Results 1 to 15 of 15
Thread: Ls2 6.0 Ltr V8 Engine
    Hoppy is offline
    Sep 2005
    Default Ls2 6.0 Ltr V8 Engine
    ITEM:
    LS2 6.0 LTR V8 ENGINE
    AS USED IN THE VZ SERIES COMMODORES
    CONDITION:
    THIS ENGINE IS A BRAND NEW CRATE ENGINE AND COMES COMPLETE WITH :
    INLET & EXHAUST MANIFOLDS
    FUEL RAIL & INECTORS
    COILS, LEADS & PLUGS
    WATER PUMP & FLEX PLATE
    ELECTRONIC THROTTLE BODY
    SALE IS FOR THE ENGINE ONLY
    DOES NOT INCLUDE ENGINE HARNESS, STARTER MOTOR OR ALTERNATOR
    REASON FOR SELLING:
    Not Needed
    PRICE AND PRICE CONDITIONS:
    $6600
    EXTRA INFO:
    BUYER WILL HAVE TO PAY FREIGHT, I CAN ORGANISE FREIGHT, OR YOU CAN
    GERALDTON WA
    CONTACT:
    EMAIL TO michael@hopkinson.com.au
    PICTURES:
    VS_STATO_CAPRICE
    Jan 2008
    Hey there just wonderin if the wiring harness in a vy with ls1 has the same wiring loom as the 6ltr's?
    Sep 2005
    Not sure, probably not, the 6lt has a drive by wire throttle body, but you could change that. and some LS2's have the 54 tooth reluctors on the crank.
    Hoppy
    Sep 2005
    more info for you
    Can't use LS1 computer must use E30 due to different crank/cam reluctor setup. Can't (to my knowledge) use a cable with the E38 ecu, may be possible but would depend if there is a model using that ecu and operating system that has a cable to use as a tune start point, would require modified operating system and retuning if possible. Can use LS1 ecu if change reluctor on crank and cam gear. Will also need to change injector plugs on loom.
    I use EFI Live and regularly check Holden Crazy which is the tune file repository and have not seen a cable tune for the E38, there maybe a US model, sometimes the trucks ran cables later than the cars, perhaps an LQ9 operating system if one exists less fly by wire and retuned to suit.
    Hoppy
    minux's Avatar
    minux is offline Infidel Bear
    300rwkw FG G6ET/2011 Sti Spec R Hatch
    Mini Putt 2 Champion!
    Feb 2005
    Is this actually an LS2 or is just a Gen 4 L76?
    "Be who you are and say what you feel, because those who mind don't matter and those who matter don't mind."
    - Theodor Seuss Geisel
    Sep 2005
    Well it seems I've been jipped, I was told this motor was an LS2, I have not had it out of the box till today and it seems I have an L76 not an LS2. Sorry for the claim that it was an LS2.
    Hoppy
    Vs stato international 5lt
    Sep 2007
    Ballarat
    Sep 2005
    Quote Originally Posted by DumpedVT View Post
    so how much are you after for it now being an l76?
    I'd say $5500, Bargain
    Hoppy
    minux's Avatar
    Feb 2005
    Have someone who may be interested, but $5500 is quite high. Would you take 4?
    Can pick up LS2 crates now for $4500.
    Sep 2005
    Quote Originally Posted by minux View Post
    Where can you buy an LS2 crate motor for $4500??,
    If you have someone interested for $4000, do you think they would be better spending $500 more and getting the LS2??
    Hoppy
    minux's Avatar
    Feb 2005
    Quote Originally Posted by Hoppy View Post
    Hoppy
    Nah, the L76 can be made better than the LS2
    VZ 6.0LT LS2 HSV CRATE MOTOR
    WHII Statesman
    Sep 2006
    Geelong, VIC
    Does this have a 24x or 58x reluctor wheel? You can confirm by checking the colour of the crank angle sensor behind the starter motor. Black = 24, Grey = 58.
    Sep 2005
    Sep 2005
    TRUBL1 is offline Banned
    VX SS 5.7 M6
    Oct 2007
    Actually you can run a LS2 with an LS1 computer and loom. All Panels and Parts in adelaide are using these in a conversion kit they have designed for retrofiiting LS2's into any commodore of any age. Due to the cost of buying brand new computers for LS2's and the like to run them they modified the LS1 loom and retuned the computer to run quite well, and these cars are passing a roadworthy no worries.
    Unsure if they would sell these seperatly or not as they were keepin how they were doin it pretty quiet for a while.
    And you do have to change the drive by wire to a cable which is any easy change.
  1. VN Engine - Signs of failed engine valves
    By nolim8ts in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 30-04-2007, 07:15 PM
  2. engine light, engine cut out
    By VN-88 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 30-03-2007, 12:10 AM
  3. Engine + engine bay colours?
    By traindriver in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 04-05-2006, 02:06 PM
  4. ALOT of engine movment... not broken engine mounts
    By commy92 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 26-04-2006, 10:14 AM
  5. Engine stalls and engine light comes on.
    By tysons_2001 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 01-03-2006, 08:01 PM
