+ Reply to Thread
Page 3 of 8 FirstFirst 1 2 3 4 5 6 7 ... LastLast
Results 51 to 75 of 176
Like Tree2Likes
Thread: Raptor Compound Supercharging for ECOTEC
  1. #51
    MaN|aC's Avatar
    MaN|aC is offline Donating Member MaN|aC Berlina
    VT 4.2 S/C
    Apr 2006
    Both engines I smashed a lifter leaving pieces of metal in the sump, so everything needs to be rebuilt again
    I should get it back for Power Cruise next month as it been nearly 6 months to rebuild it...
    208rwkw 13.5 @ 102MPH
    STROKED AND BLOWN
  2. #52
    wh v6 statesman
    Apr 2009
    mornington peninsula
    Quote Originally Posted by MaN|aC View Post
    did you put in 1.9:1 high compression rockers or higher in or is it not needed because the stroker kit is meant to lower the compression ratio
    cheers
  3. #53
    immortality's Avatar
    immortality is offline crappy ol' VN driver immortality W427 immortality W427 immortality W427
    VN3.8 5spd/VSII3.8/VH5.0
    Apr 2006
    Auckland NZ
    there have been a few COME strokers that have had this failure. are they any closer to figuring out why? which brand of lifter did you have?
    Quote Originally Posted by nermal View Post
    high ratio ROCKERS effect valve lift and have nothing to do with compression
    Body by Holden, Soul by Brock
    the Legend will live forever
  4. #54
    wh v6 statesman
    Apr 2009
    high ratio ROCKERS effect valve lift and have nothing to do with compression[/QUOTE]
    oh ok i wasn't too sure about them at the time
  5. #55
    MaN|aC's Avatar
    VT 4.2 S/C
    Apr 2006
    Quote Originally Posted by immortality View Post
    Im guessing that Speed Pro lifters which COME Racing uses isn't strong enough hence why I broke two already.
    Sorry Tim for getting a bit off topic
    STROKED AND BLOWN
  6. #56
    Raptorsc's Avatar
    Raptorsc is offline RAPTR6 Raptorsc Executive
    Hilux 4.0 V6 SC 270kw
    Jul 2006
    Mackay Qld Australia
    Maniac
    No worries on that
    Visited the fab shop again yesterday and it seems old mate is running out of time and $$ to complete the compound system (doing it as his own project) and is now thinking of turning to getting our custom intake manifolds for ECOTECs happening.
    Let see what happens
    Raptor Superchargers - Boosting S1/S2 3800's, Ecotec's, Alloytec's and 304's
  7. #57
    wh v6 statesman
    Apr 2009
    looks like i will changing them when i get the engine done, oh yeah and sorry about changing the subject aswell
  8. #58
    Raptor Charged VX's Avatar
    Raptor Charged VX is offline Turboed Ls1 FTW Raptor Charged VX Executive
    VY SS
    May 2009
    The other possible way is to feed both chargers into a rather large WTA intercooler, lets say to 3 inch inlets at the bottom then approx a single 4 or 5 inch outlet at the top directly into a very large single throttle body, so to do that you would need fabricate a whole new manifold with the TB at the front like an LS1 and move the thermostat to the back like the buicks, and then you could almost make the manifold to copy an aftermarket 5L one, just think about how much air u could feed thru the right TB and manifold set up, have the heads flowed right and everything to match you could keep winding up the boost, something to ponder about.
  9. #59
    Raptorsc's Avatar
    Jul 2006
    OK
    A little update, I should have got some photos, product Compound SC is on the road and rolling, full stainless exhaust with big bore headers all hand made. The intercoolers are on their way from the USA and polishing of the chargers is happening.
    Will be another few weeks yet ............ but going ahead nicely so far.
    RC VX your suggestion would give double the flow but leave us at normal 10 - 12psi, what we are doing is 20psi
  10. #60
    SICK SS is offline 7L 427ci BABY SICK SS Executive
    427 ci vu ss a4 ve ssv a6
    Jan 2007
    central queensland
    Quote Originally Posted by Raptorsc View Post
    OK
    Tim i remember damo talking about doing this sum years ( maybe 6ish ) with me when i was decideing what path to go down good to see it going ahead
    RAPTOR CHARGED 330RWKW VU SS UTE IF IT DOSNT BLOW IT SUCKS
  11. #61
    VY SS
    May 2009
  12. #62
    Mar 2008
  13. #63
    Raptorsc's Avatar
    Jul 2006
    Yes
    The front mount heat exchanger has been mounted (painted black for total stealth) and the intercoolers arrived from USA if I hadn't mentioned that already.
    Now all they are waiting on is for me to manufacture the chargers for it.
  14. #64
    VY S pack & VP ute
    Jun 2008
  15. #65
    Raptorsc's Avatar
    Jul 2006
    The superchargers could be installed late next week
  16. #66
    custom vk Calais
    Jan 2009
    any updaes mate ?
    when will you be looking at doing this kit ? i am very keen to do this to the vt.
  17. #67
    Raptorsc's Avatar
    Jul 2006
    Kego
    All still on track at this stage, might be a couple of weeks before there are chargers hangin of it but for sure its still going ahead
  18. #68
    custom vk Calais
    Jan 2009
    Raptorsc's Avatar
    Jul 2006
    Talking
    kego
    Would you know it, its 12:52pm Saturday and I am making up the special chargers for the Compound System. We dropped some 1.98:1 MACE rockers on this same engine on Thursday also.
    The front mount radiator has been in for a few weeks now, everything is ready to rock and roll. I should be able to supply the finished chargers for the project later this next week, then its ROCK AND ROLL
  20. #70
    VY S pack & VP ute
    Jun 2008
  21. #71
    Raptorsc's Avatar
    Jul 2006
    drippy
    A minor set back occurred yesterday, the freakin stock motor died, seems a balancer shaft bearing has gone down, sucks pretty much since the motor has ONLY 130 000km on it which is NOTHING. The owner went to collect some gear, had a dodgy load so drove back about 70 kmh, pulled up and then NOISE
    Anyhow noise is not going away so we have an engine rebuild happening before we even get a supercharger near it. We have another friend who had this same issue, anyone else heard anything of balancer shaft bearing failure??
    Compounding will happen when motor actually runs again
  22. #72
    radarak47's Avatar
    radarak47 is offline I lean to the right radarak47 Executive
    VXII Acclaim
    Jun 2008
    Sydney NSW
    Sounds very similar to my first engine Tim. Couldn't tell you for sure though because I never got around to pulling it down.
    Give me a couple of weeks and I will be able to tell you. Does it knock at idle up to about 3000rpm then stop as the rpm goes higher?
  23. #73
    Raptorsc's Avatar
    Jul 2006
    Yes, thats pretty much exactly it
  24. #74
    VY V6
    Jan 2008
  25. #75
    VY S pack & VP ute
    Jun 2008
    any updates on this?
    thanks
+ Reply to Thread
  1. [ACT] perfect line cobra compound
    By big m in forum Parts And Other Items For Sale
    Last Post: 22-02-2009, 03:03 PM
  2. Supercharging
    By Grennan in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 02-05-2007, 11:51 AM
  3. supercharging a stock vt ecotec
    By Vt_vic in forum V6 Development And Modification
    Last Post: 15-04-2007, 07:05 PM
  4. Raptor S/C for Ecotec...
    By Frandy in forum V6 Development And Modification
    Last Post: 07-11-2006, 01:29 PM
  5. WTB Compound bow package
    By digisol in forum Swap / Wanted to Buy / Trade
    Last Post: 26-07-2006, 07:16 PM
