+ Reply to Thread
Page 2 of 8 FirstFirst 1 2 3 4 5 6 ... LastLast
Results 26 to 50 of 176
Like Tree2Likes
Thread: Raptor Compound Supercharging for ECOTEC
  1. #26
    delcowizzid's Avatar
    delcowizzid is offline on holiday delcowizzid Senator Signature delcowizzid Senator Signature delcowizzid Senator Signature
    в∞ѕтεכ √&
    Jul 2008
    NZ
    In the late 1930's Mercedes Benz used compound supercharging on there Grand prix cars. In this system one unit pumps into a second smaller unit increasing boost pressures to as high as 38 psi.
    even WW2 planes used 2 different sized chargers too
  2. #27
    Raptorsc's Avatar
    Raptorsc is offline RAPTR6 Raptorsc Executive
    Hilux 4.0 V6 SC 270kw
    Jul 2006
    Mackay Qld Australia
    Size of the second stage is no issue at all, they go smaller because they can, we aren't because we don't need to. If you are running rootes type blowers you will take every opportunity to reduce weight and size since the things are heavy and power hungry.
    In the case of aircraft, you make everything as light as possible, so if you can get away with smaller on the second stage then you do.
    For us we have no such limitations, we will use the same compressor in both stages because we can, enough room etc
    Paxton did it with 2 identical units
    Raptor Superchargers - Boosting S1/S2 3800's, Ecotec's, Alloytec's and 304's
  3. #28
    Raptorsc's Avatar
    Jul 2006
    I have been searching the web the last 30 mins looking for the historical stuff on the paxton twin system ......... nothing. I have somewhere (no idea where) a photocopy of an old magazine article about this system. Judging by the rarity of info about it I might have to dig it up sometime, even the Paxton freaks in the USA will be coming to lap it up
  4. #29
    wh v6 statesman
    Apr 2009
    mornington peninsula
    i have been reading up on this forum about the 'css' and i am completely blown away cause as far as i knew at first it was about getting up to 20psi out of an ecotec, and then a couple of days after that i read that it could be producing up 24psi, and on top of that people are thinking of trying to get more psi, i cant help to ask isn't that too much out of and ecotec even if it has been fully worked from the inside out cause as far as i have found i can only find engine components that can only handle up to 20psi, im only new at this and i have that feeling that i might be getting a bit over my head too quickly.
  5. #30
    Raptorsc's Avatar
    Jul 2006
    Nermal
    Never fear, let us do the testing and see what we have or haven't got and what effect on everything it has.
    There will be lower pressure versions of this system for sure however the idea of it in the first place is to run more boost than you can get from the single unit
  6. #31
    eaton v8's Avatar
    eaton v8 is offline my little sleeper eaton v8 Executive
    vz 6l auto 239cam 3.9diff
    Jun 2008
    gladstone qld
    Quote Originally Posted by drift-it View Post
    well ive seen a setup on a malloo ute on youtube where a side mount feeds a top mount!!! so i guess this is sorta the same principal... very loud induction noise!!!
    i have a feeling if it was a red one that i seen that in a mag and marks workshop in wa put it together
  7. #32
    Raptorsc's Avatar
    Jul 2006
    Eaton V8
    Yes I have also seen that one, there was some complaint about total noise of the system, goes hard but damn she's a loud one
  8. #33
    Raptorsc's Avatar
    Jul 2006
    Supercharger Compounding 101
    Theory
    By flowing the air through two compressors, the pressure ratio becomes the sum of the two individual centrifugal compression ratios. The result is a much higher total boost pressure available to the engine.
    Thats it for today
  9. #34
    wh v6 statesman
    Apr 2009
    Quote Originally Posted by Raptorsc View Post
    Nermal
    i would be more that happy to go over 20psi because if i went any lower like 15-16psi then there would not be any point in getting the 'css' in the first place, i just wouldn't mind knowing if there are engine components out there like forged pistons, conrods, crankshaft ect, that would be able to handle over 20psi because i cant find any, and it would most have to be for a 4.2l stroker kit of some sort cause thats what i am looking at getting.
  10. #35
    Raptorsc's Avatar
    Jul 2006
    For sure you can set up to run 20psi, drop the compression to 8.3:1 or thereabouts, go forged pistons and run some decent rods and MLS head gaskets.
    COME would be totally comfortable making you a stroker kit for 20psi.
    I think everyone needs to take a look at the pressures being applied to stock ECOTEC's now, with 16psi boost seeming to work quite fine if the tune is spot on, therefore for another 4psi the motor can't be needing too much more strenght. Forged pistons and something like an L67 rod are going to be close to a real solution.
    Not seeing any huge difficulties yet, we will be running 16psi on the stock motor
  11. #36
    wh v6 statesman
    Apr 2009
    oh ok yeah the 8.3:1 from comeracing is the kind of long stroker kit i was looking at getting anyways mainly because it is the strongest that i have heard of so far, and because i am defiantly going to be strengthening the engine before i supercharge it just incase the worst was to happen and to get even more power out of the engine.
  12. #37
    Raptorsc's Avatar
    Jul 2006
    You biggest concern at this power level would be the gearbox, you should be looking for a T56 transmission upgrade, unfortunately they aren't so cheap
  13. #38
    VY6 Ute
    Jan 2008
    Aspendale, VIC
    Mal Wood do a T56 conversion for the ecotecs... i know of a few that have been done for YT blower set ups. i personally know of a VS and a VX being done, have a chat to find out your options, someone told me ballpark figure is around $5000-6000, dont take that for gospel though, may be totally incorrect!!
  14. #39
    MaN|aC's Avatar
    MaN|aC is offline Donating Member MaN|aC Berlina
    VT 4.2 S/C
    Apr 2006
    Quote Originally Posted by nermal View Post
    Take it from me, I've destroyed two COME Racing engines with 20,000kms apperantly they not too strong mate...
    Im currently rebuilding my third stroker atm but this time COME Racing isn't building it.
    208rwkw 13.5 @ 102MPH
    STROKED AND BLOWN
  15. #40
    Raptorsc's Avatar
    Jul 2006
    ^^^^ some good advice
    There are just a few good ones.
    Maniac - is the current build ok for 20psi ?
  16. #41
    MaN|aC's Avatar
    VT 4.2 S/C
    Apr 2006
    Once the intercooler goes on then I'll test your smallest pulley available Tim, my current engine still has the same specs as the COME Racing but im using different parts.
    When I blow up this engine im going back to my original 3.8 ecotec
    STROKED AND BLOWN
  17. #42
    ve ss sportswagon!!!
    Dec 2008
    tasmania
    maniac
    u seem 2 no a bit about stroker kits, do u no how much a kit wood b for a vy including labour off the top of ur head?
  18. #43
    MaN|aC's Avatar
    VT 4.2 S/C
    Apr 2006
  19. #44
    VP Executive R-spec
    Jan 2005
    Maniac is your car a series 1 :? there was a guy at the easternats with a turbo 304 making 340 rwkw, stock engine!: 2 grand and you would never break another ecotec again
  20. #45
    wh v6 statesman
    Apr 2009
    Quote Originally Posted by MaN|aC View Post
    was that over there recommended psi rating or under because they are rated at 20 psi at most so they say.
  21. #46
    wh v6 statesman
    Apr 2009
    Quote Originally Posted by LJS-UTE View Post
    sounds interesting, i was wondering if it was possible to put a t56 on an ecotec a few weeks ago, do you know if its an easy conversion if the ecotec is already a manual or will i have to still change the whole clutch reservoir and pedals ect, to in order to fit the t56
  22. #47
    Raptorsc's Avatar
    Jul 2006
    Nermal
    The 10psi rating matters when we are pumping in a single stage, in dual stage we can come back to 8psi per charger (real easy on the chargers) and still make final pressure of 16psi!
  23. #48
    wh v6 statesman
    Apr 2009
    Nermal
    oh ok thanks
  24. #49
    VY Berlina V8
    Apr 2009
    Malwoods makes a kit for the ecotech, from memory it was like 6-7 grand.
  25. #50
    HoldenManDan's Avatar
    HoldenManDan is offline Built, not bought... HoldenManDan Calais
    VS Exec SII 4.2L L67 T56 :D
    Jul 2006
    Penrith, NSW
    my t56 is sitting out the back waiting for my 4.2 L67 to be finished... its going to be fitted to my already manual vs, and all the parts for the conversion plus delivery totalled $8100. It included: (directly from the receipt)
    SUPPLY NEW T56 6SPEED GEARBOX. NEW CLUTCH KIT
    AND FLYWHEEL, NEW BRAIDED LINE, NEW ENGINE PLATE
    AND BELLHOUSING,, NEW GEARSTICK AND KNOB, MOUNT
    AND CROSSMEMBER, FRONT HALF OF SHAFT WITH NEW
    UNI AND SLIP YOKE
    you could bring the price down a bit if you were happy with a reco box instead of a new one, but i'm not cutting any corners with this build.
    ummm MaN|aC, my stroker is getting built with parts supplied by C.O.M.E, i'd be interested to know what parts went into your previous builds that failed... a PM detailing what parts were in them would be great if you could!
    Factory 5 speed VSII, now 4.2 Litre L67 with T56 6 speed
+ Reply to Thread
  1. [ACT] perfect line cobra compound
    By big m in forum Parts And Other Items For Sale
    Last Post: 22-02-2009, 03:03 PM
  2. Supercharging
    By Grennan in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 02-05-2007, 11:51 AM
  3. supercharging a stock vt ecotec
    By Vt_vic in forum V6 Development And Modification
    Last Post: 15-04-2007, 07:05 PM
  4. Raptor S/C for Ecotec...
    By Frandy in forum V6 Development And Modification
    Last Post: 07-11-2006, 01:29 PM
  5. WTB Compound bow package
    By digisol in forum Swap / Wanted to Buy / Trade
    Last Post: 26-07-2006, 07:16 PM
