Damn I like breaking engines
Your up for some drags at Willowbank on Wednesday Pete lol
Nice Alan! Bet your glad to finally have it back. Now just don't go breaking this one![]()
Quagmire: My fellow Americans, I have not been entirely truthful with you. I did gagoogidy that girl. I gashmoygadied her gaflavity with my googus. And I am sorry.
208rwkw 13.5 @ 102MPHSTROKED AND BLOWN
1. i didnt see the need to adjust the idler it seems tight enough
2. may look into this havent cleaned it its just been overlooked i actually have a kn filter cleaner kit in my shed.
3.the air filter may well be slipped on a bit far as it was fouling on the quater panel so i moved it up a bit i think.
4. yer theres a few bits it like to fix with my piping which may be restricting it.
5. doesnt seem to be any leaks at all
6-
7.i actually just remembered that i have another boost guage shall give it a look
8. yer ill be definatly trying to fix it before ordering another pulley
i may also try and get a 4' pipe made up not sure how im gonna fit it in but im sure theres a way.
and yer hopefully this has been a problem from start that i will be abe to fix and have free kw's and get some better times.
cheers for ur help once again
Maniac
I am interested to know the power
I know one of these stroker owners was wanting the VLC option, we just started making them in earnest today, will see a few popping up around the place now.
Not sure if it was maniac or sircruisealot, i am sure I will be reminded if I need to know![]()
Raptor Superchargers - Boosting S1/S2 3800's, Ecotec's, Alloytec's and 304's
That would have been me Tim, feel free to pm me about it. Im keen to get the VLC and a smaller pulley too.
Alan, wish i could head out to the drags but work is lame and there's just no way i'd be able to - im still not even 100% on whether i'll be at the drag day yet.
hi im interested in a raptor just wondering if u could send me as much info as possable for a vs ser 2 and all prices involved
Last night at Willowbank my first run was 17 secs 400m powerskid no traction at all
But I managed to get a 13.5 with most of the night having traction issues lol
thats pretty good .you think you could do better?
Yeah with some MT semi slicks and a bigger stallie
Maniac
Time to update the signature, it takes only a small amount of wheel slip to knock .5 off a quartermile run as that slip kills your 60ft, definitely keeping an eye on this one
We have VR V6 stock stroke with a reasonable cam etc goign 13.0s here in Mackay so essentially you should be eating that with the stroker. The VR is going a 4000rpm stall now and a retune to 6600rpm for a stronger run![]()
My next plans are a 3000 stall converter, 3.9 diff gears and change my rev limiter to 6000rpm then watch my times drop![]()
are u not pm'ing details anymore just updating details from kits already installed??????
Rumbuck
I have just checked my PM's and I am seeing nothing from you at all, I surely PM alright, answered a LOT this week.
just wondering wat every1 else is doing exhaust wise
this monday mine is going in to get a exhaust put on
im keeping my pacemakers just na pacies
and then into twin cats 2 1/4 pipes
then merge into a single 3' into a hotdog and muffler at the rear
this should be ok yeh
i didnt want much drone but aparently merging into a single 3 will give me better velocity and better note rather trying to get a sound out of 3 cylinders.
Yep, gets a reasonable sort of tick of approval from me
Can't see any mention of a catalytic converter tho, should be going twin 2.5" or single 3"
yeah im running pacemakers to a 2and 1/4 Y pipe to a 2.5inch hi flow cat with 2.5 inch pipe all the way with one straight thru muffler and one straight thru resignator goes much better now
i have to say exhuast turned out great sound better little more drone but yer price to pay for the etra response i have gained havent even had her fully open as its a little damp but yer seems to have gained a fair bit.
hey iv got a vy with a raptor intercooled setup running 10psi what is the max psi i can run? i want to boost it up as much as possible and what other mods will hav to b carried out apart from a retune and the correct pulley?
Yes my good friend and I made you this exact offer only last week - didn't hear back from you about it tho!
OK, you can go a 12psi pulley, all I ask is that you check it on the dyno and you install a 32mm BOV (with Raptor recommended mods), no amount of small valves will handle this bad boy.
Hope you got a good exhaust to let all the SNORT out![]()
does it make a noticable amount of difference? what kw gain do u think?
My experience with the VY project car
10psi goes very well
12 psi really goes quite a bit harder by comparison. I can't think of anyone running the 12psi manual right this moment, but you can be sure it will "feel" 30% more powerful since the boost comes in MUCH earlier
yeah thats what im after more boost earlier and some 3.9's should b a bit of a weapon........do u have a price on this 12psi pulley?
when u say to get it checked on the dyno i think its 100buks here to do a power run, will a normal powerrun show if the car is running lean or not? or is that just for a figure?
The power run isn't so much part of the question, its all about safe air fuel ratio
When you order your power run make sure you ask for a dyno chart that shows the power and air fuel ratio on it, if they aren't sampling the exhaust gasses during the run then hightail it outta there with your ute and find someone who does. I would expect 100% of dynos can measure and log air fuel ratio.
Then if its needs more fuel simply supply your dyno chart to chiptorque and some $$$ and they will do a you a revised tune for more fuelling.
