK, excellent condition
$15 - HJ/HX?? Dash clock was working when removed, had been living in a box for the past 8 years
SOLD - Rear disc brake conversion parts
- Master Cylinder
- 2 rear discs
- 2 rear brake calipers
- 2 brake lines for the calipers
- 4 handbrake shoes
- 2 backing plates
- Handbrake cable
- All the springs & clips needed
$50 - 6cyl Aussie 4 speed gearbox (gearbox in unknown condition it selects gears but havent had it in a car) & bell housing, bolts, clutch fork & clutch fork retaining spring, starter motor spacer/cover plate, clutch cover all in excellent condition
$15 - 6cyl Aussie 4 speed bell housing only
$50 - VL Commodore Electric window, power mirror & electric door locks wiring harness. This harness is in perfect condition, no damage or corrosion, all wires & connectors as original no joins etc. It will suit a VK will some minor modifications.
$30 - 1 set VB-VL Genuine Electric door lock solenoids
$50 - Genuine Momo HSV horn button perfect condition will fit most aftermarket steering wheels. This has the Lion & Helmet logo.
SOLD - CSA Delta 5 spoke mags, polished alloy with blackouts. Look similar to a Simmons F90 they are 15"x7" have 15/225/60 Rubber 2 have reasonable tread depth and 2 the outter edges are rather worn and would definitely need replacing. Selling coz they dont fit over my brakes.
Wanted VK SL centre console (not the highrise one) PM for details
starter motor is sold sold sold i believe![]()
if u still have it how much u think post for webber would cost to send to corio vic 3214
Shipping on the door moulds would be particularly expensive, I dotn really have the time to package them up, I would prefer pickup only on themOriginally Posted by VK_308
im interested in the calais door shells=moulds (bottom of doors +front 1/4 panels)?, are they in good condition ie no/minimal cracks and mounting lugs intact etc? and also the king springs s/low for 6 cyl as well.. are both these items still available?
im in syd, so i can pick them up in the next week or 2, how would u like them paid for.. bank transfer, cod?
cheers ,cam
Do you still have the windows for the VK? Is it all the door windows you have? What condition are they in? My windows have scratches all over them and as it is going to be a showcar, need to replace the windows.
bump more parts added
hey there, vkberlina, would you happen to have front windscren glass for a VB
cheers, nick
Hey mate, just wondering what diff the disc brake conversion is for?
Cheers,
Steve.
bump, parts list updated, some prices revised
hey scott
just sent u a pm about the door moulds, disk brake conversion and a few random questions
also was the car u were stripping out disk brake all round..if so do u have the handbrake cable?
cheers cam
i see you have a boot garnish for sale, do you have the eyebrow's aswell by nechance at all...? ive been looking for some at a cheaper price but every1 wants a faark load for them
hey u still got the vk grille if so will u post it 2 SA
hey mate how much for the master cylender by itself???
OK RAMBLER'S LET'S GET RAMBLING
I wont separate parts, PM me for postage & I will answer
could u plz pm me the info bout the vt-vz seat rails
Beware Of Imitations - Not The Latest Thing, But The Genuine Thing
pm sent about the grill
does that include all the calais door for $50,,, definately intersted here and probably can pick them up
thats what i am after is just the door trims, i have a mate who is going over your way in a couple of weeks, i will definately buy them if u still have them left
hey matey im interested in ur brake booster how much u reckon for postage to 4218 thanks
Driving a ford is like the special olympics....even if you win your still a retard
SPEED KILLS
Drive a Ford and live forever
Sex is good, Sex is golden, Sex is done in the back of a holden.
Do you still have the door trims? can you post/pm/email me some pics and prices to Act 2905? or would they cost to much to post?
cheers, Pat
just sent pm about bellhousing and taleshafts
