FS: Memcal/Pushrods to suit VS Ecotec with Cam
Due to a cam swap gone wrong, I have left over parts from the swap that are no longer needed due to using a different cam with custom tune.
The parts up for sale are a ChipTorque HP4 chip to suit a VS Ecotec engine. Apparently the chip can be used on a few different cams, however it will not be a perfect tune, but will get the car running. I had a Surecam High Performance Street cam (218deg. dur@50thou, 450thou valve lift) with this cam and exhaust mods and made 141rwkw. It ran fine, idled well, and wasn't too bad on fuel. However as mentioned due to a lifter failure the cam was damaged, and I ended up getting a different cam so the chip is no longer needed.
Also for sale are a set of 7.100" chromoly race pushrods to suit the above cam. These pushrods are 50thou longer than standard as the cam I used was a regrind. These were only used for around 500kms.
So basically, all you would need for a cam swap for a VS Ecotec engine is a regrind High Performance Street cam from Surecam ($208 a year ago!) and the chip and pushrods I have, and there you go.
The chip costs $500 from Chiptorque, and the pushrods costs $170 from Performance Wholesale.
Would prefer to sell together for $500.
Either PM or call me on 0418 225 044 if interested. Can also provide dyno sheet for proof of power.
I'm also open to offers...
