Page 4 of 5 FirstFirst 12345 LastLast
Results 76 to 100 of 124
Like Tree6Likes
Thread: Raptor New Products thread
  1. #76
    Raptorsc's Avatar
    Raptorsc is offline RAPTR6
    Hilux 4.0 V6 SC 320kw
    Jul 2006
    Mackay Qld Australia
    EDIT- my bad just re-read the boost levels with the clutched pulley
    Yes thats close enough to it. Because we dont offer an intercooled system for the VS it would mean if clutch pulley was used then the boost is TOO high for a non intercooled setup. Its only safe to use if intercooler is in the equation
    Raptor Superchargers - Boosting S1/S2 3800's, Ecotec's and Alloytec's
  2. #77
    VS V6 Ute Series 3 S Pack Getrag
    Feb 2011
    Sutherland Shire
    I was thinking along those lines. I dont plan to run the charger without an intercooler from the start. Is the pulley expensive to upgrade?
  3. #78
    Raptorsc's Avatar
    Jul 2006
    The clutch pulley arrangement is a few bux for sure $220
  4. #79
    Feb 2011
    Sutherland Shire
    Not too bad considering you can spend more on a night out. Itching to get my kit. What sort of time frame is expected from purchase to delivery to Sydney, if you dont mind asking?
  5. #80
    Raptorsc's Avatar
    Jul 2006
    DPR
    You need to let me know a couple of weeks in advance, this allows me to get it ready on time for you. Postage time is around 4 days
  6. #81
    Feb 2011
    Sutherland Shire
    Mar 2008
    Quote Originally Posted by Raptorsc View Post
    NEWS for 2012 Raptor Products for Holden/GM vehicles
    Add -The Holden Rodeo/Colorado Supercharger system - Intercooled only
    Add - The New Cooling fans for ALL Raptor V superchargers
    Add - All Raptor V superchargers produced for 2012 will not be lower spec than V - L. Previously V was the first model, but the success of V L means we no longer should continue with standard V
    Add - 32mm BOV system for all NON intercooled Ecotec kits (customers report these are a LOT better than the 25mm)
    Add - Clutched supercharger drive for all intercooled ECOTEC VT - VY kits , slightly higher than 11 - 12 psi boost
    Delete - VN - VS 304 supercharger kit from Raptor Product range
    Considerations - Water to air intercooler system for ECOTEC engines VT - VY. This would be a better thing alround but needing a vehicle to work on and the time to do it.
    Wildcards - Hopefully the Staged Ecotec system gets running on the road this year
    Give me a month or 2 to build up the fun coupons Tim and I'll be up for this with the clutched drive.
  8. #83
    Raptorsc's Avatar
    Jul 2006
    A new product upgrade has come to mind. Will work on it over the next week or so and test to be sure it delivers the benefits I am hoping for
    It will be an even higher flow cooling fan unit, staged unit - the more cooling air the better
  9. #84
    one_and_only2004's Avatar
    one_and_only2004 is offline Turbo L98 FTW
    Z Series Thunder Utility - Turbo
    Mar 2008
    Regional NSW Australia
    Have you ever thought about water cooling? Little radiator, small pump and a sealed gearbox is all you'd need.
    VZ Thunder - 360RWKW Turbocharged V8 - Parts by AKO Performance Tuned by BPS
  10. #85
    Raptorsc's Avatar
    Jul 2006
    Cool Raptor VLC
    O&O
    We have been producing a watercooled version for a while now. I did feature it here somewhere, nevermind I will include another image of it here.
    You can see the water jacket and where the water fittings screw in. I guess I have produced 4 or so on the last couple of months and another one for customer in Norway last week.
    I am absolutely itching to get one on my Hilux ASAP
    Attached Images Attached Images
  11. #86
    Mar 2008
    That looks VERY tidy - I reckon it might increase the loss through the gearbox (through the friction of water) but it'd increase the reliability/durability 5x easy.
    There's so many options with these things!
  12. #87
    Raptorsc's Avatar
    Jul 2006
    O&O
    The water actually goes around the outside of the gearbox in a jacket, that is the raised ridge you can see there. Inside is sealed but still only air around the drive mechanism.
  13. #88
    Mar 2008
    Very good idea Tim - you've put a lot of thought into this for sure.
  14. #89
    VT
    Apr 2005
    QLD
    Just do it then!
    But we know the 'itching' is a typical 'Mackay' thing
  15. #90
    Raptorsc's Avatar
    Jul 2006
    Cool New Raptor RACE Cooling fan - Staged
    Today I made a little experiment to see if we can FURTHER punch more air through the charger trans for MORE cooling - this is always a good thing
    So here we are
    Factory specs of fan: Static pressure: 1.00 (Inch - H2O)
    The Raptor test unit specs for 1 fan: 25mm H20 (water gauge) (= 1 inch app) Same result as factory spec sheet. A good start!
    Staged Test unit specs: Static pressure: 46mm H20 (water gauge) - 88% increase
    That is around 88% PRESSURE INCREASE
    The increase which is going to equate to something similar in flow through the 19mm feed hose. The volume of the fans is fan in excess of what you can flow through the hose however increasing pressure means we can get a LOT more through the hose.
    Since I haven't ever seen a relatively compact 12V fan with around 46mm of Watergauge pressure yet it means we will make our own using this staged arrangement. As you can now see staging is highly effective for big pressure increases - this is the same staging theory on the Compound Supercharger setup in our other thread here. Feed one unit into the next - easy as!
    So for those in HOT climates or are pretty abusive on your Raptor - this is the system for you - get the heat out of your charger.
    I now have to create a product that does the same as the test rig in the pics but is a ready to install item
    I will call it the Race series Cooling fan - this is the performance needed for max cooling.
  16. #91
    Raptorsc's Avatar
    Jul 2006
    Quote Originally Posted by VT-565 View Post
    Just do it then!
    Lol
    It will always be my car that is last to get mods!
  17. #92
    richardpalinkas's Avatar
    richardpalinkas is offline Blown Alloytec
    Raptor Impulse VZ SV6
    May 2009
    Gold Coast
    Is it possible to stage the old and new fans together? Seeing as I have both present?
    Spoken by a true member of The Committee
  18. #93
    Raptorsc's Avatar
    Jul 2006
    Default Staged
    Rich
    The answer is no
    You can only stage the drum type fans such as the one you just bought
    In theory you can stage an axial fan such as the old one, I have tried in the past, the motor fails very fast and the pressure gain is pretty ordinary too
    The way I have shown is the only strategy and materials combo that's got the numbers on the water gauge to make a big cooling difference
  19. #94
    Raptorsc's Avatar
    Jul 2006
    The following link will take you to new product - this is NOT a Raptor product but it a VERY useful thing if you are thinking of intercooling your V6
    First I know of this was a Facebook notice .........
    Anymore tricks up your sleeve RCVX?
    VT-VX Ecotec Reverse Plenum
  20. #95
    Raptor Charged VX's Avatar
    Raptor Charged VX is offline Turboed Ls1 FTW
    VY SS
    May 2009
    There is a little bit going on at the moment, you will see a whole range of NEW items for sale, The aim is to provide products and services if required.
    Current Ride:2003 Vy SS series2. Single mount T04Z and intercooled. 224 232 @590" Vcm Suite Cam, Crow Cam Valve Springs, Aftermarket Lifters, Ls1 Double row rollmaster timing chain. 3000rpm stall converter, 3:46 Diff Gears. Still being tuned!
    Previous Rides:97 VS Acclaim Stocker /02 VX S Pack 5sp, Raptor Charged Intercooled 307rwhp
  21. #96
    Raptorsc's Avatar
    Jul 2006
    A slight slight change to our website overnight
    You may need to tap your f5 button if you still see same old front page
    And, not its not my car lol, customers car from California - Lexus IS300
  22. #97
    VC SL/E A3300 ,Looking for a VL
    Mar 2011
    armadale Perth, Australia
    they must love you're products to do that
    Black_Stig
    If Cars could scream Rape, I'm sure yours just did because I just eye fuc&ed the shit out of the above images.
    MY 1980 VC SL/E Exhaust Note
  23. #98
    VZ S Ute Supercharged
    Jun 2011
    Hey Tim is the 14psi pulley still available for the V - L? If so, how much? and what tools would i need to change it over? I've got the Alloytec from Sydney you mentioned earlier in this thread. Ive had the V-L on for 9 months now and done about 14000kms and its still going strong. I'm keen to see what it really can do at its maximum safe boost. After reading this thread i will be getting one of those cooling fans from Jaycar first!
  24. #99
    Mar 2008
    14psi is pretty high- you'll probably have to drop your limiter a bit to keep the thing in one piece.
  25. #100
    immortality's Avatar
    VN3.8 5spd/VSII3.8/VH5.0
    Apr 2006
    Auckland NZ
    Hi Tim,
    Great to see a ever increasing range of products/upgrades.
    Just thinking, would these improved cooling upgrades increase the maximum rpm's of the Raptor charger? Also can the customer install the water cooled gearbox housing themselves or does the charger need to be returned to you?
    Bart
    Body by Holden, Soul by Brock
    the Legend will live forever
  1. Raptor V vs Raptor V Hybrid
    By apoc585 in forum Raptor Superchargers
    Last Post: 18-11-2010, 07:12 PM
  2. NEW Products!
    By MACE in forum Mace Engineering
    Last Post: 08-11-2010, 12:14 PM
  3. ICE products
    By tommyjustme in forum Car Care Products
    Last Post: 27-04-2010, 07:03 PM
