Well as i said, the vehicle is going to be now transformed into a tow car.
All proceeds will be going into the drag ute.
These are the following items up for sale.
Custom Twin Turbo Kit made 505rwkw@12 psi, kit will include the following.
Twin Garrett Roller bearing turbos, Twin External wastegates with screamer pipes, steam pipe manifolds, dump pipes, turbo blankets, speedflow fittings, oil supply, oil drain, coolant hoses and fittings. Air intakes with K&N air filters, extrusion intercooler and SFS silicoin hosing. $8000
For more information and/or pictures
TT VY LS1 475kw@12psi - Australian LS1 and Holden Forums
Forged LS1, sleeved block, Lunati rotating assembly, custom ground camshaft, crane double velve springs, 1.8 roller rockers, titanium retainers, double row timing chain, 8.6:1 comp ratio, ported cylinder heads, machining by Rhemac, engine built by B&V Autotechniques, $10,000
Dual Pump Fuel System,
Surge tank, aeromotive fuel rails, 60lb injectors, dual 044 pumps, adjustable rising rate regulator will support 1400hp $2,500
Complete package $18,000
For more information either send me a pm, or give me a call on (08)8250 2233
