i have a borg warner T5 manual conversion, customised to suit a VT-VY V6 commodore.
includes
-T5 manual gear box, with custom cross member
-new RPM heavduty organic clutch (less than 200kms use)
-8 bolt flywheel, machined less than 200kms ago
-clutch cable
-custom made tailshaft to suit vt-VY
-custom modified clutch pedal box, to suit vt-VY
-brand new throw out bearing
-brass spigot bush
pick up from SE melb, may arrange delivery for a fee.
$1500
(edit, sorry i ment 8 bolt flywheel)
Dan
has this been in a car working? if so is there anything else that might be needed?
why on earth would you put a cable manual in a car that runs a hydrolic manual
Because the Getrag box that VT-VX use are a POS!
yes it has been running in my car, . but due to the balance in the L67 needing a heavier flywheel i couldnt eliminate a vibration. a heavier flywheel would of sloved the problem.
if you wanted to fit this to an L67 (supercharged V6) you would need a new flywheel
only thing not included is the kit is interior shifter boot.
cheeter, i used a cable clutch because the T5 belhousing uses a cable clutch, and i used the T5 because as blown v6 hatch has already eluded to, the getrag boxes are **** and expensive.
T5's are stronger and cheaper.
Dan
forgot to mention, also has the manual starter motor in the kit
ahh yer true ey
Does this need an engine loom and memcal for the conversion to a VX? Also where abouts in SE suburbs are you located?
are you selling the parts seperate or want them all gone in 1 go
sold. .
Mods please close.
Dan
