+ Reply to Thread
Page 1 of 11 1 2 3 4 5 ... LastLast
Results 1 to 25 of 253
Thread: Holden V6 Kits VN - VR
    Raptorsc's Avatar
    Raptorsc is offline RAPTR6 Raptorsc Executive
    Hilux 4.0 V6 SC 270kw
    Jul 2006
    Mackay Qld Australia
    Default Holden V6 Kits VN - VP -VR
    For the 3800 motor (often referred to as the Buick motor) we offer the following
    2 Bar MAP sensor, 36 lb injectors are included with every kit for this engine
    Stage 1: 145RWKW - 160RWKW, no engine mods, just bolt on insert recalibrated MEMCAL and you are happening. Boost pressure is 8 - 9psi Price $4 k -$5 k range
    Stage 1.5: 160RWKW - 170 RWKW, no internal engine mods. Boost pressure 7.5 - 8.5psi
    Stage 2.0: 185RWKW - 200 RWKW, internal mods not needed and boost pressure 11psi.
    Changing camshafts, modifying cylinder heads etc will all make a considering increase of power at any one of the stages. Stage 2 plus big internal upgrades based around increasing volumetric efficiency will of course give the most power gain.
    Raptor Superchargers - Boosting S1/S2 3800's, Ecotec's, Alloytec's and 304's
    Raptorsc's Avatar
    Jul 2006
    Default Dyno chart for VN
    Will attach a chart for our VN kit, you would expect similar power from any 3800 motor in VN, VP, VR so long it had extractors fitted.
    We will be able to provide charts for this same Stage with intercooling fitted in a couple of weeks time.
    HDT_aero is offline resident bush mechanic HDT_aero Executive
    manual VN aero
    May 2005
    SA
    prices?? and is there a web site with more detailed information on each stage
    im not admiring your car im looking in disgust
    manual VN aero
    May 2005
    SA
    found the web site but doesnt have prices.
    how much for the kits with no installation
    Raptorsc's Avatar
    Jul 2006
    Default Pricing
    HDT
    I will PM you the pricing, and yes you can fit it yourself.
    For any who read here, we are similar in price to other centrifugal SC systems for this vehicle type, the real differences are the power outputs, the ease of installation, completeness of kits and kits feature exclusively the Raptor V supercharger manufactured by us.
    Tasmaniak's Avatar
    Tasmaniak is offline Not a valid input.... Tasmaniak Executive Tasmaniak Executive Tasmaniak Executive Tasmaniak Executive
    car
    Apr 2005
    Buick Motor... Why not call it what it really is and call it a GM
    hakhawk's Avatar
    hakhawk is online now forum adjudicator hakhawk Grange hakhawk Grange hakhawk Grange
    BMW E21 320i, E36 318IS coupe
    Jan 2005
    bah, you're a shocker 12voltking, will you never learn, that we will never learn. it will continue to be called a buick motor for eternity, even though some of us know that is is GM. why not call it what it realy is, a lump of iron and aluminium.
    Raptorsc's Avatar
    Jul 2006
    12 Volt King
    Got it all sorted up the top there now
    Tasmaniak's Avatar
    car
    Apr 2005
    I feel all warm and fuzzy inside....thanks man. I kind of get on my high horse about that...just a personal "issue"
    SweetWagon's Avatar
    SweetWagon is offline booosted SweetWagon Calais
    VS Berlina Wagon Supercharged
    Jan 2006
    Springwood NSW
    I didnt think the buick v6 would able to take that must boost without internal mods?
    Doctor Sodways's Avatar
    Doctor Sodways is offline Legendary Baby! Doctor Sodways Calais
    Slammed VeeDub Rat and a Brunette...
    Sep 2005
    Behind a Camera...
    Can i get a PM with the pricing as well, along with postage costs to melrose park SA 5039
    I used to play sports. Then I realized you can buy trophies. Now I’m good at everything.
    The best car safety device is a rear-view mirror with a cop in it. ~ Dudley Moore.
    Raptorsc's Avatar
    Jul 2006
    Thumbs up Doctor and VN6
    Doctor
    Will get that PM to you very shortly
    VN6pwr, this engine model is really happy for some boost, compression ratio under 9.0:1 means safety margin on this motor is good, responds very well.
    VN Executive S1
    Aug 2005
    Raptorsc's Avatar
    Jul 2006
    All PMs requested have been sent
  15. #15
    VP Exec,honda civic,mazda626
    Jan 2006
    watsonia
    VN6pwr, this engine model is really happy for some boost, compression ratio under 9.0:1 means safety margin on this motor is good, responds very well.[/QUOTE]
    what if the engine has done 200 odd thousand ks?
  16. #16
    Toyota Supra Turbo
    Dec 2005
    SE Suburbs, Victoria
    I'm interested as well, suburb postcode is 3802.
    Adam
    1990 VN S1 V6 Calais (SOLD!)
    1996 Toyota Supra Turbo
  17. #17
    Raptorsc's Avatar
    Jul 2006
    An engine which has seen 200 000km can either be completely stuffed or well within service limits in terms of wear. How a engine has been treated has everything to do with whether its going live long after a supercharger system has been added to it.
    If the motor has recieved at a minimum "by the book servicing" or better it is extremely likely it will be fine whether it be a 3800 or an ECOTEC
    Case in point, 95% of our customers to date have fitted the supercharger sytems to their vehicles all of which have been in excess of 180 000kms. All have performed exceptionally well, some having made in excess of 10 dyno pulls(competition days), some even more. Others have been flogged all over the place and are just fine. In most of these cases the rear wheel power has nearly doubled.
    To recap, depends on how the motor has been maintained/cared for.
  18. #18
    azkwazere is offline Ahhh Yes, Ahhh Yes.... azkwazere has disabled reputation
    VP 5-SPD / 24-SPD Racer Hybrid
    May 2005
    .....SE Burbs
    PM For me please... prices etc... thanx
    aZk.
    Wanted to buy:
    1. T5 V8 Bellhousing and Clutch fork assembly suit VP
    2. V8 Tail Shaft, T5, Suit IRS VP
    3. T5 VB Gear Box
    PM Me if you got what i need...
    Quote Originally Posted by ryno_vrx View Post
    honestly i doubt it will happen cause kanye west will just interrupt Armageddon anyways
  19. #19
    Jan 2006
    watsonia
    Quote Originally Posted by Raptorsc
    cheers can you PM with prices thanks
  20. #20
    VSB
    VSB is offline VSB Executive
    VX Supercharged Calais and Vr Berlina
    Mar 2005
    1991_Vn2nV's Avatar
    1991_Vn2nV is offline Donating Member 1991_Vn2nV GTS 1991_Vn2nV GTS
    91 VN Berlina & 03 VY Berlina
    Mar 2006
    Gumeracha, Adelaide Hills
  22. #22
    Raptorsc's Avatar
    Jul 2006
    All PM's sent, just about burnt me fingerz out so far this week lol
  23. #23
    vr executive
    Jan 2006
    Kalgoorlie,WA
  24. #24
    Raptorsc's Avatar
    Jul 2006
    OK, PM going your direction.
  25. #25
    sami_1985 Guest
    Smile
    Interested too...Toowoomba QLD 4350 Thanks
+ Reply to Thread
  1. VL Holden Wheels wont fit on Trailer with Holden Hubs WTF?
    By Gazza2005au in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 07-10-2011, 10:51 PM
  2. Replies: 14
    Last Post: 13-07-2008, 03:10 PM
  3. Holden Calais VS vs Holden Commodore vn
    By holdn in forum General
    Last Post: 08-02-2006, 10:08 PM
  4. VN - VS Holden CAI Kits
    By vinnywelsh in forum V6 Development And Modification
    Last Post: 27-07-2005, 09:29 PM
