Register - Members List - Calendar - Mark Forums Read -
Go Back   Just Commodores > Trading Post > Parts For Sale
Parts For Sale Got some odd car parts or other bits to get rid, they go in here.
Reply
LinkBack Thread Tools Display Modes
  #1
Old 04-02-2008, 09:44 AM
Ride: VSII L67 Statesman
Trade Rating: (0)
quiksilv3r Executive
Default Supercharged V6 Yella Terra Water-Air Intercooler + Billet Snout
Ok, Statesman is now written off and I didn't have a chance to install the cooler and snout. So here they are.
Yella Terra Water-to-Air Intercooler
Quote:
(From Yella Terra)
Yella Terra's Stage 2 water to air intercooler upgrade kit fits neatly between the factory supercharger and manifold and will reduce intake air temps by upto 57 degrees!! Upgrade for factory supercharged L67 Ecotec V6. Supplied with alloy fuel rails and polished front mounted heat exchanger.
Stealth fitment - factory look
Single pass core for ultimate in cooling
Easy fit system - installs in 5 hours
Ultra reliable High flow electric water pump
Allows increase in timing and boost pressure for more HP
Polished front mounted heat exchanger
Add Water Wetter (SC 1557) for increased cooling capacity
Recommended fitment with boost upgrade
No tuning issues - water to air = no problems!!
Quote:
(From Chipcontrol site)
Key Features:
Lowers intake temps by 60deg
Bolt on drivability (no tuning required)
Billet fuel rails supplied
Braided fuel lines
Substantial power and torque gains
The W2A "Stage 2" is probably the best modification that can be done to the L67. It is the second generation in water to air intercoolers.
This kit is a direct bolt on mounting between the supercharger and the intake manifold, cooling the discharge air by 60deg and allowing you to drive the supercharger harder and increase boost levels.
Unlike the Stage 1this kit is designed for show aswell a go, it features billet fuel rails and braided fuel lines and the supercharger will sit much higher in the engine bay but will still clear the bonnet. Drivability will remain the same unlike the stealth but tuning is recommended for maximum gains.
Porting of your supercharger and manifold is also recommended to get the most from your supercharger, we can CNC machine your manifold and supercharger to suit.
Comes with all parts, only removed from Courier's boxes to make sure everything is there. Adaptor plate still in plastic wrapping. Complete kit. Also included are a set of Billet Fuel Rails.
Yella Terra Billet Snout with all Accessories
Quote:
(From YT site)
Yella Terra is proud to offer a CNC machined billet supercharger drive extension and new front gear cover for your Supercharged V6. This brings with it the ability to change boost pressures by simply replacing the 'bolt on - bolt off' blower pulley. The kit comes with a new coupler to replace the prone to wearing factory part, high load bearings, the Yella terra modular pulley system that maintains factory belt, a new GM base gasket and specific gear oil for the supercharger. Supplied with detailed instructions, fitting takes approximately 2 hours and does not require ECU retuning below 11 psi of boost.
Increase power by 25%, torque by a massive 50%, more reliability and all for less than $900.00!!
Different pulley sizes in stock for custom boost/ECU applications.
Quote:
(From Chipcontrol Website)
Key Features:
Replacement Gearcase
New supercharger oil
New snout coupling
New supercharger gasket
Bigger snout bearings
Billet machined snout
Modular pulley system
The M90 modular pulley kit is a must for any enthusiest who wants to mod thier L67, it makes it quick and painless to change pulley sizes and its is ultra strong, much stronger than the standard snout.
Everything is included with the modular pulley kit to service your supercharger while it is off, you get a new supercharger > LIM gasket, new supercharger oil and a new snout coupling.
It is not just a power up modification but also a full service of your supercharger to ensure everything is maintained.
Extra pulleys are available in wide variety of sizes
Would rather sell both together as this is the perfect first round of mods you can do for the VS-VY Supercharged V6 motor. No tuning required (to make the most of the mods tuning is recommended, but factory tune is more than safe and sufficient to handle the upgrades).
RRP is ~$3900 for both of these.
They are brand new. I understand people wont pay full price as they could just buy new so I am chasing $3500 neg. for both.
Would rather not seperate, but if I can organise both to be sold (if you want the snout only I will wait until somebody wants the cooler before I split them).
Have a new car lined up and some extra cash wouldn't go astray to help fund the purchase.
Contact Michael 0413 241 973. Located Morayfield QLD 4506, also work in the City.
Digg this Post!Add Post to del.icio.usBookmark Post in TechnoratiFurl this Post!Google Bookmark this Post!Yahoo Bookmark this Post!Bookmark to AskJeeves!Bookmark to Slashdot!Live Bookmark this Post!Spurl this Post!Reddit! Wong this Post!
Sponsored Links
  #2
Old 24-02-2008, 10:18 PM
Trade Rating: (0)
New photos
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Thread Thread Starter Forum Replies Last Post
yella terra korny LS1/2 Development and Modification 24 22-01-2008 05:54 PM
Yella Terra Cai Charg'd Yella Terra 22 22-12-2007 07:53 AM
ecotec yella terra s/c kit blake0182 VT - VX Holden Commodore (1997 - 2002) 3 21-04-2007 09:27 PM
Yella Terra 1.7 RR for VR? Simdog VR - VS Holden Commodore (1993 - 1997) 5 15-08-2006 12:00 AM
Free Ringtones | Best Credit Cards | Credit Cards | Personal Loans | Compare | Car Reviews
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
