Page 35 of 36 FirstFirst ... 25313233343536 LastLast
Results 851 to 875 of 883
Like Tree5Likes
Thread: ECOTEC V6 kits VS - VY
  1. #851
    vs ute
    Oct 2011
    hervey bay
    yes a non intercooled kit is what im after , what kind of intercooler would i need ?? i have a fortune bodykit so there is lots of space for an intercooler and going to put some bonnet vents to help get rid of heat to go with the intercooler , also i have heard the standard radiator plastic tanks can crack so i may need an alloy radiator is this true ?? thanks chris
  2. #852
    VS Berlina
    Mar 2011
    Woodford QLD
    chris your first post said you had a 2000 VS. Thats a little confusing on its own, they only made them till 97? Later, you've mentioned you own a VZ ute, though you havent stated whether or not the ute is the car is in question. If in fact you are talking about a VZ you are talking Alloytec not Ecotec.. you might want to clarify before you start ordering parts..
  3. #853
    one_and_only2004's Avatar
    one_and_only2004 is offline Turbo L98 FTW
    Z Series Thunder Utility - Turbo
    Mar 2008
    Regional NSW Australia
  4. #854
    Raptorsc's Avatar
    Raptorsc is offline RAPTR6
    Hilux 4.0 V6 SC 320kw
    Jul 2006
    Mackay Qld Australia
    Chris
    Confirm your vehicle model and year when you get a chance - want to send you the correct parts!
    About the radiator - plastic tanks age with time, you can either replace with a new Holden part or go aftermarket with alloy, stock works perfectly and probably a LOT cheaper. Have someone who knows what they are looking at inspect your radiator tanks, last thing you need is all your water being dropped while at full noise lol
    Raptor Superchargers - Boosting S1/S2 3800's, Ecotec's and Alloytec's
  5. #855
    VT
    Apr 2005
    QLD
    The end tanks are relatively cheap to change, worth doing imho providing your core is in good condition.
  6. #856
    vs ute
    Oct 2011
    hervey bay
    2000 series 3 vs ute
    the radiator is about 3 years old has done around 25,000kms and is in good condition , taking this ute on a trip to broken hill early next year and i have already broken down in the middle of no where and dont fancy sitting around in 40 degree weather waiting for parts to fix something , the plastic tank radiators i can get from car r us for $88 new and the alloy ones are around $230
  7. #857
    Raptorsc's Avatar
    Jul 2006
    Default Radiating energy
    Quote Originally Posted by VT-565 View Post
    I am with VT 565 on this one
  8. #858
    Raptorsc's Avatar
    Jul 2006
    This is the correct thread for another story
    A customer is taking their VT V6 Commodore to Lake Gardiner next year for SPEEDWEEK, apparently trying to set some kind of record on the dry lake bed. Hoping the Raptor will power his V6 to a class record - whatever the class is
  9. #859
    VT
    Apr 2005
    QLD
    Those DSLR guys have a squillion classes lol
    Good luck to everyone on the white shit
  10. #860
    vs ute
    Oct 2011
    hervey bay
    forgot to mention im taking a holiday to top of qld later in year or early in the new year thats why i wanted to know if i need a deposit and how long it would take to make the kit as im spending only a week or so there , definetly going to pick kit up from mackay
  11. #861
    Raptorsc's Avatar
    Jul 2006
    Cool Mackay or bust
    Chris
    I will take a small deposit from you shortly and the rest on pick up, will manufacture it in advance so you can collect it in 5 mins of your time
  12. #862
    Raptorsc's Avatar
    Jul 2006
    Your not wrong there, just had a bit of a look at their webpage
    2012 - Dry Lakes Racers Australia
  13. #863
    Raptorsc's Avatar
    Jul 2006
    It seems we have a new front runner in the Raptor V6 Power stakes
    Location of vehicle - Brisbane
    VS V6 ute w/manual (T56)
    Boost pressure 11.7 manifold pressure - Raptor V L series
    Engine is stock stroke - still 3.8 liter only
    Compression ratio 10:5:1 - Hi silicon cast pistons
    Heads stock
    Cam ZZP item
    LS1 Air Flow meter (too small)
    Intercooled
    Engine building advice came from SRE (Spencer Race Engines)
    Tuned and Dyno'd by Chiptorque for 257rwkw @ 5900 rpm - Today
    I have the dyno chart copy but I believe the owner will be along here in a week or so - he is a member and you have seen him here before. He is the drift man, some images posted here some place of his past works!
    That folks ............. is how its done. As i have often said stock compression or MORE, never less - low compression is a waste of everything.
  14. #864
    vs exec
    Jun 2008
  15. #865
    Raptorsc's Avatar
    Jul 2006
    I learned yesterday my cousin who has high boost Raptor V on his VS Ecotec says he has 280rwkw. At this stage not having more details and not having seen his chart - I am not finding it believable .......either
  16. #866
    VS Ute
    Apr 2009
    Quote Originally Posted by Raptorsc View Post
    Compression ratio 10:5:1 - forged pistons
    Heads stock
    Cam ZZP item
    Intercooled
    Your making me blush, LOL. Sorry mate the just cast high Silicon pistons my mistake, PEACH is the local builder- awesome dude Geoff and it was 10.7 psi going MAFless tune next and will be good to rev to 6600rpm (cam rated for 6800, but I'll let the power curve set the limit) Had to limit to 5500rpm until then as the comp and MAF start clapping out
    CIRCLE WORK IS A DRIFTERS RITE OF PASSAGE
  17. #867
    Raptorsc's Avatar
    Jul 2006
    OK, changed the original post
  18. #868
    VX S commodore II
    Feb 2012
    Could you PM me the price of this kit ( Raptor Superchargers ) for a VX commodore, Pro Street, and shipped to Christchurch, NZ. Quote in AUD currency please.
    Thanks
  19. #869
    Raptorsc's Avatar
    Jul 2006
    OK will get it done shortly, if you dont hear from me, hit me up again for the pricing
  20. #870
    greasemonkey24 is offline Donating Member
    vt s pac 3.8
    Jan 2012
    armadale
    hi i have vt 3.8 with cai extractors, im fitting stage 2 cam and memcal shortly could u possibly pm me a reccomended kit without doing any internals and pricing thanks guys
  21. #871
    Mar 2008
    Quote Originally Posted by greasemonkey24 View Post
    Make sure you get yourself a boost friendly cam or you'll go backwards in performance
    VZ Thunder - 360RWKW Turbocharged V8 - Parts by AKO Performance Tuned by BPS
  22. #872
    Raptorsc's Avatar
    Jul 2006
    The Raptor ProStreet Stage 1 is the go for you maybe, good power and our lowest priced full kit. It doesnt include an intercooler but you can add that later, in the meantime you can add 70 or so rwkw easily and safely
  23. #873
    Raptorsc's Avatar
    Jul 2006
    The salt lakes racer VT V6 has been tuned up
    235rwkw. The owner suspects the cam timing is incorrect as the power should have been a solid 260 but fell short and there is no time to fix it, they go racing on the 19th of this month
    Pictures etc in the near future
  24. #874
    VS Ute
    Jan 2012
    Frankston
    Hey raptor. i got a VS V6 SIII Auto Can you PM me all details on 1.5 and stage 2 kits with what id need, everything. Thanks
  25. #875
    VS Acclaim Series 2
    Oct 2011
    Perth - Cockburn
    Would a Stage 1.5 S/C suit 1.9 rockers from MACE and a stage 2 cam from MACE (suiting the rockers), as well as shift kit and 3.7 LSD diff?
    Also have MACE CAI, should I go with Stage 1 instead?
    My Car - http://forums.justcommodores.com.au/...series-ii.html - Green + Black Themed VS
    Also looking for LSD Diff with 3.7's, possibly 3.9 gears.
  1. Fluctuating idle on deceleration in 3.8 V6 auto (ECOTEC and non-ECOTEC)
    By cliffo78 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 25-04-2009, 12:02 AM
  2. VY Kits
    By sharebruz in forum VY Holden Commodore (2002 - 2004)
    Last Post: 28-05-2006, 10:57 PM
  3. Ecotec 4.2 stroker kits
    By smoken-v8 in forum V6 Development And Modification
    Last Post: 03-01-2006, 09:19 PM
  4. Supercharge kits for ecotec
    By nicko451 in forum V6 Development And Modification
    Last Post: 28-09-2005, 03:08 PM
  5. Stroker kits for ECOTEC V6
    By cizocizo in forum V6 Development And Modification
    Last Post: 04-07-2005, 07:10 PM
