Results 1 to 16 of 16
Thread: Fs: Lumpy ecotech cam
    taztassio is offline
    VY S L67
    Nov 2007
    Default Fs: Lumpy ecotech cam
    Hey,
    I have a BRAND NEW BILLET CAM TECH cam, specs as shown:
    Advertised duration: 290in/290ex
    duration at 0.050": 229in/229ex
    Lift at Cam: 332"in/332"out
    LSA: 110
    intake centreline: 108
    For stock heads this will need modified retainers, as its about 532" lift in and out.
    Located glenwaverley, will post.
    $550 no lower
    (cost of grinding this custom cam was $550, and the cost of the billet ontop was more).
    This will idle rough, and produce some mean top end power.
    Bagged vs caprice sII
    Sep 2007
    Newcastle
    H1GHROLLR's Avatar
    H1GHROLLR is offline CHEMICALLY SUPERCHARGED
    VX CLUBSPORT R8 LS1
    Feb 2009
    ROCKINGHAM,PERTH
    VP Executive R-spec
    Jan 2005
    In a ls1 maybe.... but that's getting right up there for the V6's it would be VERY grumpy at idle
    VY SII HBD Calais L67
    Dec 2006
    Quote Originally Posted by DARTYVXCLUBBY View Post
    thats not a very lumpy cam the LSA:110 is very very tame
    Yeah the LSA is 110 but did you check the duration? 230? Great top end from this thing if it's tuned right
    VYII Calais L67
    VY S L67
    Nov 2007
    ahah this is NOT a tamed ecotech cam.
    call camtech yourself. this is a CUSTOM GRIND, for 3-5000 rpm, rough idle. its all written on teh card.
    you can do the cam yourself, but it would be in the range of $400-$800 to get installed.
    This will produce some MEAN power for someone serious about their ecotec.
    to give you an idea, stage 3 intense cam has specs as follows
    CAM-363 - INTENSE™ Stage 3 Normally Aspirated Cam, duration @ .050": 222º/230º, lobe lifts: .339"/.331", valve lifts with 1.60:1 rocker arms: .542"/.529", lobe separation angle: 110º, intake centerline: 106º
    This cam as MORE intake duration, and very similar lift
    here is a vid of a STAGE 2 in a car in the US with a reasonable size exhaust
    http://www.intense-racing.com/video/WesCamMov.mpg
    delcowizzid's Avatar
    в∞ѕтεכ √&
    Jul 2008
    NZ
    the ramp rate of the lobes has a lot too do with it to and just looking at that cam sitting there it has a fast ramp rate be nice and choppy i bet. very nice looking new billit too
    VY S L67
    Nov 2007
    delcowizzid hit the nail on the head.
    this is why i posted a picture, so people SERIOUS about ecotec power will get a good idea
    Sep 2007
    Newcastle
    do you have a vid or sound clip of when it was in and what kind of kw increase does this give you?
    cheers
    vs III commodore ute
    Sep 2008
    i would totaly buy this but ive already put 1.95 rockers on sounds sick tho
    My CaR dOsNt ChErP gEaRs, It JuSt KiCkS sIdEwAyS!
    custom vk Calais
    Jan 2009
    so if i got this cam,what would i need to do to my ecotech to get it running right.like what needs upgrading ?and what do you think it will set me back ? very interested
    Pub247's Avatar
    Pub247 is offline Donating Member
    92 VP wagon Daily
    Apr 2006
    Melbourne S.E.
    you need it installed and tune cost would be around 1500 for installation and tune. probably new valve springs and performance or new lifters wouldnt go astray either. Looks like a decent cam
    Quote Originally Posted by Smidy
    How many kw would i need to beat vin diesil to the train lines?
    VY S L67
    Nov 2007
    cam is BRAND NEW never installed.
    stock lifters are hydraulic roller, so they will be fine, just setting up the preload on them will be your concern.
    i would run MINIMUM 105# valve springs, and you will need either VITON valve seals or MODIFIED retainers to allow for the increased lift (seals are about $30 from states, and retainers are about $70).
    this will produce great power, and is probably the biggest you can run on stock heads. i am not going to claim a KW increase as there are so many variables.
    also, pushrods will be needed.
    on 1.6 rockers you will have 532" lift in/ex. max the heads allow is 520". so modified retainers give you 30" more clearence, and the viton seals give you 20". thus either/or will be under 520" and allow you to run the cam.
    also suggested a double row timing chain if you run more than 105".
    also, rockers can be sold straight up for a good price, this will give you MORE of a power increase than rockers. as not only is the lift more than 1.95's, the duration is what gets the power. (how long the valves are open).
    this is an absolute steal for someone wanting a great cam. the billet+delivery etc add a couple of hundred onto the cost of the grind ($550) and im prepared to wear the cost of that.
    With rudds money coming in for most of you, put it to a needy cause, your car
    VY S L67
    Nov 2007
    Quote Originally Posted by mking View Post
    cheers
    check the video.
    this will be choppier than that as the vid link is a stage 2 intense, and this is atleast as choppy as the stage 3
  15. #15
    в∞ѕтεכ √&
    Jul 2008
    NZ
    gotta love a nice choppy idle like in that vid
  16. #16
    VY S L67
    Nov 2007
    yeah its pretty aggressive.
    At the stage the cam is SOLD.
  1. Lumpy Cam
    By Jecs in forum V6 Development And Modification
    Last Post: 10-10-2010, 12:30 AM
  2. getting lumpy
    By blaze in forum V8 Development and Modification
    Last Post: 22-11-2009, 09:25 PM
  3. HELP pacemakers have made car run lumpy and backfire
    By erugby in forum V6 Development And Modification
    Last Post: 22-01-2008, 12:36 AM
  4. Rough Lumpy IDLE When Cold
    By phill025 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 07-12-2006, 12:36 PM
  5. lumpy gearbox
    By chevy_big_block_bro in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 18-03-2005, 11:03 PM
