Have been thinking about getting a supercharger for a while now and looking at a intercooler pipe work thinking i dont realy like all pipe work crossing back from one side to the other.
So without getting a reverse plenum could you run two smaller intercoolers ontop of each other so you could run in one side out the other then a U bend up to the other and then back out the otherside (the same side it came in at) and then back up to the throttle body?
The only thing i can see being a problem is the room for two pipes on the one side, any thoughts???
like this i guess
i thin you have to say good bye to your fog lights if you have any as it gets quite squishy on that side of the car, i really dont like both in and outlets out the same side, but intercooler manufacturers do make them...
there is a pic here:
VZ Alloytec Kit Development
and here:
Life starts at 200km/h
Your thought is on the right track... but in this situation you would genarally cut off the end tanks from the ends where your u-pipe was and weld on one single end tank from one intercooler to another.
Like this (except I forgot to include the end tanks on the rhs...)
Important to have you in/out pipes at the top and bottom...
Here's another pic which might explain better..
Would it be better or worse for flow?
.:Blown VT V6, DAJ37:.
it is a fairly sharp bend inside the end tank of the cooler which is quite restrictive in my opinion.
it has been done before:
Drive it
Like ya stole it!
All ideas are welcome, intercooling setup is critical to supercharged engine performance, great to see people giving it some serious thought
Raptor Superchargers - Boosting S1/S2 3800's, Ecotec's and Alloytec's
