+ Reply to Thread
Page 26 of 35 FirstFirst ... 16 22 23 24 25 26 27 28 29 30 ... LastLast
Results 626 to 650 of 862
Like Tree4Likes
Thread: ECOTEC V6 kits VS - VY
  1. #626
    Raptorsc's Avatar
    Raptorsc is offline RAPTR6 Raptorsc Executive
    Hilux 4.0 V6 SC 270kw
    Jul 2006
    Mackay Qld Australia
    You were suprised, I felt vindicated, I could not have got this help from anywhere else and until it was proven by Brad it would have remained a theory
    The bend tightness is part of theory and the other is the surface co-efficient of silicone hosing, its very sticky compared to alloy or hard plastics (like stock intakes). The surface co-efficient of clean Alloy metal vs silicone hose is massively different.Getting rid of it all makes a HUGE difference if you got stickiness and tight bend all happening together, on go the air brakes
    Thank goodness we now have proof, independantly verified
    Raptor Superchargers - Boosting S1/S2 3800's, Ecotec's, Alloytec's and 304's
  2. #627
    Pub247's Avatar
    Pub247 is offline Donating Member Pub247 W427 Pub247 W427 Pub247 W427
    92 VP wagon Daily
    Apr 2006
    Melbourne S.E.
    you forget to add intercoolers into your physics equation most pressure loss comes from them
    Quote Originally Posted by Smidy
    How many kw would i need to beat vin diesil to the train lines?
  3. #628
    Raptorsc's Avatar
    Jul 2006
    Pub
    To tell the truth we are no longer seeing intercoolers as a restriction, our blower kits have always been 10psi and most people with coolers set up correctly with all metal pipes still get 10psi at the motor, same goes for WTA and ATA. We tried 4 different intercoolers on ImpulsesV6 Alloytec and never found any restriction difference between brands, in the end silicone bends will likely prove to be the greater impediment to airflow efficiency
    I suggest now that people with Raptor IC kits and well built self constructed IC systems are now experiencing some of the lowest loss intercooling systems in Australia.
    I am providing this info to our Alloytec customers and they are free to either retain or remove the silicone from their systems. The kits all made their advertised power but now there is opportunity to get an extra 3psi or so based on recent discovery. Going to be some bigger Alloytec numbers I feel ..............
  4. #629
    Raptor Charged VX's Avatar
    Raptor Charged VX is offline Turboed Ls1 FTW Raptor Charged VX Executive
    VY SS
    May 2009
    everything is trail and error, and how can something be answered if its never be donte or asked before, these forums are perfect for people to discover whats going in underneath other peoples bonets and what works and what doesnt,
  5. #630
    impulsesv6's Avatar
    impulsesv6 is offline Alloytec Garage impulsesv6 Executive
    A quick Alloytec
    Dec 2006
    brisbane, QUEENSLAND
    i think i have the 90deg bend into the engine sorted, but the 90deg bend out of the charger is something that may need the charger modified...
    will send ya some pics tim when i get a chance
  6. #631
    Raptorsc's Avatar
    Jul 2006
    Smile
    Quote Originally Posted by Raptor Charged VX View Post
    Absolutely and its of huge value when a manufacturer like ourselves continues to work with the customer, I think a lot of people have learnt a lot here at no cost to themselves but in turn benefitted in some small or even large (brad ) way
    Impulse
    Email me more pics of where you are up to with your silicone change out, got your last lot, looking for more
  7. #632
    immortality's Avatar
    immortality is offline crappy ol' VN driver immortality W427 immortality W427 immortality W427
    VN3.8 5spd/VSII3.8/VH5.0
    Apr 2006
    Auckland NZ
    Quote Originally Posted by Pub247 View Post
    The core size is 600x300x76mm
    The whole lenght size ( max. length ) is 780* 310 * 76 mm. 3" inlet / outlet.
    -BAR AND PLATE CONSTRUCTION
    -300-700PS
    Working Pressure: 10~40PSI
    Compressed air flow rate:572CFM/300HP 858CFM/500HP
    Presure Drop: 1.5~2.5psi@35psi;0.1~0.3psi@15psi
    Hot Air Temp: 0~150C
    TOP PRESSURE UP TO 80PSI
    fairly efficient for a cheap cooler.probably chinese made but if it measures up to these figures who cares where it came from. it certainly looks like a near zero loss system is achievable with low pressure systems (10-15psi). i think the other thing to consider here is that the raptor doesn't seem to heat the intake charge that much so the cooler doens't need to do a lot of work.
    Body by Holden, Soul by Brock
    the Legend will live forever
  8. #633
    ve ss sportswagon!!!
    Dec 2008
    tasmania
    does any1 no what is the closest you can have your pod filter to the supercharger? i was goin to mount mine strait off the supercharger but i noticed tim said its no good, so was just after a rough length i could put a strait peice of 4" silicone then adapt a filter?
  9. #634
    94 Single Turbo Supra
    Apr 2009
    Since the supercharger is a fixed displacment device of sorts, you do realize if he is seeing less than calculated boost, it could have something to do with the motor processing more air than a stock Alloytec.
  10. #635
    VY SS
    May 2009
    these motors are a fair bit differnt , the tune is pretty well perfect for these motors, and it has been physically proven then that the way you run your cooler pipes affect boost, as its the same on all intercooled cars turbo or blown. the less pipe and less bends the better, common sense.
  11. #636
    Raptorsc's Avatar
    Jul 2006
    A straight piece silicone for 4-6" then the filter would be a reasonable plan.
    The Raptor V will deliver a huge variation in volume at a given pressure - whether on Alloy, Eco or 3800 the same compressor speed will give the sam boost IF pipework is optimal
  12. #637
    VX
    Aug 2009
    G'day there,
    As ive looked through a few pages of this thread it seems the go is to ask for prices and you will PM.
    Ive got a VX series 2 auto sedan and was lookin for a bit more get up and go, was wondering if your could provide estimates of power with your different supercharger kits, and price of parts/estimated installation.
    Cheers,
    VX_6
  13. #638
    Raptorsc's Avatar
    Jul 2006
    Low cost 32mm blow off valves
    I cannot VOUCH for their quality/lifespan but have seen one in the flesh and seemed not too bad
    Check em out
    Greddy Style Type S Blow Off Valve - $54.00 : performance car parts | Car accessories Australia | auto components
  14. #639
    Mar 2008
    G'day Tim
    Could you Pm me the price for an intercooler kit and 12 psi pulley.Time to step up a notch!
    Thanks
    Ads
    PP
  15. #640
    Dec 2008
    tasmania
    will these low cost valves work on an intercooled kit tim? woodnt mind giving 1 a go, so i would just need the supercharger spring for it would i?
  16. #641
    Raptorsc's Avatar
    Jul 2006
    I have an email from a customer that I would really like to put up here, its from 2 brothers one who bought a Raptor kit and the other the 9psi V*****H kit. They both seem (from what they say) to have identical other mods like rockers etc. The performance difference between the 2 systems is quite amazingly different considering both are price similarly and so on.
    I won't post it (the email) on account that someone maybe could to the reverse to us through time/chance but I think you will get the idea this one went our way by a pretty decent margin.
    Everyone has their wins/loses ...... this one went our way
    In this instance (VY V6) the ProStreet Stage 1 with rockers went 182rwkw (in the advertised range) putting it over 20rwkw in the lead
  17. #642
    vs exec
    Jun 2008
    How much for a vs v6 auto stage 1.5 kit? and does it require a custom tune or is a tuned memcal included in the kit? and also is a shift kit on the auto a necessity? thanks
  18. #643
    Raptorsc's Avatar
    Jul 2006
    redvs2
    You can add the shift kit later, over time I have changed my views a bit and would suggest an oil cooler for the auto, easier to install/get done and enhances the way the auto shifts and lasts
    The 1.5 kit is an intercooler kit but we don't supply any pipework, its the ProStreet Stage 1 + intercooler, intercooler tune, and basic blow off valves for 9psi operation. You need to organise the pipes.
    All kits include a MEMCAL with a high quality tune, been supplying them for a LONG time now.
    $5500 for that one
  19. #644
    Raptorsc's Avatar
    Jul 2006
    A little news update from Raptor
    We will shortly be introducing a new Water to Air intercooler product to supercede our Air to Air system, will be just as efficient, easier to ship, complete stealth, no boost loss ever and far simpler to install. FOR VT - VY, not for VS due to space constraints
    About 5 weeks away now, will be dyno tested prior to selling kits
  20. #645
    Vt Clubsport
    May 2009
    hi i currently have a vt, only has a 2.5" full rebback exhaust at the moment, but will be getting some pacemakers & an aftermarket cai soon, i was wandering about the stage 1 kit you have, what estimated gains can be expected in rwkw, estimated quatermile & a rough price (fitted). and a price non fitted.
    estimes dont have to be spot on, just a rough idea of what can be expected estimately, thanks for your time.
  21. #646
    radarak47's Avatar
    radarak47 is offline I lean to the right radarak47 Executive
    VXII Acclaim
    Jun 2008
    Sydney NSW
    Hi Tim,
    Any more news on the W2A intercoolers? It sounds like the way to go for stealth....
  22. #647
    VX Executive S2
    Sep 2009
    Quote Originally Posted by radarak47 View Post
    Hi Tim,
    Out of the many posts, this one attract my attention. I believe it is possible for anyone to participate.
    Excellent ! I like it very much.
  23. #648
    MR_VX's Avatar
    MR_VX is offline Forced to be Fast MR_VX Executive
    VX SII Raptorcharged
    Mar 2009
    Townsville, North Qld
    installing my intercooler for the raptor kit i got, im havent a few problems can any one please show me some pictures of how and where to pipes hook up please!
    Check out my ride here =>My VX Raptor
    say NO to chev badges
    WTB - VY Black handbrake cover - Twin 2.25in exhaust to suit vx - vx/vy calais window surround chrome
  24. #649
    Raptorsc's Avatar
    Jul 2006
    MRVX
    You are always welcome to email me
    I have some pics of this
    Will send some now
  25. #650
    Raptorsc's Avatar
    Jul 2006
    Email sent, will be a while coming
    Otherwise take photo of piece/s you are having trouble figuring out, email those to me and I will come back with comment when I see the email
+ Reply to Thread
  1. Fluctuating idle on deceleration in 3.8 V6 auto (ECOTEC and non-ECOTEC)
    By cliffo78 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 24-04-2009, 11:02 PM
  2. VY Kits
    By sharebruz in forum VY Holden Commodore (2002 - 2004)
    Last Post: 28-05-2006, 09:57 PM
  3. Ecotec 4.2 stroker kits
    By smoken-v8 in forum V6 Development And Modification
    Last Post: 03-01-2006, 09:19 PM
  4. Supercharge kits for ecotec
    By nicko451 in forum V6 Development And Modification
    Last Post: 28-09-2005, 02:08 PM
  5. Stroker kits for ECOTEC V6
    By cizocizo in forum V6 Development And Modification
    Last Post: 04-07-2005, 06:10 PM
