ok i got a bit of a story about my build up of my ls1 vu ss and some of the troubles ive had geting a single custom turbo kit made for my ute. here is a few pics of the build up. PWR water to air barrel intercooler
this is the cooler tank for the water to air intercooler
custom header tank and intercooler plumbing
patriot heads
dump pipe and manifold
turbo and pod filter
ok now you have seen all the pics of what it use to look like turns out the turbo injested some rubber some how and stuffed the compressor wheel and the set up of the custom manifold was rooted. It was two close to the heads and the coil packs were arcing from the coil packs to top the heads and the hole system made the motor run two hot. It could have been modiflyed but there was no guarantee that it was going to work after the modications so what has this got to do with raptors superchargers you may ask the turbo has been pulled off a set of 1 3/4 4=1 paceys 60lb injectors raptor v had been fited and running 10 psi of boost and in a month or so a cam will also be installed so i should be picking my ute up next week some time and will post some more pics and dyno sheets then moral of the story dont be a ginne pig and only use tryed and trusted ways of increasing proformance i will say a big thanks to tim @ raptor and tim @ ls1 proformance for fixing this mess
and i will keep every one here posted to
cheers
thrifty
