Hey,
as many of you know my car came off a trailer a week ago
and as a result im wrecking it for parts
This Item is on Ebay with a 7 day listing, soo if you want it you better call me
The Motor
the motor has done 230,000km and was purchased from VP_luke (now VN_luke) about a month ago, i had it in the car running for about a week before the car was written off... Also it has a fitting for the turbo oil return on the top of the sump, it is jb welded in and i took the sump off and cleaned it out to ensure NO metal shavings entered the engine, the engine has replaced inlet gaskets, crow cam heavy duty valve springs and is REALLY smooth, you might need to change the engine loom as i modified it to fit a VN s1, the looms out of a 93 VP that did 150,000km and looks good,
The Trans
the automatic transmission has done 180,000km, i pulled it out of a car at the wreckers and it has a Corvette servo installed, i wont lie the trans has worn seals... it wont slip once warm and under power but in the mornings it needs 5 mins to warm up before you go drive it, other than that its perfect
The Turbo Setup
now many of you know my setup, its a Ball bearing T04E (T4 rear housing) 0.50 Inlet compressor wheel and 0.68 exhust wheel (NOT housing size)
3" dump pipe to the car all mandrel bent, all the manifolds are press bent and comes with heat wrap.. the turbo outlet is 2" it then goes to 2.25" untill its opened up to 3" at the intercooler, then stays 3" till the throttle body
the components are as follows
* T04E Ball bearing turbo oil only
* 45mm external wastegate
* Manual Boost Controller
* 3" dump pipe
* High flowing turbo mandrel bent manifolds
* Steel braided oil lines -4 feed, -10 return
* Speed flow oil fittings, T peice at sender
* Greaddy Ripp off Type S Bov
* 600x300x80 3" inlet Intercooler (black)
* turbo clamps all round ($8 a peice... bolt type clamps)
* 2.25" + 3" intercooler piping, with bov flange
* Turbo Smart silicon adaptors
* 2 bar map sensor
* vaccume lines for everything
* 2" boost/vac gauge
*all gaskets required
all you need is bigger injectors and to tune it
im asking $2000 for the lot which is cheap considering how much i spent on it.
items located in Euroa, 3666 Victoria, thats north, just off the hume... Pick up only
ive got a engine crane so if you bring a trailer i put it in the trailer for you!
if you want any other engine related peices just ask as you can have anything that goes with it ie radiator, thermal taps etc
so give me a call on
0423-017-619 (Gordon)
the heat wrap got a little soaked in power steering fluid which i would reccomend washing it before you run it but yeah
soo now pics
cheers, man the reason for the sale is as stated earlier, the car was written off after it fell off a trailer
this was with the old motor
YouTube - VN Calais Turbo
so yeah, this is also going on ebay so if you want it for this price better get on the phone asap :P
ive got a guy comming to look at it tommorrowif your intrested speak now or forever hold your peace
Sold!!!!!!!!!!!!!!
