Results 1 to 6 of 6
Thread: Problems whist installing.
    one_and_only2004's Avatar
    one_and_only2004 is offline Turbo L98 FTW
    Z Series Thunder Utility - Turbo
    Mar 2008
    Regional NSW Australia
    Default Problems whist installing.
    I've started fitting up the raptor and i've had a few problems.
    The intake temperature sensor doesn't fit in the hole in the intake piping - the hole is too big - am i doing something wrong?
    There are two nobby bits on the charger intake piping - one for the BOV and there's another one for a pipe that seems to go over somewhere near the throttle body. Currently i have a bung cover(was supplied with the kit) which is covering this and everything seems to work fine, but I've noticed on every under bonnet picture where there's a raptor They've got the pipe on it. I tried to see where it goes in the instructions but i can't work it out...
    Apart from that everything seems to be working fine - especially that CHARGER WHINE!!!
    VZ Thunder - 360RWKW Turbocharged V8 - Parts by AKO Performance Tuned by BPS
    acarmody is offline Donati..Whoa Green
    VX Berlina
    Apr 2007
    Have you tried giving Tim from Raptor a phone call? I'm sure they will be happy to help.
    Ronald Reagan (1986)
    Raptor Charged VX's Avatar
    Raptor Charged VX is offline Turboed Ls1 FTW
    VY SS
    May 2009
    there is a little hose under the plenum that faces back out to the charger thats were that has to go , i know in the instalation manual its in there
    Mar 2008
    Yeah i had another read yesterday and worked it out - Thanks.
    I'll give Tim a ring tomorrow about the temp sensor - i've rigged something up with the old temperature sensor and a bit of 100-mile-an-hour tape and it seems to be working well.
    VY SS
    May 2009
    Raptorsc's Avatar
    Raptorsc is offline RAPTR6
    Hilux 4.0 V6 SC 320kw
    Jul 2006
    Mackay Qld Australia
    Apologies for slow reply to your PM
    I have mistakenly added another temp sensor into you kit, use original sensor and clip, return other one to me if you like
    You may be missing the little alloy bracket to secure inlet pipe?
    Let me know
    Raptor Superchargers - Boosting S1/S2 3800's, Ecotec's and Alloytec's
  1. Need help! idle way too high, and many problems after installing twin throttle body
    By galeryz213 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 08-05-2011, 10:32 PM
  2. vr transmission installing problems
    By Zuicider in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-05-2011, 01:06 PM
  3. Signal Problems Aand LPG Problems
    By reyyan in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-03-2011, 08:33 AM
  4. Problems installing double din headunit in VU
    By JoffLane in forum Car Audio
    Last Post: 06-03-2008, 04:30 PM
  5. ignition problems or starting problems
    By Vs-AclaimII in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-10-2006, 04:55 PM
