Results 1 to 22 of 22
Thread: Raptor my vx just a few questions ???
    87LAG's Avatar
    87LAG is offline BOOSTED 6 FTW
    VX S S2 AUTO RAPTORCHARGED
    Apr 2010
    THE SWITCH
    Question Raptor my vx just a few questions ???
    Hey all and to raptor,
    I am looking to raptor my 2002 vx v6 s auto very soon but just have a few questions... if any 1 can help?
    My main question is that with a vx i have been told that u can not change the memcal so how do u get around the computer??? is it a full computer swap and then ge it security linked with a tech2 or wat is the go?
    The other one is wat sort of boost would i be running with a motor that has high ratio rockers and full extractors with 2.5" exhaust?
    If any1 with a vx/vy that has raptored there car there knowledge about the computer setup would be great as to how it all goes and runs.
    any help appreciated, cheers 87LAG
    Raptorsc's Avatar
    Raptorsc is offline RAPTR6
    Hilux 4.0 V6 SC 320kw
    Jul 2006
    Mackay Qld Australia
    Hi
    Apologies, I did see your PM
    OK to nail your questions
    1. How to change the tune..... Yes it can be changed, so far I know we are the only company offering this service as part of the complete kit price. Our tuning supplier unsolders the main memory chip then installs a new socket into which a replaceable chip can be installed - which has the Raptor tune burnt into it. This is all included in the kit price
    2. The kit for that model is standard at 10psi and is compatible with high lift rockers, high flow exhausts and most other small bolt ons without need to change tune.
    The entire kit/tuning was developed on our own VY Commodore.
    As always make sure to give the car a couple of pulls on the Dyno and make sure car runs safely
    Raptor Superchargers - Boosting S1/S2 3800's, Ecotec's and Alloytec's
    87LAG's Avatar
    Apr 2010
    THE SWITCH
    cool cool that makes good sense now. am definitely getin keen for just after chrissy. The only other question is that do i send u the computer?? or send it to the tuner?? and wat is the turn around time????
    sorry for stupid questions just wanna have all bases coovered ie how long with no car while the computer is being sorted....
    cheers
    Raptor Charged VX's Avatar
    Raptor Charged VX is offline Turboed Ls1 FTW
    VY SS
    May 2009
    pretty sure you send it straight to chip torque and the turn around can be as little as three days with express post
    Current Ride:2003 Vy SS series2. Single mount T04Z and intercooled. 224 232 @590" Vcm Suite Cam, Crow Cam Valve Springs, Aftermarket Lifters, Ls1 Double row rollmaster timing chain. 3000rpm stall converter, 3:46 Diff Gears. Still being tuned!
    Previous Rides:97 VS Acclaim Stocker /02 VX S Pack 5sp, Raptor Charged Intercooled 307rwhp
    Raptorsc's Avatar
    Jul 2006
    As above
    You unclip and unplug the ECU, send it via express post to Chiptorque, they do the work - we pay the bill, they send it back to you either via express post or TNT overnight air freight
    You plug ECU back into car, clip into cradle and providing everything under the bonnet is correct the vehicle is more or less ready to GO
    87LAG's Avatar
    Apr 2010
    THE SWITCH
    sounds good fellas definitely be expecting a call just after christmas from me to organise a stage 1 kit once again thanx heaps to all for the help and info...
    cheers 87LAG
    VY 3.8
    Nov 2010
    Maroochydore
    How much PSI can a stock ecotec handle without too much chance of letting go?
    Raptorsc's Avatar
    Jul 2006
    There is a lot of opinion on a matter like this
    If you are buying a product from Raptor - we suggest 12psi should be where you pull up
    If you are buying a product from a turbo kit manufacturer they will say up to 17psi
    Both are right however the safety margin for tuning, bad fuel and abuse of the engine @ 17psi is ZERO
    We say 12psi for 2 reasons, its the max recommended pressure from the supercharger and its a point at which you can provide a decent tune that will cover most eventuality's
    87LAG's Avatar
    Apr 2010
    THE SWITCH
    tim mate if u wouldn mind pm me a price for everything to do a stsage 1 kit that would be great cheers
    Raptorsc's Avatar
    Jul 2006
    PM Sent
    Was away for a couple of days
    308 vc
    Dec 2010
    North east Adelaide
    "1. How to change the tune..... Yes it can be changed, so far I know we are the only company offering this service as part of the complete kit price. Our tuning supplier unsolders the main memory chip then installs a new socket into which a replaceable chip can be installed - which has the Raptor tune burnt into it. This is all included in the kit price"
    so you in effect convert the vx flash ecu to a memcal ecu like a vt? or have i misread?
    VY SS
    May 2009
    No they put in a chip the same as the Vx one one but it's removable so it can be taken out and reflashed. But it's not a Memcal
    308 vc
    Dec 2010
    North east Adelaide
    VY SS
    May 2009
    no dramas at all
  15. #15
    Raptorsc's Avatar
    Jul 2006
    Default Pictures of the replaceable chip
    Here is how the beastie looks, this is bit that contains the tune calibration.
    This was taken a long time ago but they are still identical as is the tune
    Attached Images Attached Images
  16. #16
    87LAG's Avatar
    Apr 2010
    THE SWITCH
    well looks like its happening should all be here friday 11th march . . . computer, injectors, lim gaskets, plenum spacer and manifold insulator 12mm, 2 1/4 twin cat-twin exhaust and plugs are all in and car runs wickedly good and more responsive already.....
    cant wait
    will post up my success.
  17. #17
    Raptorsc's Avatar
    Jul 2006
    Aye,
    Up an running
  18. #18
    87LAG's Avatar
    Apr 2010
    THE SWITCH
    Up and running and love it my afm has packed it in and pings at full throttle but will be sorted today
    2nd gear limiter bash here i come . . . : )
  19. #19
    vs caprice 5.0
    Aug 2010
    broadmeadows
    87LAG's Avatar
    Apr 2010
    THE SWITCH
  21. #21
    87LAG's Avatar
    Apr 2010
    THE SWITCH
    Little issue i have ..... The air intake runs right down near / rests on the exhaust / extractors and from wat i can work out would get very bloody hot
    any on done anything different
    help would be appreciated
    cheers
  22. #22
    Raptorsc's Avatar
    Jul 2006
    Lag
    Trim your silicon at the blower and at the the other end and you will raise that U shaped piece to be higher, you can then position it also more towards the guard and gain a larger air gap.
    A bread knife cuts silicon real easy, especially if you use some washing up detergent as a cutting lubricant
  1. Welcome to Raptor
    By Raptorsc in forum Raptor Superchargers
    Last Post: 23-01-2012, 08:46 PM
  2. Raptor V vs Raptor V Hybrid
    By apoc585 in forum Raptor Superchargers
    Last Post: 18-11-2010, 07:12 PM
  3. vz sv6 raptor kit!
    By wish_i_had_an_8 in forum Raptor Superchargers
    Last Post: 21-09-2010, 11:46 PM
