Alright, just to let you know it will be much heavier than your car and I do not recomened using bridge guage cabling in your car.
That will be $20 000 per metre please![]()
LOL @ the bridge gauge!!
Joe Bellissimo
Shopping Secure - Car Audio Specialists
www.shoppingsecure.com.au
MSN/Email: sales@shoppingsecure.com.au
Hmmm let me upgrade my springs and shocks first then I'll get back to you on that.
Ronald Reagan (1986)
I'm currently using 5metre RCA leads, to connect several components to my television, it works fine, but is it ok to do so?
Are you asking is it fine to split the RCA leads or are you asking if they are too long?
Joe Bellissimo
if it's ok to split them, like using 1pair, and then one lead off another pair, and using them instead of AV plugs?
Well AV plugs and RCAs are the same thing. When you split them you are reducing the voltage which would reduce the signal clarity but if its not posing a problem I really don't see anything wrong with it.
Is there something specifically wrong with it that you are trying to fix?
Joe Bellissimo
Well the AV plugs you get with things when you buy them, are lucky to be 1 metre long.Without even trying to find out if you could buy longer AV cords, i just thought i would try out the RCA's,i had spare, and they worked. Seeing as their 5 metres long, i can basically put stuff wherever i want.. just wanted to make sure i wasn't going to cause any problems by using them..
I've used spare 5m car rcas to hook up a dj mixer to a PA before. They are all much the same
just started my VT(V6) cold have never noticed before but windows up radio off and I could hear water wooshing when it turnded over then a tap on the throttle sounded like water running through my dash any ideas what is ???? cant hear it in engine bay or in the car with door open....
My suggestion would be to not try and start your car underwater, I hear its bad for the engine. Though I've heard Bugatti Veyrons are good for 15min underwater.
It's the coolant running through the lines. When it's low, or has air blockages, you will hear it. Start the car when it's cold, and take the cap off your radiator. Turn your your heater onto max, so it causes the thermosat to open all the way. You will need to add coolant via the radiator, while bleeding it of any air leaks at the same time. You will find a small flat head screw on your thermostat housing, you simply undo this to allow any air out.
Thats a better answer than I could have provided since I'm not a mechanic, thanks HoldenCommodoreVP.
Joe Bellissimo
I'm just glad i was finally able to post some useful.....![]()
Is there a rep system where I can give you points?![]()
Joe Bellissimo
Damn -- rep for you
Joe Bellissimo
looking on the site Shopping Secure - Car Audio Specialists - SPL Dynamics TD-6903
is there a best price you can do with postage to sydney 2558??
I'll take 10% off and you can come and meet me up at Liverpool if you want so you wont have to worry about shipping.
Joe Bellissimo
woundering if it is possible to build a awd holden vl.
im buting a 3 litre twin cam twin turbo in january with everything under the sun done to it but its only rear wheel drive. and the idea of an awd vl popped into me head just woundering if it would be possible. ive searched the net and carnt find anything about it bein done befor.
you can email me on shetlon_15@hotmail.com with any answears or thaughts
cheers
Mate I honestly have no clue. I suppose anything is possible but it will depend on how deep your pocket is. I think it would be pretty damn sick but I'm not sure if it would be worth the effort involved.
Joe Bellissimo
Joe I think you really need to get the threads title change to something like, "Don't be shy! Post up any questions you may have about (my?) car audio products!".
haha yeah should make the title audio related lol
my 1996 vs berlina
http://forums.justcommodores.com.au/...s-berlina.html
Joe I think you really need to get the threads title change to something like, "Don't be shy! Post up any questions you may have about (my?) car audio products!".-quote
haha yeah should make the title audio related lol-quote
Don't be shy guys, post up any questions you might have. My section is for interaction so I'm happy to answer any questions, even if you think it might be dumb, just ask away! (Only if its audio related by the way )
No, people are just retarded..
Ive got 2x12" pioneer 2ohm champion series subs im after a decent amp to run them, recommendations?
Sleeper Wagon - In the Build
VP Executive series 2
Check out My Ride
Current ModsWidened S/C CAI, 2.5" exhaust, Advance headers, no bellmouth, 17" VY SS, Foamy TuneFuture ModsNew CarWantedMONEY!!!
