Adam
Mate tats screamingly awesome and I know what the stally would be doing
Also just sent you a semi urgent PM for some info![]()
Raptor Superchargers - Boosting S1/S2 3800's, Ecotec's, Alloytec's and 304's
Test and tune coming up too hey Adam and you got another VT manual with a Raptor ProStreet to keep you company there in Sarina![]()
HEY TIM
YEAH TEST AND TUNE NEXT FRIDAY GUNNA HAVE A CRACK SEE WHAT SHE WILL DO DON'T KNOW HOW IT WILL GO WITH STREETERS ON BUT YOU KNOW ME I'LL HAVE A GO ANYWAY WILL SEE IF I CAN CON COREY INTO HAVING A RUN IF I CAN GET IT OFF THE LINE HOPEFULLY SHOULD RUN A GOOD TIME.![]()
ADAM
Mate the temperature gradient is showing Friday night as the coolest night of the week, lets hope they are right![]()
Tim
Fingers Crossed A Couple Of Last Minute Adj Today And She Will Be All Ready Got A Nice Little Drum Of Airplane Fuel To Go In So It Should Breath Well And Burn Well. Will Let You Know How It Goes
Struth mateyou are out to assault the track hey
Airplane fuel, hope it runs well on that like not too rich etc
What a plan![]()
Body by Holden, Soul by Brock
the Legend will live forever
IMMORTALITY
YOU ARE ABSOLUTELY RIGHT AVGAS IS LEADED AND WILL KILL THE 02 SENSOR IF RUN ALL THE TIME HALF A DOZEN RUNS DOWN THE STRIP WILL BE FINE SMELLS GREAT WHEN IT BURNS TO AS YOU WOULD KNOW HAVING RUN IT BEFORE.
TIM
AN ASSULT IS WHAT IM GOING FOR ALTHOUGH I HAVE NO IDEA WHAT WILL HAPPEN MIGHT BE A FLOP YET HAVE NO IDEA IF SETUP IS EVEN NEARLY READY FOR THE TRACK YET HENCE THE TEST AND TUNE I KNOW IT HAS THE PUNCH BUT CAN I PUT IT DOWN TIME WILL TELL![]()
HEY ALL
DISMALL EFFORT FRIDAY NIGHT BLEW A TRANNY COOLER LINE ON THE WAY TO THE DRAGS AFTER FIXING THAT ON THE SIDE OF THE ROAD FINALLY MADE IT TO THE TRACK FIRST RUN A 14.82 WASN'T HAPPY CAR FELT REAL LOOSE ON TRACK AND DIDN'T FEEL LIKE IT WAS REALLY PUTTING THE POWER TO THE TRACK SECOND RUN 14.50 STILL NOT HAPPY THIRD RUN 14.00 AND UPON PULLING BACK INTO PITS A MATE TOLD ME I WAS ONLY SPINNING ONE WHEEL ON THE PAD I HAD A SNAPPED AXLE ALL NIGHT HENCE THE REASON IT DIDN'T FEEL RIGHT![]()
One wheelers![]()
She woulda been pulling to one side a bit with one wheel drive lol, would say it was just one of those days
I know for sure there is plenty in that machine and after having ridden in it I must say how ever you achieved a 14.00 with only one wheel connected beats me ...... TOP EFFORT![]()
Hey Tim Yeah She Did Have A Bit Of A Pull Exact Counts Were
R/t .625 Bit Slow There
60ft 2.19 Sec
330ft 5.943 Sec
660ft 9.039 Sec
1000ft 11.762 E/t 14.092 @96.89mph
hey tim
if you have a look on you tube under heading xd falcon ute v8 vs supercharged v6 commodore nothing exciting but there she is
Had a look bud, you need to rev er next time lolbut as you said you were testing the water so to speak and next time will bring on the animal for all its worth.
pm me adelaide SA 5039
PM sent for that VP kit
You just can't beat a nice VN hey. This one has been around a while now but going through a second update.
The engine update at present is getting big work on the heads, cam and supercharger pipework. It was always running 12psi boost and now the owner is increasing the boost to 14psi (via rev limit increase).
Should have some dyno charts through at the end of the month
hi Tim,
will your LS1 intakes fit onto the older buicks now that you have rotated the blower outlet down like on the ecotec kits?
cheers
Bart
hey could you pm me for price of stage 1 kit for a vn.
also, this might sound dumb, but do you guys make electric pulleys so i can run an on/off switch?
if you dont make electric pulleys, could i use one designed for an sc14?
only im on my P's, so i dont want to have it running all the time and get ****ed up by the cops.
cheers.
I will answer that one bud.
Unfortunately it is a different design so no clutch on the pulley that I know of. How long before you are off you P's? I am not wanting to put you off, cause these are a great charger, but they will attract the wrong attention as long as you have the additional red or green plates
If you do decide to run with one, you will have a heap of fun![]()
ah bugger.
oh well.
that wont put me off much.
il just have to look all innocent when they open the bonnet and explain that i know nothing about cars and that i thought it was just a pulley driven airbox.....
haha.
could i still get that pm about pricing and shipment to 3068 in vic please Raptorsc?
cheers.
This is a dreama post to a certain degree but I will put it up anyhow
My pipework supplier has a very worn VR V6 auto ute, now this thing has more ks on it than a Northern Territory road train but owner is keen to give the old girl a make over. List of bigger items are as follows
1. Engine rebuild with stronger pistons
2. Maximum porting of heads
3. slightly improved camshaft
4. Twin Raptor V chargers in compound configuration (20psi total pressure)
5. 2 stage intercooling and possible liquid cooling of the chargers
6. The big build on the auto but no change in stall speed etc, just stronger and still electronic control
7. A high flow intake manifold plenum designed to enhance maximum efficiency of cylinder filling. This will not resemble the original manifold in anyway at all, TB position like to to change also.
I imagine ute will get the paint and panel to go with as well.
Whats the chances of the above happening in my opinion, well pretty high as the guy can do all the stuff himself very easily except for the engine machining and auto tranny build.
If it comes together it will be quite the piece, it will in no way be an all out HP engine as it has to remain the workshop ute, just how he plans to have power control for the apprentices remains to be seen
For the owner just so long as it smokes the rubber good and hard to 150kmh is all he cares for, quartermile times are not his thing
You got a stockist in NZ? i need a S/C kit for my vr so how much would i be looking at?
Federation
Against
Rotary
Tossers
