Page 3 of 3 FirstFirst 123
Results 51 to 70 of 70
Thread: Intercooling
  1. #51
    Raptor Charged VX's Avatar
    Raptor Charged VX is offline Turboed Ls1 FTW
    VY SS
    May 2009
    drift it , that is correct , and also you cold air sensor before the TB and after the MAf
    Current Ride:2003 Vy SS series2. Single mount T04Z and intercooled. 224 232 @590" Vcm Suite Cam, Crow Cam Valve Springs, Aftermarket Lifters, Ls1 Double row rollmaster timing chain. 3000rpm stall converter, 3:46 Diff Gears. Still being tuned!
    Previous Rides:97 VS Acclaim Stocker /02 VX S Pack 5sp, Raptor Charged Intercooled 307rwhp
  2. #52
    03 vy calais L67
    Moto X Champion!
    Mar 2009
    Townsville, QLD
    well that would save alot of hastle when intercooling! i thought u'd need a totally new tune!
  3. #53
    impulsesv6's Avatar
    impulsesv6 is offline Alloytec Garage
    A quick Alloytec
    Dec 2006
    brisbane, QUEENSLAND
    finished my 2.5" hot pipe today...
    can definately notice the difference!
    boosts heaps quicker and no pressure drop going from 3" to 2.5"
  4. #54
    VY SS
    May 2009
    looks good bren , what boost reading are u getting at the manifold
  5. #55
    impulsesv6's Avatar
    A quick Alloytec
    Dec 2006
  6. #56
    vc commodore
    May 2008
    Quote Originally Posted by impulsesv6 View Post
    Hi mate, just curious why you went to a smaller pipe size for the hot pipe? Wouldn't the 3'' flow the hot air better? Thanks.
  7. #57
    VY SS
    May 2009
    ok my theory on smaller hot pipes. the size of the pipe should work just as good better being the same size outlet of the charger it will keep all the pressure up until it fills the tank on the hot side of the cooler , and as long as the cold pipe is the same size from the cooler to the TB its gonna hold the pressure.
  8. #58
    VY SS
    May 2009
    impulse , so your running the ten PSI puley?
  9. #59
    impulsesv6's Avatar
    A quick Alloytec
    Dec 2006
    wouldnt have a clue anymore what pulley, lol... 51mm i think...
    until i changed oil i never hit a definate 10psi... always 8-9psi...
    but before the 2.5" pipe 10psi... with the 2.5" pipe 10psi...
    have also heard the theory that the pipes from the cooler to the tb should ideally be the "same volume of the tb minus the area of the butterfly"...
    just like optimum exhaust systems velocity is where its at...
  10. #60
    vc commodore
    May 2008
    Ok so does this mean that 2.5'' from the charger to the cooler and 3'' from the cooler to the throttle body? Thanks.
  11. #61
    impulsesv6's Avatar
    A quick Alloytec
    Dec 2006
    Quote Originally Posted by vc81 View Post
    this is what i have on my car atm
  12. #62
    Raptorsc's Avatar
    Raptorsc is offline RAPTR6
    Hilux 4.0 V6 SC 320kw
    Jul 2006
    Mackay Qld Australia
    Alloytec 10psi should be 61mm pulley, same pulley on ECOTEC gives 12+
    Raptor Superchargers - Boosting S1/S2 3800's, Ecotec's and Alloytec's
  13. #63
    VZ SS COMMODORE
    Aug 2010
    QLD
    I can vouch for AKOs work. Top quality welds and the best flowing systems. Very happy with the exhaust systems that you did for me mate... Have recommended you to alot of blokes, keep up the good work champ
    Currently wrecking:
    - L67 VT Calais (all leather options / chrome) VT HSV MANTA 5.0L roller motor, L67 VT International II, V6 VX S-Pac II, VS SS II, VS Calais II, VT Wagon.
    PM me if you are chasing anything
  14. #64
    VY SS
    May 2009
    thanks for the kind words twalt
  15. #65
    Raptorsc's Avatar
    Jul 2006
    Recommended another Raptor owner to you today AKO
  16. #66
    VY SS
    May 2009
    Thanks tim putting jobs on hold to after powercruise ATM
  17. #67
    one_and_only2004's Avatar
    one_and_only2004 is offline Turbo L98 FTW
    Z Series Thunder Utility - Turbo
    Mar 2008
    Regional NSW Australia
  18. #68
    VY SS
    May 2009
    ETA you now know
  19. #69
    TI3VOM's Avatar
    TI3VOM is offline VT V6 wanting 300RWHP
    VT V6 Acclaime S1
    Feb 2009
    Somewhere
    Hey RCVX,
    I have a VT V6 that I've got a Powerdyne supercharger for, I already have a 450x300x75mm cooler with 3" inlets.
    I was wanting to know how much some intercooler piping would cost for this setup please?
    Glenn
    VT V6 fitted with DMS gold 40mm coilovers, Whiteline adjustable swaybars & strut brace, 330mm AP racing brakes, Rebuilt 3.45:1 LSD and a Powerdyne supercharger
    Check it out: http://forums.justcommodores.com.au/...-v6-racer.html
  20. #70
    VY SS
    May 2009
    Quote Originally Posted by TI3VOM View Post
    Hey RCVX,
    Glenn
    Glenn you should have a PM.
  1. [Ecotec] L67 Intercooling??
    By pedrotski in forum V6 Development And Modification
    Last Post: 27-04-2011, 05:52 PM
  2. Intercooling The raptor.
    By one_and_only2004 in forum Raptor Superchargers
    Last Post: 03-05-2010, 09:10 PM
  3. Intercooling SC14?
    By UNKNOWN in forum V6 Development And Modification
    Last Post: 05-02-2008, 06:35 AM
  4. intercooling crs kit
    By IBLOWN in forum V6 Development And Modification
    Last Post: 04-01-2006, 04:50 PM
