Time to clean out the shed
x2 manual vn s1 v6 engines with flywheel $150 for the two
x1 vt motor all there mins heads $100
x1 full vt v6 engine wiring loom $50
x1 bt1 sump bash guard $20
x1 set of vy tail lights some small marks $50
x1 65mm v8 throttle body with all senors $50
x1 vn tow bar $10
x2 vn ecus v6 $20 each
x1 set of 5lt engine covers SOLD
x1 autometer 5inc tacho sports comp (I think a solder is dry and will need to be checked as did not read ever now and then but wiring to coil was dickie so may be problem ) SOLD
x1 autometer oil pressure gauge mechanical 2 5/8 sports comp SOLD
x1 autometer water temp electric 2 5/8 sprts comp SOLD
x1 5ltr power streeing pump and bracket good nick $60
x1 5ltr sump and oil pick up $40
x1 vr ecu, bcm and key $50
x1 vn trailer wiring loom gmh plug in brand new $30
x1 5ltr timing cover very good no rust $30
x1 set of vq statesman hub caps x4 $20
x1 s5ltr standard heads with rockers and push rods good nic SOLD
x1 set of vn to vr front super low king springs SOLD
x1 vr ss steering wheel $30
x2 vn to vs peadel box to suit manual $60 each
x1 brand new (worn three times) pair of alpinestars tec 6 moto x boots size 11 cost $ 650 sell $350
x1 custom made vn kick panels with JBL silts in them ( they are very heavy so the must be good ones i not in to stereo stuff) SOLD
x1 v6 air box and tubing $10
x1 set of vq statesman fog light grills white $20
x1 vr mirror switch $10
x1 pro lift moto x stand use very little cost $140 sell $80
x1 steel harmonic balancer ( after market) to suit 5ltr very good nick but has surface rust on chrome $40
x1 set of 5ltr rocker covers painted red $50
heaps more will post as i find in the shed
I am intrested in
x1 s5ltr standard heads with rockers and push rods good nic $100
is that for the pair and what would postage be to vic 3630 (roughly)
also would it be possible to get a look at the valves rough idea on kms or was the motor on gas
thanks
email kody20k@hotmail.com
Can u put pic up of the harmonic balancer?
how much for all that stuff dude?
where abouts is pick up from
Interested in these
x1 vn ecu v6 $20
what can u do that for??
if u can do all 3 for $40 + post ill take em seeing as ur gonna throw em out
Email me PREDATR@GMAIL.COM
