Results 1 to 5 of 5
Thread: Raptor Superchargers on a worked 93 vp3.8ltr
    06 VE SS
    May 2009
    Rockingham, WA
    Question Raptor Superchargers on a worked 93 vp3.8ltr
    g'day all,is it possible to fit a Raptor Supercharger Systems to worked 93 vp 3.8ltr motor here so info
    1 X FULLY RECONDITIONED LONG ENGINE .
    REBORED AND HONED TO PERFORMANCE TOLERANCES.
    CRANK GROUND AND LINISHED.BLOCK HOT TANKED,DECKED ,NEW WELSH PLUGS, BLUEPRINTED.
    HEADS FULLY RECONDITIONED ,NEW VALVES ,BRONZE GUIDES,3 ANGLE VALVE GRIND, BACK CUT VALVES,BOWL PORTED AND FLOWED.
    SUPPY AND FIT NEW CAM BEARINGS.
    1 X SET ACL PERFORMANCE PISTONS AND RINGS.9.5 :1 COMP
    1 X SET ACL MAIN AND CONROD BEARINGS.
    1 x Clive Roller 228 @50 Hydraulic Cam 3200 to 6700 rpm.
    1 X SET OF PERFORMANCE VALVE SPRINGS AND RETAINERS .
    2x Performance 70 mm throttle body c/o.
    1x Performance chip to suit cam listed c/o.
    1x Rollmaster Red timing chain and gears SINGLE ROW
    12 x Hydraulic lifters( NEW ! NOT RECO)
    1 x FULL GASKET SET
    1 X SET YELLA TERRA ROLLERS STD RATIO.
    1 X 3500 STALL CONVERTER TO SUIT T700.
    1 X TWIN THROTTLE BODY MANIFOLD
    6 x GROUP A INJECTORS CHEMICALLY CLEANED ETC
    only done 6,000kms
    immortality's Avatar
    VN3.8 5spd/VSII3.8/VH5.0
    Apr 2006
    Auckland NZ
    nice, but possibly not ideal for a supercharger. that cam wouldn't be blower friendly me thinks, probably has a lot of valve overlap (tight LSA).
    if you post up the rest of the CAM specs Tim will be able to give you a better idea of what will work.
    that CR is only .1 higher then the ecotecs so that should be fine
    Body by Holden, Soul by Brock
    the Legend will live forever
    vn calais, vs clubsport #137
    Jun 2005
    sounds like an SRE engine of ebay? pending on cam specs it should be fine mate. did you get a cam card with your engine?
    06 VE SS
    May 2009
    Rockingham, WA
    Raptorsc's Avatar
    Raptorsc is offline RAPTR6
    Hilux 4.0 V6 SC 320kw
    Jul 2006
    Mackay Qld Australia
    As mentioned we need the cam specs, apart from that its a good thing for boost.
    Raptor Superchargers - Boosting S1/S2 3800's, Ecotec's and Alloytec's
  1. Raptor Superchargers ....... worldwide
    By Raptorsc in forum Raptor Superchargers
    Last Post: 11-03-2012, 08:02 PM
  2. Raptor Superchargers Project Car VY
    Last Post: 28-06-2009, 09:26 PM
  3. Raptor Superchargers for ford?
    By SlipStream in forum Raptor Superchargers
    Last Post: 18-12-2008, 10:56 PM
  4. RAPTOR SUPERCHARGERS 304 5lt
    By olschoolvh in forum V8 Development and Modification
    Last Post: 13-09-2008, 01:22 PM
  5. raptor superchargers
    By super_6 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 03-10-2007, 12:38 PM
