- Feb 2, 2003
- 3,002
- 428
- 83
- Age
- 44
- Location
- Adelaide
- Website
- www.justcommodores.com.au
- BYD Atto 3 / RAV4 Hybrid
Many Commodores are now reaching an age where their engine mounts are beginning to crack and fail due to the high torque they have been placed under throughout their lifetime. Signs of a worn engine mount could include engine vibrations, misalignment, engine damage, broken belts and hoses or excessive noise.
<a href="http://clixtrac.com/goto/?211406"><img src="http://www.justcommodores.com.au/temp/Transgold1.jpg" width="640" height="480" alt=""/></a>
Most modern Commodores are equipped with hydraulic engine mounts, which feature a fluid chamber designed to dampen noise and vibration into the cars cabin. Although these mounts do offer comfort they are certainly more prone to failing under the heavy loads placed on them.
There are many options available to replace these mounts, though often aftermarket upgrades can be costly and overkill for street use resulting in an uncomfortable ride. These Transgold engine mounts are an affordable solution and a direct OEM replacement to help counter any excessive movement that could be occurring under your hood.
You can pick up the Transgold mounds for around $55 from Supercheap Auto stores or online HERE to suit the LS1 fitted in the VT-VZ commodore range, V6 VE Commodore and many more.
