When you either are thinking about getting into supercharging or you already have one sometimes some extra info is GOOD
In this thread ANYONE is welcome to post a weblink to helpful software/webpages to anything helpful regarding FI engine performance. This can be to webpages with dyno sims, air flow calcs, unit conversion etc you name it, anything useless I will weed out
Here is the first one, at this site you scroll until you come to "Turbo Calculator Horsepower and Airflow", to a data entry section, you only need to know ONE parameter and it does the rest for you.
I filled in the HP box with 630hp which is what our sponsored tractor pull engine makes on the dyno now - in turn it tells me supercharger is flowing 945 CFM, not bad when I only rate it at 750 CFM. So you can learn about the airflow of your motor if you know the power at the wheels or power measured someplace
Throttle Body Calculator airflow requirement calculator and some others of interest not only for forced induction weed away i just copied it from a thread i made elswhere with good sites
