Page 1 of 2 12 LastLast
Results 1 to 25 of 34
Thread: Raptor V vs Raptor V Hybrid
    VS Maloo
    Jan 2006
    Hawkesbury
    Default Raptor V vs Raptor V Hybrid
    I have been looking on the site and it specifies that the Raptor V is for engines up to 5L, and the Raptor V Hybrid is for over 5.5L engines. I have a 355 stroker, so technically is now a 5.7L not a 5L. Does that mean that if i were to get a supercharger kit from you i should be getting the Raptor V Hybrid, or would you still recommend the Raptor V? Also is there any difference in warranty validation etc?
    --APOC--
    Jun 2006
    Western Aus.
    Quote Originally Posted by apoc585 View Post
    Actually it 355 cubic inches = 5.8L.... but we won't get too technical.
    Hot Lap Motorsport
    Raptorsc's Avatar
    Raptorsc is offline RAPTR6
    Hilux 4.0 V6 SC 320kw
    Jul 2006
    Mackay Qld Australia
    apoc
    How much boost pressure would you like for your 355?
    Raptor Superchargers - Boosting S1/S2 3800's, Ecotec's and Alloytec's
    Raptorsc's Avatar
    Jul 2006
    Not saying anything about the Raptor R as such but a variant of it will be running possibly soon as end of next week.
    I will have some pics otherwise it is going for export and will not be seen here.
    Pics will be provided
    Mar 2008
    Quote Originally Posted by Raptorsc View Post
    Sounds interesting
    So you won't be able to buy them here?
    Raptorsc's Avatar
    Jul 2006
    Lets see what the next few weeks brings, if I have time to make up a few more I will do that, will also look at slipping one on the tractor pulling tractor for some heavy duty testing, big revs and continous boost testing.
    Will get some more covers cast once we machine up the first one ---------- TOMORROW
    Raptorsc's Avatar
    Jul 2006
    Default Raptor V Hybrid
    As always we release our juiciest information on Just Comms FIRST
    The Raptor V Hybrid was born into the world today! This beast is for those who want more flow (stroker V8s, 4 valve head V8s) than what the Raptor V would give.
    All the Raptor ProStreet kits for the 5.0 liter will remain but for additional cost this item is now on the scene to fill the needs of a 355 - 383 stroker engines
    Otherwise its for use on anything where it can fit
    Enjoy these images of the epic weapon, has a billett alloy impeller, I think pretty much the only other supercharger with billett impeller is Procharger ....... until now
    Attached Images Attached Images
    Raptorsc's Avatar
    Jul 2006
    Machining some more Hybrids for action
    Raptor Charged VX's Avatar
    Raptor Charged VX is offline Turboed Ls1 FTW
    VY SS
    May 2009
    Raptorsc's Avatar
    Jul 2006
    I know you will
    Once we get a few on hand it could be a proposition, all units being made right now is presold for the moment but we will get ahead of orders soon
    VY SS
    May 2009
    ok well once they have been ran for a while, ill be more than happy to run a cooled 12 psi system again
    ryno_vrx's Avatar
    ryno_vrx is offline Donating Member
    VR HSV enhanced Berlina
    Nov 2008
    Mirani
    if you wanna swap my current order for one of those hybrids i think i'll allow it
    whats the difference between my missus and my blower??
    well they both whine but the blower actually puts out
    Raptorsc's Avatar
    Jul 2006
    Finally some info on the Hybrid BEAST
    Just came back from the first drive with the new blower.
    Flat-out awesome!
    Comparing: (from same car with same camshafts, etc) and even the same pulley on the supercharger.
    We had first positive pressure in the manifold as early as 2000 rpm, where the Raptor V gave us first positive pressure at 3600 rpm.
    We now develop 170 kpa of pressure at redline, and the Raptor V gave us 128 kpa.
    We also note that the boost is more progressive and linear. The Raptor V compressor map showed that it could not quite keep up with our 5.0 L 32v engine. The compressor map for the Raptor V Hybrid shows that it had not trouble keeping up.... the boost never wavered and did not have a small sweet spot like the Raptor V. This supercharger has a big, smooth sweet spot. Very comfortable.
    on the last drive I spun the tires from 1st to 2nd gear, spun them again from 2nd to 3rd, and spun them AGAIN from 3rd to 4th!
    Could be awesome on a Commodore V6!
    one_and_only2004's Avatar
    one_and_only2004 is online now Turbo L98 FTW
    Z Series Thunder Utility - Turbo
    Mar 2008
    Regional NSW Australia
    Too right it could - gear it up for 12psi @ 2000 rpm and regulate it with a wastegate - i'll put my hand up for one!
    VZ Thunder - 360RWKW Turbocharged V8 - Parts by AKO Performance Tuned by BPS
  15. #15
    Raptorsc's Avatar
    Jul 2006
    OK latest in from the USA - dyno testing of Raptor Hybrid (495hp) vs the Raptor V (430hp)
    Engine is 5 litre V8 Porsche
    Came back from the dyno, and we put down 495 HP at the tire! Up from 430 at the tire before.
    But wait, its BETTER than that.... the only dyno I could get to was an eddy-current dyno and they are 40-50 HP low compared to the inertial-drum dyno I have been using.
    I will go to a matching inertia-drum dyno just like the one used to measure the car and Raptor V previously.
    I expect to see 520 or more at the tire. Add 15% for engine output.
    The Raptor Hybrid is showing 65hp extra when tested on a different type of dyno to normal, it will show more he expects when tested on same dyno. If it does make 520hp at the tyre on the dyno they normally use then it will be an indication that a Raptor Hybrid can add an additional 70 - 90hp at the tyre over the Raptor V.
  16. #16
    Raptorsc's Avatar
    Jul 2006
    Smile Raptor V Hybrid - More airflow for engines >4.0 litre
    Raptor Superchargers is soon keeping the Raptor Hybrid as a stock item, initial parts supplies are on the way! Supports 500+ Hp at the tyre
  17. #17
    VS ute
    Nov 2008
  18. #18
    Raptorsc's Avatar
    Jul 2006
    Smile ECOTEC Boost
    The Raptor V is the supercharger used in all our ECOTEC kits
    The V Hybrid is a bigger beast and simply wouldn't fit very easy
  19. #19
    VS ute
    Nov 2008
  20. #20
    Raptorsc's Avatar
    Jul 2006
    Smile Raptor V Hybrid #3
    Another hybrid has just been created, this one goes onto a Subaru 4 cyl
    This will be the first fitment of a Hybrid to any vehicle in Australia
  21. #21
    Mar 2008
    Would it be extremely difficult to fit a hybrid onto an ecotec? Would it be capable of more boost down lower?
  22. #22
    Raptorsc's Avatar
    Jul 2006
    Yes in both instances, but then again we should do a test fit on an ECOTEC, we could do this tomorrow maybe
  23. #23
    Mar 2008
    So if it did end up fitting, is it as simple as sending back a normal raptor R and having it frankensteined into one of these bits of gear?
  24. #24
    Raptorsc's Avatar
    Jul 2006
    Yes it would be that simple to upgrade the charger, remember tho the intake size is 4" vs 3.35" and outlet is 3" versus 2.5" so some changes to pipework too
  25. #25
    Mar 2008
    Yeah i thought the piping would have to change - not to worry, I reckon that trent would be able to sort it out if it becomes a possibility.
  1. Welcome to Raptor
    By Raptorsc in forum Raptor Superchargers
    Last Post: 23-01-2012, 08:46 PM
  2. Raptor V (SV6)
    By tanner892 in forum Raptor Superchargers
    Last Post: 12-01-2009, 08:02 PM
  3. Another Raptor in a VR Calais V6
    By totq in forum Raptor Superchargers
    Last Post: 01-02-2008, 09:06 PM
  4. Raptor Supercharger
    By HIROLLA in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 24-07-2006, 11:30 PM
