Results 1 to 4 of 4
Thread: FS: Lightning Audio B300.2 Amplifier! 300watt RMS!
    1991_Vn2nV's Avatar
    91 VN Berlina & 03 VY Berlina
    Mar 2006
    Gumeracha, Adelaide Hills
    Exclamation FS: Lightning Audio B300.2 Amplifier! 300watt RMS!
    ITEM: Lightning Audio B300.2 2 channel Amplifier. 300watt RMS.
    CONDITION: Used but in as new condition
    PRICE: $100 ono
    DELIVERY/PICK UP INFORMATION: Pick up or buyer to pay postage.
    PAYMENT OPTIONS: Cash or direct deposit or Paypal.
    CONTACT DETAILS: Through here or to holden_vn2nv@hotmail.com
    OTHER INFO:
    The Bolt B300.2 amplifier by Lightning Audio is designed for serious performance, driving your tunes powerfully and with precision. The "Juice Boost" (12 dB bass boost at 50 Hz) lets you pump up some thump, while built-in variable crossovers maximize your system's overall performance by sending the right frequencies to the right speakers.
    Lightning Audio also includes speaker-level inputs on each Bolt amplifier, so you'll be able to hook it up to any factory or aftermarket system. Best of all, Bolt amps are affordable, so you can supercharge your system without having to take out a major loan to do it!
    Details:
    stereo or bridged mono output
    Tri-way capable (Tri-Way Crossover required)
    300 watts x 1 in bridged mode
    100 watts x 2 into 4 ohms
    150 watts x 2 into 2 ohms
    requires 8-gauge power and ground leads — wiring and hardware not included with amplifier
    preamp outputs
    selectable 40-400 Hz variable high-pass/low-pass crossover, 12 dB/octave
    11-7/8"W x 2-1/4"H x 11-1/8"D
    1991_Vn2nV's Avatar
    Mar 2006
    Features
    Internal Crossover: The internal 12dB/octave crossover may be set for high-pass, full range, or low-pass operation. The crossover frequency is variable from 40Hz to 400Hz.
    Juice Boost: The amplifier includes a control that allows you to boost bass from 0 to +12dB, centered at 50Hz.
    RCA Preamp Outputs: The gold-plated preamp output jacks provide a convenient source for daisy-chaining an additional amplifier without running an extra set of RCA cables from the front of the vehicle to the amplifier location. The pass-thru jacks output a full-range signal.
    Controls
    Left Side of Amplifier:
    Juice Boost Switch: allows you to select 0dB or +12dB
    Filter Switch: allows you to select high-pass, flat (full range), or low-pass crossover operation
    Crossover Frequency Control: the crossover frequency control is variable from 40Hz to 400Hz
    Gain Control: a rotary control that allows you to adjust the speaker output level
    Inputs and Outputs
    RCA Input: gold-plated RCA jacks
    RCA Output: gold-plated RCA jacks
    Speaker-level Input: 5-pin jack for use with supplied wiring harness
    Right Side of Amplifier:
    Speakers: gold-plated screw terminals; each terminal is 0.319" wide
    +12V: 0.487" wide gold-plated screw terminal
    REM: 0.351" wide gold-plated screw terminal
    GND: 0.487" wide gold-plated screw terminal
    Fuses: two ATC 20-amp blade fuses
    '97 VS II Statesman 5.0L 5-Speed
    Feb 2006
    Radelaide
    1991_Vn2nV's Avatar
    Mar 2006
    SOLD
  1. F/S Kicker 12 inch Sub. 300watt rms. Cheap in SA.
    By fnlow1 in forum Parts And Other Items For Sale
    Last Post: 22-10-2007, 08:09 PM
  2. FS: 18" RJR Lightning Mags, no tyres VIC
    By hakhawk in forum Parts And Other Items For Sale
    Last Post: 14-02-2007, 05:03 PM
  3. FS:West Coast Custom By Orion & Directed Audio WCC-6004 4CH Amplifier
    By ruredi in forum Parts And Other Items For Sale
    Last Post: 19-05-2006, 03:42 PM
  4. FS:West Coast Custom By Orion & Directed Audio WCC-5001 Mono Amplifier
    Last Post: 14-05-2006, 10:11 AM
