Page 2 of 2 FirstFirst 12
Results 26 to 40 of 40
Thread: Krackatinnee, Raptor Intercooled VS, reverse plenum
  1. #26
    Raptorsc's Avatar
    Raptorsc is offline RAPTR6
    Hilux 4.0 V6 SC 320kw
    Jul 2006
    Mackay Qld Australia
    Decent bud, much appreciated, you gotta get your start someplace
    Raptor Superchargers - Boosting S1/S2 3800's, Ecotec's and Alloytec's
  2. #27
    VS Ute
    Apr 2009
    Newest vid - so much more to do and so little money.
    YouTube - Learning to drift my blown VS Ute 3800 pt 3 - first time with chase camera.mpg
    Attached Images Attached Images
    CIRCLE WORK IS A DRIFTERS RITE OF PASSAGE
  3. #28
    vs exec
    Jun 2008
  4. #29
    VS Ute
    Apr 2009
    Not yet? Been building engine and had some drama's so shelved since June. 1/4 mile in the next two months will hopefully post a good time
  5. #30
    Raptorsc's Avatar
    Jul 2006
    Nice low key answer
  6. #31
    VS Ute
    Apr 2009
    Krackatinnee has had a makeover
    List of car mods to come
  7. #32
    one_and_only2004's Avatar
    one_and_only2004 is offline Turbo L98 FTW
    Z Series Thunder Utility - Turbo
    Mar 2008
    Regional NSW Australia
  8. #33
    Raptorsc's Avatar
    Jul 2006
    He has it as well, the first copy I recieved has the torque line, this is the first time I have seen the boost line
  9. #34
    VS Ute
    Apr 2009
    Dyno 2.jpgSure did
  10. #35
    VS Ute
    Apr 2009
    Krackatinnee's mod list
    2000 VS Ute
    Diff 2 way LSD out of R31, with 4.11's
    Trans 6 spd Tremec with custom super close gears - Mal Wood
    SC Raptor with 12 psi pulley
    Intercooled custom by AKO (akoperformance.com)
    3 inch stainless with 520 x 300mm(? have to check) FMIC
    Note- AKO and I installed reverse plenum, 69mm mace TB and re-wired harness to suit MAF/cold air/TB sensors (Thanks mate)
    Fuel system 500 hp Walbro FP, Alloy rails suplied by AKO
    Engine Built by PEACH - Full internal balance, fly and clutch zeroed, High Si content pistons with 60 thou machined off top land and 8 thou extra ring gap over stock, stock block, Rollmaster DRTC, balance shaft removed, XP hot cam, Stock heads
    stock rockers, zzperformance rods, 105 pound springs and mod retainers, 82 degree therm, thanks to Chris from SRE for all his advice
    Tune Chiptorque - Nerang
    Exhaust Pacemaker headers, 2.15 collection into 3 inch cat, 2.75 inch cat back exhaust mandrel bends - Price Right
    Suspension FE2 - soon to be coilovers front and custom springs rear, whiteline adjustable sway bars and tower brace,K-mac adjustable struts
    Misc dual core radiator
  11. #36
    Raptor Charged VX's Avatar
    Raptor Charged VX is offline Turboed Ls1 FTW
    VY SS
    May 2009
    Looking good Dave. Must be a drift machine now
    Current Ride:2003 Vy SS series2. Single mount T04Z and intercooled. 224 232 @590" Vcm Suite Cam, Crow Cam Valve Springs, Aftermarket Lifters, Ls1 Double row rollmaster timing chain. 3000rpm stall converter, 3:46 Diff Gears. Still being tuned!
    Previous Rides:97 VS Acclaim Stocker /02 VX S Pack 5sp, Raptor Charged Intercooled 307rwhp
  12. #37
    vs exec
    Jun 2008
    just wondering mate if i may ask how much your engine work set you back? also what handbrake are you using in the drift videos? or is it flick out and power? I dont know much about propper drift but looks good mate
  13. #38
    VS Ute
    Apr 2009
    Quote Originally Posted by redvs2 View Post
    Bout 5k, internal balance was exxy, but I will re- use crank ,everything else is new, bearings,seals, etc . Standard handbrake with bendix heavy duty pads a lot of the time I power in to corners with a Scando flick and clutch pop at 120km/ h
  14. #39
    Raptorsc's Avatar
    Jul 2006
    Lighting up and 120, pretty cool then
  15. #40
    VS Ute
    Apr 2009
    [QUOTE=Raptorsc;2119115]Lighting up and 120, pretty cool then[/QUOTE
    Yeah but after initiating you gotta catch the slide, scrub some speed off then power on. With the getrag this required me to down shift to second, hoping t56, will allow me to stay in 3rd,buy the time you hit apex doing bout 80 km/h, still learning to steer myself. Really want some more bum in sit time. Def quick though, look forward to 1/4 mile ( need to set up catch can).i certainly need to stiffen the ol girl up some more.
  1. Raptor V vs Raptor V Hybrid
    By apoc585 in forum Raptor Superchargers
    Last Post: 18-11-2010, 07:12 PM
  2. Vz Intercooled kit for EOI
    By jaisvz in forum Raptor Superchargers
    Last Post: 17-05-2010, 02:18 PM
  3. Reverse lights not working on reverse
    By macca_223 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 01-01-2010, 11:02 PM
  4. intercooled vx
    By daz08 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 17-03-2006, 10:31 PM
  5. intercooled vx
    Last Post: 07-03-2006, 01:18 PM
