Righto i asked Tim about intercooling my raptor using his kit, but he's been a bit quiet sooo...
I've started my own kit with a:
460mm x 300mm x 76mm 3" intercooler
HKS SSQV blow off valve + 3" adapter pipe
Now i'm wondering how many lengths of intercooler piping (plus bends and joiners) i'll be needing, so i'm hoping that someone else has fabricated their own kit and wouldn't mind helping me out?
all depends on how u wanna run ya pipes dude or if u wanna cut ya gaurds etc
also i dunno about your model but in my vs i had to move me air flow meter to. if ya in qld send me a pm and i got a mate that does pipe work for a good price.
hope this helps
if your in brisbane i can hellp ypu put,, and your bov i dont know if that kind will be able to be used,, u have to run two valves one either side of the cooler, and one has to be at least a 32mm one with a really soft spring presure of 2.5kg otherwise you will get compressor surge and break the charger.
Check out my ride here >>>>My VX Raptor
say NO to chev badges
Wanted To Buy=>> Mace 12mm or 25mm Manifold spacers - VX SS Headlights - VY handbrake complete set up
For Sale=>> vt/vx Berlina/Calais chrome window surround PM me for more details
Sounds like you are getting the right advice, sorry I didn't catch up here with info for you sooner. The second valve is most crucial IF you run the high boost pulley.
Raptor Superchargers - Boosting S1/S2 3800's, Ecotec's and Alloytec's
Hey tim, is there any drama if you run a BOV on each bend of the pipe coming off the cooler. So like if you look at the cooler, then work your way out where it wraps around to go back into the engine bay. Would this be a drama? Would it cause the boost guage to read wrong for being to far away?
.:Blown VT V6, DAJ37:.
I would recomend two valves on any cooler kit as the pipework gives compressor surge
yes both blow off valves on 9psi is needed
