Gday all, this is my Raptor VX s pac in the making, hope you like
Current Motor Mods:
Raptor V prostreet Supercharger kit
600x300x76 intercooler with 3inch pipe
OTR CAI
K&N pod filter
Mace 69mm Throtthle Body
Reversed Plenum
1.9:1's F.I.T Rockers
Exhaust System
Pacemaker Extractors
Single 2.5 Inch Lukey sports exhaust
2.5inch Hi-Flow cat
2.5inch Y piece
Interior
Getrag Billet shifter
VY SS sports pedals
VY gear knob
VY roof light console
Calais 3 window cluster with red facia
Calais interior light and country lights
Exterior
Genuine CV8Z Monaro tail lights
VT calais chrome boot strip
245-35-19 G2 10 spoke mags
VT Calais window chrome
Mods to do
MACE Pod filter box
Lowering -super low King springs all around
Satin chrome interior door handles - vents -Vy Handbrake cover
Blue LED interior conversion
Remove wing from boot
Install my 4x10in subs
Up grade window chrome to vx/vy Calais
Check out my ride here >>>>My VX Raptor
say NO to chev badges
Wanted To Buy=>> Mace 12mm or 25mm Manifold spacers - VX SS Headlights - VY handbrake complete set up
For Sale=>> vt/vx Berlina/Calais chrome window surround PM me for more details
Factory cat?????????
It is absolutely tragic, you would be unlikely to have any top end power with that there either, can kill power by at least 40rwkw ......everytime!!! That cat is a dog lol
Some of the muffs in that Lukey system may be a bit restrictive, dunno how you missed the cat warnings in the VS - VY thread.I also mentioned about exhaust being critical to V6 performance in the big Forced induction section for V6s in Street Comms mag last year too.
Do cat first, either go single 3" or twin 2.5 cats (1 per side)
You need to setup like my VY (see full thread on that) if you want same results. I used twin cats with VY HSV exhaust from cats back, that definitely works well.
I will repeat again here in this thread, ONLY the VY V6 series 2 has factory fited cats which are compatible for supercharging, all other models from VS - VY series 1 have the junk pancake cat (2 in 1 out). Pancake cat = high restriction
Once you get that all sorted, see how it feels, then we have the smaller pulley option that gives bottom end galore![]()
Raptor Superchargers - Boosting S1/S2 3800's, Ecotec's and Alloytec's
no worries thanks tim, ill check around Townsville for second hand vy exhaust. did it still have the nice note to it like my lukey????
Umm![]()
No, the car will end up near silent like stock but with very high flow. Your inside sound system will then work 100 x better too. Good for highway but would be too quiet for flogging around town to attract attention with da chix hahha
Yes, scouser it does apply to you
The cat is actually close to identical if I recall from VN to VY series 1. Applies to all with the 2-1 cat - its definitely BAD
Brands - Not certain, I was lucky having the series 2, factory twins were perfect![]()
so what high flow cats do you recommend????
Brands - Not certain, I was lucky having the series 2, factory twins were perfect[/QUOTE]
what the? you just told me my fatory cat was bad but you stuck with ur 2 factory cats please explain lol
tim,
Just wondering remember how i got the ONE BOV from you should a get another to replace the other one as well or will the bosch (intake side before AFM) on be fine to leave on?
MR VX your system should be fine with the big valve after the charger and one bosch valve before the TB, thats all i had and i was running 12 psi,
sweet thanks mate, im getting the big 32mm BOV fitted tomorrow
yeah they sound pretty sweet, and like i said they give you the abilty to run more boost and well we all love more boost
i pulled my dash out today and got the cluster out so i could get some LED's from Jaycar to do the conversion, they didnt have all the bulbs i needed, because i was gonna cheat and use the factory bulb holders, they had a few but they wouldnt fit back into the cluster, plus i pulled the headlight switch apart to get the bulb out, i didnt no there was 2 small ballbearing in it and i lost oneso im gonna send it all to ASR Audio and get the to do it!
sounds like a nightmare
yep sure was! ill just pay for it to be done!
i currently have a 2.5in exhaust and was quoted $1300 to get another 2.5 in next to the current one and 2 hi flow cats. to me its not worth doing for the extra what few rwkw's? might just stick to the single and get 1- hi flow cat! not sure on what brand tho.
Thats what I would do, get a decent cat into that single pipe its enough mostly. Twin 2.5" kills the low end, this has been reported by quite a lot of my customers who have tried it. I only used twin 2.25" which is the best all round
yea will do, hopefuly ill get a hi flow cat in the next 2 weeks! unless someone has a second hand one they wanna sell meas far as ive been told any brand will be fine.
well as an s pac with EF2 suspension i wanna lower it by about 2 inches. I THINK EF2 is factory 30mm's lower then standard plz correct me?????? so to lower it 2 inchs more i think i need the ultra low springs so i was thinking about buying this kit & get a 4 point camber kit! let me no what you think???????????
http://cgi.ebay.com.au/ws/eBayISAPI....=STRK:MEWAX:IT
ok mate, well if your VX is series 2 there is no point getting a 4 point camber kit, because your car will already have the toe adjustment, all commodores from VX series 2 have it factory,
and yes your right about the FE2, get your self a set of pedders touring springs and shocks, they drop it just right and is still a nice ride,
oh ok sweet thanks for that mate, is the factory fitted camber kit is as good as an after market ones?
yep does the same job
u still need to get a 2 point camber kit, to adjust camber, but ur car should already have adjustable toe
