Page 22 of 23 FirstFirst ... 12181920212223 LastLast
Results 526 to 550 of 558
Thread: Charge that VX
  1. #526
    MR_VX's Avatar
    MR_VX is offline Forced to be Fast
    VX S pac SII Raptorcharged
    Mar 2009
    Townsville, Qld
    Well i went to drive it today and it felt like some thing was loose so i took it home and jacked it up, I didn't fine any bolts or any thing loose, my rear left rotor was rubbing on the brake pad with ive fixed a little. but i did notice a fair bit of chunking when i was turning the tail shaft around is that normal?
    Check out my ride here >>>>My VX Raptor
    say NO to chev badges
    Wanted To Buy=>> Mace 12mm or 25mm Manifold spacers - VX SS Headlights - VY handbrake complete set up
    For Sale=>> vt/vx Berlina/Calais chrome window surround PM me for more details
  2. #527
    immortality's Avatar
    VN3.8 5spd/VSII3.8/VH5.0
    Apr 2006
    Auckland NZ
    Check the bearings in the rear wheel hub.
    Body by Holden, Soul by Brock
    the Legend will live forever
  3. #528
    MR_VX's Avatar
    Mar 2009
    Townsville, Qld
    yeah ill have a look. it seems to be getting louder. its like a rubbing sounds. its real noticeable when turn full lock left and right.
  4. #529
    MR_VX's Avatar
    Mar 2009
    Townsville, Qld
    Ok this is a stupid question but i know F-all about BOV's, I've got 2 x 32mm one's. there's a allan key/nut on the middle top side of them and they are set a 2 different settings by the looks of it. one is screwed in more then the other. What happens when they are screwed into to far or out to far??? I have no idea where they should be adjusted to.
  5. #530
    Raptor Charged VX's Avatar
    Raptor Charged VX is offline Turboed Ls1 FTW
    VY SS
    May 2009
    srew it in and it will make the action harder or stiffer, causing the valve to open later or only half way, srew it out and it will be softer and open sooner.
    set it to open soon as this is safer for the supercharger
    Current Ride:2003 Vy SS series2. Single mount T04Z and intercooled. 224 232 @590" Vcm Suite Cam, Crow Cam Valve Springs, Aftermarket Lifters, Ls1 Double row rollmaster timing chain. 3000rpm stall converter, 3:46 Diff Gears. Still being tuned!
    Previous Rides:97 VS Acclaim Stocker /02 VX S Pack 5sp, Raptor Charged Intercooled 307rwhp
  6. #531
    Raptorsc's Avatar
    Raptorsc is offline RAPTR6
    Hilux 4.0 V6 SC 320kw
    Jul 2006
    Mackay Qld Australia
    The purple one will be set correctly, the other one should be set similarly
    Raptor Superchargers - Boosting S1/S2 3800's, Ecotec's and Alloytec's
  7. #532
    MR_VX's Avatar
    Mar 2009
    Townsville, Qld
    Quote Originally Posted by Raptor Charged VX View Post
    Thanks iv'e screwed them out to about 9mm of thread showing. ( one was already set to that length )
    Quote Originally Posted by Raptorsc View Post
    Iv'e got 2 of your old blue tyre BOV's
  8. #533
    Raptorsc's Avatar
    Jul 2006
    Screw out too far and the screw falls out - they really need to be only in approx 3 turns
    Screw in too far and they wont open - causing big problems in many areas
  9. #534
    MR_VX's Avatar
    Mar 2009
    Townsville, Qld
    would a adjustable fuel pressure regualtor such as a malpassi help with a standard fuel system? would i gain any thing from doing so?
    or should i replace the fuel pump with a walbro?
  10. #535
    one_and_only2004's Avatar
    one_and_only2004 is offline Turbo L98 FTW
    Z Series Thunder Utility - Turbo
    Mar 2008
    Regional NSW Australia
    If you went adjustable FPR you probably need a retune as everything will be out of whack.
    VZ Thunder - 360RWKW Turbocharged V8 - Parts by AKO Performance Tuned by BPS
  11. #536
    MR_VX's Avatar
    Mar 2009
    Townsville, Qld
    Would I gain any from it tho?
    I'm also think of a cam and rocker kit any suggestion I've contacted Mace also
  12. #537
    Mar 2008
    Well I ran one of their stage 2 supercharged cams in mine, it seemed to work well but in all honesty i'd just get a set of 1.9 rockers if I did it again.
    At the moment fuel pressure on your rail doesn't rise with boost which means the tuner just opens up your injectors for longer and longer as the boost gets higher, a adjustable FPR raises fuel pressure by 1psi per 1psi of positive pressure - so you probably won't see any gains.
  13. #538
    MR_VX's Avatar
    Mar 2009
    Townsville, Qld
    I already have 1.9:1 rockers from FIT i got them a few years ago off ebay. Im pretty sure they are just the standard factory ones tho because i didnt notice any difference from them. nor can i tell for sure if they are FIT ones or not. If i got new ones id go with Yella Terra ones. Yella Terra - Part details
  14. #539
    Mar 2008
    yeah that's what i used to run, yella terra 1.8's.
    here's some 1.95's but if you send the guy a message he can get any ratio. YELLA TERRA ROLLER ROCKER HOLDEN 3.8L V6 1.95 Ratio
  15. #540
    MR_VX's Avatar
    Mar 2009
    Townsville, Qld
    only if you kept all ur goods from silver fox, I could have brought them lol
  16. #541
    Mar 2008
    Yeah, I sold my rockers to zeussy, and my whole intercooler kit to a fella named superchargedvys - which I'm still waiting for the final $150 after 12 months.
    ...don't deal with that guy.
  17. #542
    delcowizzid's Avatar
    в∞ѕтεכ √&
    Jul 2008
    NZ
    a stock fuel reg is fine and will rise 1 psi with every psi of boost.save your money for a power mod
  18. #543
    MR_VX's Avatar
    Mar 2009
    Townsville, Qld
    ok thanks fellas
  19. #544
    VX S Pack
    Mar 2012
    Hay
    Just curious how much car insurance is for a super changed vx s pack considering the kit for mine
    cheers
  20. #545
    richardpalinkas's Avatar
    richardpalinkas is offline Blown Alloytec
    Raptor Impulse VZ SV6
    May 2009
    Gold Coast
    Depending on your insurer, with nrma, it was not one cent more expensive, as long as its mod plated
    Spoken by a true member of The Committee
  21. #546
    impulsive's Avatar
    impulsive is offline Alloytec Racing
    VZ Alloytec
    Aug 2007
    Brisbane, QLD
    surely you guys do not pay $58 a month for insurance and $500 excess for a raptor VX/VZ
    Life starts at 200km/h
  22. #547
    Mar 2008
    Quote Originally Posted by impulsive View Post
    My raptor VY was about 90 a month from memory
  23. #548
    MR_VX's Avatar
    Mar 2009
    Townsville, Qld
    Im pretty sure mine was only like $25 extra a year with AAMI
  24. #549
    May 2009
    Gold Coast
    Yea nrma doesn't charge extra for the charger, although I raised the price of my car so my premium did go up, but I didn't have to
  25. #550
    MR_VX's Avatar
    Mar 2009
    Townsville, Qld
    Anyone know how to clean the o2 sensors safely? can i use carby cleaner and a old tooth brush ? Ive never replaced them before so i thought i should give them a clean.
  1. Super-charge?
    By LuvMyHolden13 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 19-01-2010, 02:04 AM
  2. will they charge me more for using this phone
    By pow3rslave in forum The LAN Lounge
    Last Post: 16-11-2009, 02:27 PM
  3. 253 charge light
    By Torquative in forum Electrical Wiring / Questions
    Last Post: 18-08-2009, 04:19 PM
  4. Losing charge?
    By Cobra Clutch in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 29-07-2009, 01:08 AM
  5. Does a VX Key Charge?
    By vxs3.8 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 18-05-2009, 04:26 PM
