I think lately I've been quicker haha. Let the Killa wasps do the talking haha
this wednesday? ive got my money on josh, even more money that you both blow up and have to get towed home
Life starts at 200km/h
i bet my car wont make it this wednesday haha, just a guess lol
Nah not this Wednesday! No money! And it's wet! Sometime mid to late feb. I have no money. And already have the qsc cruise this weekend and powerplay in a few weeks
Just "joshin" you guys...
maybe when its not so slippery?
I like this car very much. good to see more people boosting the 6 bangers.
vp 3.8 lt lowered T70 turbo 38 mm wastegate running 14 psi making 253 rear wheel kw lsd 3.08 gears. tuned by delcowizard
completely understand where you are coming from.. personally no, i have never supercharged an alloytec.. but offline, i have seen 2 versions of supercharged alloytecs, both N/A and blown.. Overall rich's car looks nice and has good power gains over a standard alloytec.. lets just leave it at that
nah wasnt me, your thinking of impulsesv6, a very good mate of mine
Ah dammit, I thought it was you - my bad.
Rich, next time you go on the dyno or drags let me know.. you can bolt on my ported manifold and TB if you want, see how it goes...
Cheers for liking the car haha, try to keep it in as good nick as I possibly can.
Dave, would be good to try it, still wanting to test other things too, but let's get a time of my car as it stands now, considering last time I went things did not go to plan at all. Car definately runs better than it did last time. Won't go into detail though.
yeah, you should do a bit of work to the cooler pipes, we can spend a weekend cleaning them up if you want. Are they rough as guts on the inside. im sure that won't be helping at all
Looking forward to the weather clearing up, will be good to finally get some times for 1/4. Hopefully performs as well on the track as it does on the street. Let's get a base time and build from there
New ECU? VIPEC 88?
MACE are doing tunes too now
Raptor Superchargers - Boosting S1/S2 3800's, Ecotec's and Alloytec's
Ha I wish, how much and are they able to run stand alone?
Rich
You got those fun coupons saved up for some MACE CAMS? Placed your tenative order yet hey??![]()
Wish that was the case haha. Exhaust first and see how it runs down willowbank
A thread clean up has been requested - request granted
Bit of an interesting one today, hung out with josh today, went to unlock the car and nothing. Went to unlock the car at the door using the key. Nothing, would not let me unlock it. Saw the dash display was cutting out and also saw the light switch was on the parkers. Turned out josh left my Parkers on which gave me a flat battery, which in turn would not let me even unlock the car. Moral of the story, vz will lock you out of the car if the battery is flat lol. Managed to get into the car by removing all my cooler pipes, run jumper leads under the car to the battery, which is mission enough, just to unlock it. Was definitely an experience I don't want to go through again lol
There's a option in the dash menu to turn the parkers + whatever else you leave on off after a while (I think 30 seconds or something). This little trick has flattened the battery in my hiace as I've gotten used to just leaving them on all the time...
Yea, I've seen that in the dash. I think if you put your lights on without turning the car on, it flips out and just leaves them on, normally they would turn off when I lock it, but will check the settings again to double check
