- Feb 22, 2005
- 1,188
- 335
- 83
- Age
- 36
- Location
- Geelong
- '97 Caprice 355ci & VZ SS Ute
ITEM: K&N Pod Filter
CONDITION: Brand New, Never Used.
OTHER INFO:
Re-Usable K&N Filter outflow any other air filter by up to 900 cfm and for power gains of up to 15 hp.
PICTURES:
ITEM: Tectaloy Anti Freeze Anti Boil Concentrate
OTHER INFO:
Tectaloy products are the only cooling system products in Australia to be independently tested to SAI Global specifications and certified to comply with all the relevant standards and test methods required for coolants and corrosion inhibitors. I run it in my 355 and it never goes above quarter.
PICTURES:
ITEM: ACL Manifold Gasket & Dayco Thermostat
OTHER INFO:
Coldest Thermostat for 304’s 71 degree along with Manifold Gasket Too Suit Starr Manifold.
PICTURES:
ITEM: ‘99 VS-VT Engine Covers
CONDITION: Mako Condition
OTHER INFO:
Bare Metal Re-Spray. Sprayed Cherry Candy Red. Comes With Bracket To Suit Engine Covers.
PICTURES:
ITEM: Starr Performance Manifold & Throttle Body
CONDITION: Like New
OTHER INFO:
Starr Performance Holden EFI 5 litre (5.7lt Stroker) intake manifold and 90mm throttle body (1160 cfm)
The Starr manifold and throttle body conversion transforms power and torque of the EFI Holden V8 (VN – VT1), fits under the bonnet, looks standard and flows 1160 CFM (factory 580 CFM, a 106% improvement in air volume). It is the perfect replacement manifold for anybody looking to achieve a simple gain over standard, or for the enthusiast who is building a 400HP+ cammed stroker motor. Starr 90mm throttle body and manifold accepts the stock fuel rails, covers, throttle cable and cruise control cable and all the correct emission equipment to be re-used and to retain the factory look.
Good manifold to work with, easy to tune, dont have to worry about buying other parts to suit the manifold (cables, bolts, throttle body brakets) with all the cracking down on the car scene, you can still be making more power than the standard manifold but still keeping the standard look so saving from EPA's and Defects. its done roughly 300-400 k's before i ripped it off and decided to smooth it all down, so its practically brand new
PICTURES:
PRICE: Complete Package $1500 . Manifold Alone Brand New Is $1990
DELIVERY/PICK UP INFORMATION: Pick Up, Can Freight At Buyers Expense
PAYMENT OPTIONS: COD or Direct Deposit
CONTACT DETAILS: Andrew - 0409 970 092
OTHER INFO:
PICTURES:
OTHER INFO:
PICTURES:
OTHER INFO:
PICTURES:
OTHER INFO:
PICTURES:
CONDITION: Like New
OTHER INFO:
PICTURES:
