ITEM: Raptor v, brackets, belt and pulley to fit vn-vr v6 commodore, 450x300 intercooler with custom 3 inch aluminium piping, correct heat range spark plugs, high flow injectors (440cc), longer ignition leads as you have to relocate coil pack, 2 bar map sensor, haltech e6gmx, speco boost gauge, k&N pod filter. With this kit on my car i made 244 rwhp (304fwhp) at 7.5psi making 1050ftp of torque at the wheels. (325ftp fw) In killowatts thats about 183rwkw (226fwkw).
This kit was put on in April this year so only 5 months old.
Important notes:
The ecu is tuned for a manual vr (will not fit an auto vr, auto or manual vn vp is fine). If you are not putting this kit on a manual vr, it will need a retune. I am no expert on this but even if your car is a manual vr it still may need a retue as our engines may be worn differently....( any info on this would be appreciated)
Also you will need to cut a little bit out of the back or your front bumper to fit the cooler.
CONDITION: Used - 5 MONTHS OLD
PRICE: $4500 firm
DELIVERY/PICK UP INFORMATION: Pickup or delivery at buyers expense
PAYMENT OPTIONS: COD, Direct Deposit,
CONTACT DETAILS: PM
PICTURES: i will be adding pictures tomorrow
also forgot to mention comes with malpassi rising rate fuel pressure regulator and bosch bypass valve
dyno figure
