Results 1 to 9 of 9
Thread: f.s: 355 stroker
    SNAFFLER's Avatar
    SNAFFLER is offline location: melbourne
    Jan 2005
    maidstone/west side
    Default f.s: 355 stroker
    i built this 355 for a friend who has now decided to pull the pin on his VK calais project, so the motor is for sale.
    engine short is race prept, zero deck, line & tunnel bored, harrop 355 crank, A9L rods with ARP bolts, ACL race series 17cc dish pistons, bottom end fully ballaced, runs a true 10.5-1 compression. hi volume oil pump, JP double row timming gear (+2deg), oil restrictors were needed, baffled oil pan, heads ported with esky chrome moly springs & retainers and collets & shims, roller rockers & moly push rods, 304 crane cam shaft with a 525 lift (hyd) dialed in, recurved ICE ignition dizzy, runs a harrop single plane intake manifold followed with a 1000CFM MSD billet thottle body & runs a wolf 3D ecu.. also has billet rocker covers..
    this is a basic discription to the engines combo and no expence spared on this engine..
    i ran it on the engine dyno with another combo (286 cam) and it made 400hp with 420ft pounds of torque with a basic tune to the wolf 3D, but it maxed out the cam shaft, so i pulled it down and went for the biggest hyd combo i could get.. this motor will make 450-500hp with this combo and the proper tune to the wolf 3D, but if you change the cam shaft to a mechanical it will make 500+.. its never been started with the 304 engine combo, so the motors about 2hrs old with the 286 combo..
    engine cost me $12,500 to build
    his asking price is $8000
    dont ask for Receipts as i dont have them because i built this engine in a mates workshop and i used his account to get all work carried out and parts orderd.. so for tax reasons, all receipts are amonst his paper work..
    Troy711's Avatar
    Troy711 is offline Moderator Puppeh
    2007 WM Statesman
    Dec 2003
    Canberra, ACT
    Blog Entries
    geez, it seems like it has all the right gear! can i see some receipts?
    nah, juts kidding...
    dont suppose you have a few photos? dads looking at a torana as a project which has no motor and box so i am trying to talk him into putting an 8 into it. he is set on a 6 though, but i reckon i can change his mind.
    is your mate open to price negotiations?
    SNAFFLER's Avatar
    Jan 2005
    maidstone/west side
    troy ya funny bugger lol
    it cost me $12,500 to build at under trade costs and were selling for $8000
    as a quick sale, so sorry dude, price is pretty much set ok..
    but im 99% sure its sold already ok..
    just waiting for a deposit.
    but for sh1ts-n-jiggles, heres some pics for you
    the billet MSD throttle body is not shown in the pis.
    SNAFFLER's Avatar
    Jan 2005
    maidstone/west side
    Block -
    Brand new, zero decked, line bored & honed, cam tunnels honed, deburd,
    Acid tanked, new brass welsh plugs and brass cam plug.
    Crank, rods, pistons, balancer & flywheel all balanced to each other, race series ring, bearings & gaskets, JP double row timming gear set, mellins HV oil pump, high energy sump & pickup.
    pistons - race series 17cc D bowl
    Cam shaft - crane 304 with 525 lift hyd dialed in. +2deg
    Lifters - crane
    Push rods - crane chrome moly
    rocker arms - rolla street terra (yella terra`s)
    heads -
    Vn-vt castings, L34 valves (std) street ported by eddie woods
    mecheined faces and inlet faces mecheined, piston to valve cleance checked.
    springs - esky
    Retainers - esky
    Collets - esky
    all chrome molly
    comp ratio - 10.5-1
    other -
    custom made rocker covers with dash fittings & billet oil cap
    steel ballancer
    modifided water pump
    ice ignition dizzy recurved
    8mm bosch lead set
    harrop single plain manifold
    355 blue top injectors
    Troy711's Avatar
    2007 WM Statesman
    Dec 2003
    Canberra, ACT
    Blog Entries
    SNAFFLER's Avatar
    Jan 2005
    maidstone/west side
    Troy711's Avatar
    2007 WM Statesman
    Dec 2003
    Canberra, ACT
    Blog Entries
    SNAFFLER's Avatar
    Jan 2005
    maidstone/west side
    SNAFFLER's Avatar
    Jan 2005
    maidstone/west side
    still for sale..
  1. Stroker Kit
    By Cobez in forum General Discussion
    Last Post: 02-05-2009, 08:52 PM
  2. Which ECU is best for a 383 stroker?
    By sheepz89 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 20-12-2007, 05:15 AM
  3. V6 stroker
    By sircruisealotVS in forum V6 Development And Modification
    Last Post: 20-12-2006, 08:02 AM
  4. Stroker LPG?
    By Low_VX_Taxi in forum V6 Development And Modification
    Last Post: 15-12-2006, 04:53 PM
  5. Stroker kit for VR V6
    By VR V6 in forum V6 Development And Modification
    Last Post: 19-12-2005, 01:14 AM
