Exactly right dephilile. Interesting explanation there too Michael! (never heard that "spring" thing before, but very logical!)
Capacitors impede the flow of low frequency energy, by virtue of what is called "capacitive reactance". As the frequency increases, the reactance decreases. Inductors (coils) do the same sort of thing, but in reverse - frequency up, reactance up. For that reason, the most basic type of speaker crossover is simply a capacitor in series circuit with the tweeter - thereby only allowing the higher frequencies through. (higher end crossovers will use inductors as well)
However, 220uF (micro-Farad) is far too large to use - you'd destroy your tweeters in seconds if you were to use a cap of this value. Generally for 4 ohm speakers, the series cap for the tweeter should be somewhere between 4.7 and 10uF, depending on where in the frequency range you want the tweeter to become active. (smaller capacitor, higher crossover frequency) For a 220uF capacitor the crossover frequency would be about 180Hz - I don't know of a tweeter in this galaxy that will enjoy a frequency that low, unless it happens to be a "piezo" type tweeter. Piezo's appear (to the amp driving them) as a capacitor, and in fact can be used without a crossover network at all, the device simply won't even try to produce low frequency energy. (but I'd never use a piezo except in PA type scenarios. They're tough, but the sound is a bit harsh and "tizzy")
Anyway - I'm doin' it again - writing a bloody book!!
Cheerz!
