hi guys I have for sale a level 3 instrument cluster upgrade to suit a VS Commodore approx 240,000 on the clock and comes complete with patch loom( you need one of these to get the LCD screens working) and the trip computer.....this is the triple screen LCD, and the mode button replaces the speed alert....face is painted in gold......everything is there waiting for the conversion to be done....$100 the lot PM me or 0423 980 683...Andy
Also have the following...
1/. brand new belt pulley tensioner $40.00
2/.set of VT wing mirrors few scratches plugs have been cut for electrics but enough wire to put back on $20 the pair
3/. 1 x chemically cleaned throttle body standard 68mm $20.00
4/. pod filter setup consisting of pod filter reducers, piping, ribbed flexible hose and pipe sealing ring...$20.00 the lot.
5/.pair of VT factory side skirts burgundy no cracks need a clean $15.00 the pair
6/.VT commodore instrument cluster unsure if working good for someone wanting to fiddle $5.00
7/.set of 3 Vs door trims(drivers side front was cracked) good condition, no speaker pods...good for someone who wants to experiment with fibreglass...$15.00 the lot.
8/.1 x VS Acclaim sedan rear 3 piece seat, no rips, tears or burns, could do with a clean $15.00
9/.1 x 3.8 litre V6 engine cover, needs sanding back and painting great for someone wanting to try mods etc $5.00
10/. 1 x set of 4 VT executive door trims need a clean but door cards and armrest material is great no rips or tears $30.00 the set of 4(again great for someone wanting to attempt fibreglassing.)
postage:will post at buyers expense Australia wide.
(will not post door trims side skirts or seats just too expensive so local pickup only on these)
Contact:PM me or 0423 980 683...Andy
My Computer beat me at Chess....But it didnt win at Kick Boxing.
That level 3 cluster off a 6 or an 8? Ta.
ill take the cluster and patch loom man pm me and ill transfer money asap!
IF SHE PLAYS STARFISH ILL PLAY SELFISH
I thought the TB came in 60mm, 65mm, or 70mm sizes...never heard of 68mm? Is it standard or been bored out? What do u think postage will be to 3844?
no 68mm is standard m8 postage would be $8.00 via express post...Andy
ECOTEC (Emissions & Consumption Optimisation TEChnology) V6
'V' configuration. Cold air intake. OHV design with cross flow cylinder heads. Sequential fuel injection. High energy distributorless, ignition. Twin knock-control sensors. Computer diagnostics. Electric cooling fan. Stainless steel exhaust. Triple Coils. Cross-bolted main bearings. 4 bolt.
Cylinders: 90-degree V6
Capacity: 3.791L
Bore x Stroke (mm): 97 x 86
Induction: Electronic sequential fuel injection.
Valvetrain: Overhead valves, pushrods, 2 valves / cylinder.
Throttle body diameter: 68mm
Compression ratio: 9.4 : 1
Maximum power: 152 kW @ 5200 rpm
Maximum torque: 305 Nm @ 3600 rpm
Redline / Cutout: 5600 / 5900 rpm
Recommended Fuel: 91 Octane (ULP)
mmmm......must be an ecotec thing.....I'm sure mine is 60 or 65mm, but mine is a series 1 engine.....would a ecotec engine TB fit ok on the VN S1 engine?
No sorry bud, will fit ecotec engines only....you can go up to a VR throttle body only....Andy
no worries..thanks anyway Andy
Still got the L3 Custer an loom PM me IF u DO need one ASAP
Cluster is sold !!!
