Hey guys,
Time to clear the shed and get some money together to build the new engine for the vn, so heres some stuff up for sale.
Gen 3 items,
Gen 3 engine, 2002 build done under 30,000kms, comes with: Long motor, injection manifold, throttle body, Auto Flexplate, Balancer, water pump, exhaust manifolds, coil packs, has crank and camshaft and knock sensors, VGC excellent running engine, had as spare but need to offload, $3000
Gen 3 engine, 2001 build done 10,000kms, Long motor, fully rebuilt with mahle pistons, arp rodbolts, all new gaskets, Crane 236/240, .600lift, 112 lobe centre, roll master double row timing chain, crow cams super duty pushrods, balancer, comp cams 918 valve springs, LS6 intake manifold, Throttle body and LS6 injectors, complete from rocker covers to sump, Has vt/x/y/z sump and pickup fitted, still sealed, no accessories, Has run 11.6 in a VN with 3 speed auto and 4200 convertor with 9" and 3.73 gears and made 265RWKW's with that combo. drop straight into any VT/X/Y. Still in vehicle can be heard running. and can be removed within a day if sold. $5000
Old style Chev engine items,
350 Chev, +.040 4 bolt mains, 11.5:1 pistons, Dart II 200cc Cylinder Heads, Roller rockers, solid cam, 7lt sump, Steel Balancer, Race flexplate, Starter motor, Single plain manifold, HEI distributer, water pump, good running engine, dyno time only, 385hp/385ft/lb $5000
350 Chev, +.030 4 bolt mains, 010 block, 1/2 grout filled, ROSS 13.5:1 pistons, H-Beam Rods, TR270 Camshaft, Off set lifters, Steel balancer, 7lt sump, Race flex plate, 3/4 engine, all fresh, $5000
Need to sell A.S.A.P
Message expired
