Hi,
if you have a raptor fitted V6 or some other brand of charger and need an intercooler kit, i can generally supply and fit a kit out of stainless for $1500 or less.
I can supply any size cooler, there is the option of the standard srew driven clamps or the heavy duty T-bolt S/S clamps , any colour silicone. I only use mandrel bends NO SILICONE bends for the best flow.
Tig welded construction and polishing is also available.
PM me for info.
Thanks
Trent
AKO Performance & Engineering
Current Ride:2003 Vy SS series2. Single mount T04Z and intercooled. 224 232 @590" Vcm Suite Cam, Crow Cam Valve Springs, Aftermarket Lifters, Ls1 Double row rollmaster timing chain. 3000rpm stall converter, 3:46 Diff Gears. Still being tuned!
Previous Rides:97 VS Acclaim Stocker /02 VX S Pack 5sp, Raptor Charged Intercooled 307rwhp
Nice business name!
Seriously Trent knows his stuff - everyone who's seen my kit has been blown away with the quality. Flows beautifully too - GIVE HIM YOUR MONEY.
Thanks Julian. Ever need help with anything else u have my number
Hi Trent, I been writting to you about intercooling my soon to be Raptor VS Ute
You best send me that quote. 400x300x76(core) intercooler would be good, give me a call so we can meet up for you to have a look and see if my dryer unit for the AC needs moving
Cheers mate you've been extremely helpful already
Check out my ride here >>>>My VX Raptor
say NO to chev badges
Wanted To Buy=>> Mace 12mm or 25mm Manifold spacers - VX SS Headlights - VY handbrake complete set up
For Sale=>> vt/vx Berlina/Calais chrome window surround PM me for more details
I will take some tomorrow with my good camera - all I have at the moment is phone pictures.
Intakes pipes can be done out of alloy now. I have an acdc tig now
ute looks good julian, love how the cooler tucks behind that front bar nicely... i will vouch for trent on his work, have been watching his welding for the last few months and he is becoming a master at it... also trent if u need a hand yell out mate
The work done by Raptor Charged VX is of the highest standard and will not void the warranty of any Raptor V supercharger
If you need ANYTHING intercooled, RCVX should be your first choice, the quality, price and understanding of airflow dynamics ensures you will be getting the best ........... period
Raptor Superchargers - Boosting S1/S2 3800's, Ecotec's and Alloytec's
In progress is a VS ute, we will be fitting a reverse plenum due to the tight space of the VS engine bay, but that comes with a win for less pipe and less bends again. all flowed through a 400x300 intercooler, big enough to do the job with out taking up to much room,
the ute is booked in early next month, then it will off to QR for some seriously boosted drifting the owner tells me.
IM intrested please email me thnaks
dtm11@bigpond.com
Email sent
pretty sure thats sposed to be plumbed into the intake pipe of the charger?
MY RIDE - BAGGED CAPRICE
http://forums.justcommodores.com.au/...s-caprice.html
Its ok to fit a small breather filter to it, ideally it should be connected to intake so the AFM can measure all air going into motor
No biggy tho
I was referring to the dogleg in the charge piping
We used part of another bend to make the pipe head in the right direction,, julian was worried about seeing welds so we left them there, it could have been ground back polished to appear as one piece,
I have come across some tight bends so the charger can remain in the original position now, so the pipe to the TB will be able to come along side the charger and sit more striaght.
Not a real problem in my case, I didn't want another nipply bit put on the piping, because metering won't be a problem soon as I'm going MAFless.
Something you might want to check on your future kits is that the breather hole on the raptor pro street intake pipe is drilled through, not just welded on. Mine wasn't.
got a recent report from julian that his cooler kit is reading 10psi with the 10psi pulley . pretty well no boost loss,
Is that reading at the manifold?
Has it been measured before the cooler?
yeah at the manifold as far as i know unless julian has changed it . i dont think he has measured it before the cooler, its only a 10 psi pulley so it produce much more than 10 on a good day
The quality cooler systems for the Raptor chargers are all in the hands of RCVX, none better anyplace
See if he can get zero loss on an LS1 Raptor system![]()
