Results 1 to 4 of 4
Thread: Vz bov
    Black VZ SV6
    Dec 2005
    Default Vz bov
    What is the ideal location for the BOV on the vz cooler piping?
    At the moment mine is on the lower bend of the cold pipe that goes around the rad support.
    BUT... this is a really crappy spot for it as there is really no room for it there, I was wondering whether it can go high up near the compressor on the hot pipe safely?
    Drive it
    Like ya stole it!
    Raptor Charged VX's Avatar
    Raptor Charged VX is offline Turboed Ls1 FTW
    VY SS
    May 2009
    you should have two BOVS if its cooled, one should be on the hot side after the chager around 6-10 inches from outlet and the other anywhere you want after the cooler using two will stop compressor surge and elimante damage to the charger
    Current Ride:2003 Vy SS series2. Single mount T04Z and intercooled. 224 232 @590" Vcm Suite Cam, Crow Cam Valve Springs, Aftermarket Lifters, Ls1 Double row rollmaster timing chain. 3000rpm stall converter, 3:46 Diff Gears. Still being tuned!
    Previous Rides:97 VS Acclaim Stocker /02 VX S Pack 5sp, Raptor Charged Intercooled 307rwhp
    car
    Aug 2010
    one_and_only2004's Avatar
    one_and_only2004 is offline Turbo L98 FTW
    Z Series Thunder Utility - Turbo
    Mar 2008
    Regional NSW Australia
    I'm running the standard bosch one on the cool side, and a 32mm HKS SSQV on the hot side just near the outlet of the charger - works well.
    VZ Thunder - 360RWKW Turbocharged V8 - Parts by AKO Performance Tuned by BPS
