Results 1 to 2 of 2
Thread: F/S: HSV 330mm & 315mm Big Brake Conversion Kit
    g00gz's Avatar
    g00gz is offline
    '08 Accord Euro
    Feb 2006
    Exclamation F/S: HSV 330mm & 315mm Big Brake Conversion Kit
    Removed from a VT Series 2 Clubsport
    330mm rotors up front, still mounted on Hubs (both used but still in good condition). Come with Brand new - Never fitted - PBR Calipers with brand new pads and brake hoses.
    Both the calipers are LH ones, but they are both mounted to the hubs / rotors and the only difference I was able to see was that on the RH hub, the LH calipers brake bleeding valve & brake hose should be in opposite positions. However I cant see this being an issue as the brake hose still mounts fine to the strut tower bracket, and is still long enough to join to the metal brake line that goes to the ABS unit.
    Also includes rear 315mm rotors (HSV stamped) and calipers (the calipers were removed from a VX SS)
    $550 or best offer
    Located in Salisbury North S.A. or can post Australia wide at buyers expense
    0412 - 313 - 084
    91 VN SS 355
    Feb 2005
    WEST SUBS
    got pics is the hubs to suit vn?
    Cheers.
    * RVN 355 *
  1. VL -> VLT Brake Conversion
    By jetspin_vn in forum Holden Commodore How-To's
    Last Post: 13-10-2010, 01:04 AM
  2. 330mm hsv rotors, cross slotted fronts and rears
    By crashy13 in forum Parts And Other Items For Sale
    Last Post: 23-01-2008, 06:28 PM
  3. VT brake conversion into VR acclaim.
    By cruzn in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 26-09-2007, 12:29 AM
  4. Vs - Vt Brake Conversion
    By djmcl3 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-03-2004, 09:58 AM
