Hey guys, got a Vz ute 6am manual just thinking about supercharging it not sure i really want the turbo, has anyone had experience with them or any suggestions, cheers
V6 or v8. Raptor v is a good unit
Current Ride:2003 Vy SS series2. Single mount T04Z and intercooled. 224 232 @590" Vcm Suite Cam, Crow Cam Valve Springs, Aftermarket Lifters, Ls1 Double row rollmaster timing chain. 3000rpm stall converter, 3:46 Diff Gears. Still being tuned!
Previous Rides:97 VS Acclaim Stocker /02 VX S Pack 5sp, Raptor Charged Intercooled 307rwhp
How much did it set you back ?
with a cam and all the extras i have put on it i would say around $7500.
you would have to check with raptor and see if the kit suits VZ
The VZ typically requires a change of the power steering pump - then the VT - VY kit will bolt right on
This is typical for most side mount chargers for the VZ, you need to change the PS pump
Raptor Superchargers - Boosting S1/S2 3800's, Ecotec's and Alloytec's
Remember this kit isnt something you can upgrade
You bolt on and enjoy up to 7psi depending on engine mods
Its all about the budget
