Page 1 of 8 12345 ... LastLast
Results 1 to 25 of 182
Thread: Vy Ss raptor charged
    Raptor Charged VX's Avatar
    Raptor Charged VX is offline Turboed Ls1 FTW
    VY SS
    May 2009
    Post Vy Ss raptor charged
    Hey.
    The car is a 2003 vy Ss series. 2
    Auto
    2800rpm stall
    Boostvavle
    Diff
    3.46:1 LSD out of a Vz Ss ute
    Motor
    Stock internals.
    Mods so to be
    500hp walbro intank pump
    42psi injectors
    Ase header relocation kit
    Heavy duty crow cam valve springs
    Raptor v supercharger running 7 psi
    At the moment the car is marking 300 rwhp with 567nm of torque just. From a maffles tune and the current exhaust full stainless four into ones with a twin 2.5inch x force The car as ran a 13.1 @ 107mph on 18s
    The charger is not yet fitted but will hopefully be on in a week or so.
    There will be plenty of photos of the build up as the car has to be ready for power cruise
    Current Ride:2003 Vy SS series2. Single mount T04Z and intercooled. 224 232 @590" Vcm Suite Cam, Crow Cam Valve Springs, Aftermarket Lifters, Ls1 Double row rollmaster timing chain. 3000rpm stall converter, 3:46 Diff Gears. Still being tuned!
    Previous Rides:97 VS Acclaim Stocker /02 VX S Pack 5sp, Raptor Charged Intercooled 307rwhp
    wikky is offline ............
    VZ SSZ
    Mar 2008
    Here
    What's a baffles tune? The charger and other mods haven't really added much power (maybe 40-50rwhp? ) but picked up a bit of torque. Interesting.
    one_and_only2004's Avatar
    one_and_only2004 is offline Turbo L98 FTW
    Z Series Thunder Utility - Turbo
    Mar 2008
    Regional NSW Australia
    Quote Originally Posted by wikky View Post
    The charger hasn't been fitted yet, that power/torque figure was from the mafless tune and other bits.
    VZ Thunder - 360RWKW Turbocharged V8 - Parts by AKO Performance Tuned by BPS
    VY SS
    May 2009
    yes once the charger has been fitted ill be looking at a fair increase in power an torque
    VZ SSZ
    Mar 2008
    Here
    Quote Originally Posted by one_and_only2004 View Post
    My bad, I misread your post, thought the charger was already on. Be good to see how it all goes mate. Good stuff.
    VY SS
    May 2009
    Yeah I can't wait I'm hoping for around 450 hp at the Tyres on stock cam
    VY SS
    May 2009
    The SS is going again after 3 days of being to lazy to fill it back up with coolant .. the header relocation tank from ASE is very well worth its money and simple install, \
    car seems to run fine and not get hot,
    hopefully the charger will be on its way soon ..
    Mar 2008
    Very exciting stuff! do you have the charger yet?
    VY SS
    May 2009
    not yet julian, i think tim is a bit busy atm the moment will wait it out.
    Raptorsc's Avatar
    Raptorsc is offline RAPTR6
    Hilux 4.0 V6 SC 320kw
    Jul 2006
    Mackay Qld Australia
    Freaking terrific, exactly the thread we need going forward.
    Any better close up pics of the ASE relocator tank and words on whats involved in installing it would make a great little post as well since its a required part of the charger kit install.
    Will get the bracket drilled today and maybe start a new charger for this item as well, exciting unit really.
    RCVX - feel free to detail this whole deal as much as you like, this ground breaking for the wider community even tho we already have a kit or 2 floating around out there.
    For those wanting intercooler to suit the Raptor LS1 kit, be sure to ask RCVX for a quote, he will be the exclusive supplier of LS1 intercooler kits to match the Raptor charger for all Sth East Qld
    The ph pics are a great start but I might need some really clear ones, if you got a camera and can email good ones for threads, adds and install pics would be awesome
    Raptor Superchargers - Boosting S1/S2 3800's, Ecotec's and Alloytec's
    VY SS
    May 2009
    yeah sure thing tim, will get an album together and some more detailed pics..
    Raptorsc's Avatar
    Jul 2006
    Smile ASE Coolant reservior
    OK, here is the ASE header tank kit image to kick the show off
    Attached Images Attached Images
    VY SS
    May 2009
    fuel pump and injectors go in this weekend.. charger will be mounted and cooler will be plumbed up,
    Raptorsc's Avatar
    Jul 2006
    You should nearly have mail already -
  15. #15
    VZ SSZ
    Mar 2008
    Here
  16. #16
    VY SS
    May 2009
    im hoping for 300rwkw plus.. keeping in mind the motor is completey stock at the moment, valve springs will be the first internal mod, but being realistic this kit is gonna be the best bang for buck combo, really if you want a huge 600 hp monster you need to look into the bigger brands . but the simplicity of the install is just a winner.
  17. #17
    Raptorsc's Avatar
    Jul 2006
    The base kit with no intercooler gives (around 280rwkw potential) $3700
    The base kit with no intercooler but with injectors is $4200
    The intercooler kit is around $1400 (to be confirmed) (Potentially allowing 320rwkw)
    For around $5600 you can have an intercooled 7psi system - compare this with other centrifugal systems and see the value being put forward here
    Any LS1 Commodore owner wanting to run 9psi plus should consider a side mount Vortech or a valley mount Harrop, these are HEAPS more expensive but will easily work in the higher boost range. Anyone wanting 14psi plus should consider turbocharging only, something from ASE or the likes is good for this.
    The system is easy to install and easy to remove, minimal effort, all easy DIY. On a scale of difficulty to install the Raptor system would be 2/10, a valley mount charger would be 8/10 by comparison. A turbokit is often more difficult again and would require you to have a hoist to access the underside of the engine/car.
  18. #18
    VY SS
    May 2009
    OK its here
    a weekend of fun begins
  19. #19
    VZ SSZ
    Mar 2008
    Here
    They sound like a great entry level setup. Look forward to seeing the results and hearing some feedback once a few of these kits are installed. Nice work.
  20. #20
    Mar 2008
    This is starting to look very very interesting!!
    Is the Raptor V bigger in size than the Raptor R?
  21. #21
    VY SS
    May 2009
    that there is the raptor V the raptor R is bigger
  22. #22
    VY SS
    May 2009
    Every bit of the install will be photographed ! there pics show the ASE header relocation tank
  23. #23
    Raptorsc's Avatar
    Jul 2006
    One thing for sure the RCVX is in over drive right at this moment, pushing on like there is no tomorrow
    Metal being cut and shaped, pipe routing being planned, pics being taken & much much more
  24. #24
    VY SS
    May 2009
    Picked this up on the way home will be mounted tomorrow
  25. #25
    Raptorsc's Avatar
    Jul 2006
    SHINE - BLING - Cooled LS1
  1. Another Raptor Charged Vs
    By redvs2 in forum Raptor Superchargers
    Last Post: 22-05-2012, 07:49 AM
  2. raptor charged vy ute
    By psivyv6 in forum VY - VZ - WK - WL - V2
    Last Post: 29-03-2010, 02:29 PM
  3. Brads raptor charged vs
    By vs-6 in forum VR - VS
    Last Post: 16-11-2009, 05:07 PM
  4. raptor charged vy ute
    Last Post: 25-06-2009, 05:52 PM
  5. Raptor Charged Vu Ss
    By SICK SS in forum Raptor Superchargers
    Last Post: 04-04-2007, 05:57 PM
